Alternative to extended 5100s...
Discussion in 'Suspension' started by Andrew H, Jul 9, 2017.
  1. Jul 9, 2017 at 7:55 PM
    Andrew H
    Andrew H [OP] What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    Hey guys,
    One of my rear shocks is leaking pretty good so I've been doing some research on getting new ones to replace the RCD/Bilstein extended length 5100s (f4-be5-b110-t5) which I got from Marco when he worked at DSMS. I know there are a lot of threads regarding the extended 5100s but most of those are just about if they'll work with their set-up.
    These are the specs on them...
    Extended Length: 27.28" Inches
    Compressed Length: 16.34" Inches
    Travel: 10.94 Inches
    Valving 255/70
    Can anyone confirm for me before I start shopping around for new shocks if these are the correct 5125s I should order if I just want something similar to the extended 5100s only with softer valving??
    5125 33-104645
    Extended 25.93"
    Compressed 15.91"
    Travel 10.17"
    Valving 160/70
    If not, then what do you guys recommend if I didn't want the extended 5100s again? Only have the TSB AAL and an additional 1.5" AAL in the rear.
    Thanks!
    Andrew
  2. Jul 10, 2017 at 1:35 PM
    Andrew H
    Dirty Tucson
    2017SSMDCSBTRDS
  3. Jul 10, 2017 at 1:37 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Do you just mean TSB leafs with a 1.5" AAL? regular 5100s will work if that's the case.
  4. Jul 10, 2017 at 2:16 PM
    Andrew H
    Dirty Tucson
    2017SSMDCSBTRDS
  5. Jul 10, 2017 at 2:17 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
  6. Jul 10, 2017 at 2:20 PM
    03 NIGHT TACO
    03 NIGHT TACO Well-Known Member
    Jack
    Eastern Washington
    3.4 5 speed TRD
    Kings/Dakars/ARB
    You could do OME nitrochargers as well if you wanted something different. Probably a little more expensive though.
  7. Jul 10, 2017 at 2:23 PM
    Doogz
    Doogz Well-Known Member
    Bryce
    Western MA
    2009 MGM AC
    yep..
    I have regular 5100s with tsb pack and 1.5 AAL and it rides and functions beautifully.
    Andrew H[OP] likes this.
  8. Feb 26, 2019 at 11:52 PM
    Andretti34
    Andretti34 Well-Known Member
    Andrew
    Irvine, CA
    2013 SR5 4x4 DCSB
    I recently purchased a set of used set of the dakar cs047r, I plan on taking out the third leaf and don’t plan on doing a U bolt flip or shock relocation. I was wondering for those of you that have done this and went with a longer rear shock, what shock did you go with and exactly what bump stop setup did you use so you don’t over collapse and blow up the shock? A link to the bump stops would be awesome as well :thumbsup:
  9. Feb 27, 2019 at 4:10 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I had this set up and did the b110, and got bumps I kept stop bumps. I did limit uptravel by 1” to keep from bottoming out. I bolted a hockey puck to the frame where the bump hits, because it’s exactly 1” thick. Works great.
    Don’t forget you’ll need longer brake lines with that set up.
  10. Feb 27, 2019 at 8:13 AM
    Andretti34
    Andrew
    Irvine, CA
    2013 SR5 4x4 DCSB
    So did you keep the stock bumps and add the puck or go with a longer aftermarket bump and add the puck?
  11. Feb 27, 2019 at 8:25 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Stock bump with hockey puck for the cheapest option. Wheelers super bumps work without pucks if you want to avoid them.
    Andretti34[QUOTED] likes this.
  12. Feb 27, 2019 at 8:49 AM
    Andretti34
    Andrew
    Irvine, CA
    2013 SR5 4x4 DCSB
    So as long as I limit it by 1 more inch over stock then I should be good.
    Thanks for the help :thumbsup:
    EatSleepTacos[QUOTED] likes this.
