Alternative Bump Stops
Discussion in 'Suspension' started by DaWillDaBeast, Oct 17, 2010.
  1. Oct 17, 2010 at 8:34 PM
    DaWillDaBeast
    DaWillDaBeast [OP] Well-Known Member
    Will
    Colorado
    05 Tacoma 4x4 with some goodies
    Things
    So when I lifted my rear I ended up getting a set of Bilstein 5125's in the 10.17" length and they were a little to long and were getting fully compressed before I was on my bump stops, so I needed some new ones but I'm a chepo and didn't want to nearly $200 for a set of bump stops. So I bought a set of Energy Suspension 4 1/2" bump stops and made them work
    I started with some stock bumps modded to fit with the All Pro flip kit
    Cut the stock bumps off
    Then took the energy suspension bumps
    Cut the bolt off
    Drilled the center out so the bolt on the leaf pack has room
    Put a few welds on to hold it all together
    Then mounted them up
    I'm very happy with the outcome and I think its a great alternative for those that are on a budget and don't mind a little work. On a side note I also have an extra set of the same Energy bump stops I'd like to get rid of if anyone is interested :D
  2. Oct 17, 2010 at 8:40 PM
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
  3. Oct 18, 2010 at 6:02 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Wow those are huuuuge. Nice.
  4. Oct 18, 2010 at 4:34 PM
    DaWillDaBeast
    Will
    Colorado
    Things
    Ya they are big, but no bigger than the timbren bumps (I think?)
  5. Oct 18, 2010 at 4:49 PM
    TexasTacoma37
    Maybe it's the bright color that's throwing me .
  6. Oct 18, 2010 at 4:54 PM
    jandrews
    '09 FourDubDee TRD OR
    Looking forward to testing those Wheeler's Superbumps I got comin...eventually...when Wheeler's ships them...right around the Winter Solstice...
  7. Oct 18, 2010 at 4:56 PM
    DaWillDaBeast
    Will
    Colorado
    Things
    I had to make them big because my rear shocks were fully compressed before hitting my bumps when I was fully stuffed using the stock ones. With these the frame hits the bumps right before my shocks are fully compressed so that I dont blow my shocks, but I still get nearly 100% compression.
  8. Oct 18, 2010 at 5:00 PM
    DaWillDaBeast
    Will
    Colorado
    Things
    Bili 5125's in 10.17"
  9. Oct 18, 2010 at 5:10 PM
    DaWillDaBeast
    Will
    Colorado
    Things
    Ya, I knew it was going to be close when I ordered them but I could not find many people running 5125's so I went for it, and it required a bit more work than i was hoping. But at least I have some sweet droop in the rear now.
  10. Oct 18, 2010 at 6:10 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    Those things make the stock bumps look so wimpy.
  11. Oct 19, 2010 at 12:51 AM
    StatutoryAPE
    StatutoryAPE Well-Known Member
    Joey
    Phoenix,AZ
    2000 Prerunner xtracab
    TRD Headers,CAI, dynomax super turbo, blacked out headlights, Smoked LED tails, Billy 5100 w/OME 881's and 5125's in rear, rear tube bumper, tint 35% front 3 windows & 5% in rear 3. fiberwerx 4.5's
    on this pic it looks like your shock is facing outwards. shouldnt the mounting holes/bolts be facing out instead? not sure if anyone else noticed. if im wrong let me know
  12. Oct 19, 2010 at 7:26 AM
    DaWillDaBeast
    Will
    Colorado
    Things
    I'm not sure I know what you mean? The shock adaptors bolts are facing outward?
  13. Oct 19, 2010 at 7:29 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    The axle moves forward and backward as the suspension cycles. If you rotate that upper mount so the bolt is perpendicular to the frame, you'll be less likely to experience binding at that upper shock mount.
    You can see in your picture how the upper mount is already flexing quite a bit. When the suspension compresses, the bottom of the shock is going to move backward even further than it is in this picture. Something to consider.
  14. Oct 19, 2010 at 7:58 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    those look sweet will!
    you have a side by side shot of the new ones and the stockers? i'm curious how they compare size-wise to the timbrens. her's a picture of the stock vs timbren
  15. Oct 19, 2010 at 8:28 AM
    DaWillDaBeast
    Will
    Colorado
    Things
    Ohhh, I see exactly what your saying. I'm at work now so I can't check but I believe the reason I put them on that way is because the adaptor hits that metal lip around the tower if I try and turn it anymore. You think they will be fine like they are or should I try and grind that ring down some so I can get it perpendicular?
  16. Oct 19, 2010 at 8:29 AM
    DaWillDaBeast
    Will
    Colorado
    Things
    I was wondering the exact same thing, I'll take a pic when I get home.
  17. Oct 19, 2010 at 8:39 AM
    mjp2
    NJ
    I'd try my best to get that mount rotated if it was my truck. It'll definitely be less wear on the shock eye bushings. :thumbsup:
  18. Oct 19, 2010 at 8:56 AM
    Chachie
    Chachie Well-Known Member
    Justin
    Nor Cal
    '06 TRD OR, 4x4, Auto, 6" Fabtech, 35's
    Locker mod, Anytime fog mod, always 400w mod.
    I have the same shock adapter and mine is rotated. The way i did it was i mounted the adapter to the shock and then bolted it into the mount.
  19. Oct 19, 2010 at 10:55 AM
    StatutoryAPE
    Joey
    Phoenix,AZ
    x2 on that. i would be afraid that my shock eye would break off if i hit a pothole or was wheeling hard.
  20. Oct 19, 2010 at 11:47 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Have you guys checked out our Super Bumps? They should be back in stock in a couple weeks.
