Alternatives to CV Dust seal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JeffBoyardee, Sep 18, 2021.
  1. Sep 18, 2021 at 6:10 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    could be on its way out. Hard to say without being there. Compare it to the passenger side and check if it’s significantly more. Also note if you were getting any kind of growling when driving in 2wd that goes away in 4wd, that’s a give away that the needle bearing in the diff is on its way out.
  2. Sep 18, 2021 at 6:13 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    I bought a timken outer dust seal for my GX. Same CV setup as a 4th gen 4Runner. Maybe there is a comparable for a Taco.
  3. Sep 18, 2021 at 6:20 PM
    JeffBoyardee
    JeffBoyardee [OP] Well-Known Member
    Jeff
    Seminole, FL
    2011 TRD Off-Road Tacoma DCSB
    Hm. My brothers 4runner uses the same CV's as I do. Do you recall the part #?
  4. Sep 18, 2021 at 7:24 PM
    JdevTac
    Josh
    GA/WA
    2nd gen
    I retract what I initially posted. I was thinking you meant the dust seal that gets pressed into the inside of the spindle, between the bearing and CV. But you mean the seal that always comes pressed on to the outer CV. The others are right I see no aftermarket part for that part number you listed.
  5. Sep 19, 2021 at 6:29 AM
    JeffBoyardee
    Jeff
    Seminole, FL
    How important is this seal? I know it must be important, since it's there, but would it be ok to put it back together for a week until I can get the seal?
  6. Sep 19, 2021 at 10:38 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    For a week it wouldn't be the end of the world, just don't go driving in a lake between now and then. It's essentially what seals the wheel bearing off from seeing any contamination from the inner part of the spindle, so without that "dust shield", the inner seal that's pressed into the spindle has nothing to seal against.
  7. Sep 19, 2021 at 10:40 AM
    JeffBoyardee
    Jeff
    Seminole, FL
    Ill be waiting anyways because of the wrong diff seal in my other thread, but thank you
    6 gearT444E[QUOTED] likes this.
  8. Sep 19, 2021 at 6:21 PM
    nickonfire700
    nickonfire700 Reg. Cab Nation Member
    Nick
    Rhode Island
    05 Reg Cab SR5 4x4
    Satoshi grill, 3rd Gen TRDOR Bucket Seats, TRD front skid plate, TRD Beadlock Wheels, TRD Exhaust, OEM bed mat, LCE Header, LCE Balance Shaft Delete, ECGS front diff bushing, TRD Sport LSD rear diff, Diode Dynamics SS3 Sport fog lights, Stainless Steel Brake-lines, No A/C with Defrost mod, 2014 OEM Radio, Illuminating 4x4 switch, Various LEDs, UWS Toolbox, Proven Design Products Mudflaps, Bilstein 8112 front Coilovers w/ rear Bilstein 5125's/IronMan lift leaf springs, Archive Garage Hammer Hangers, JBAs HD UCAs, SOS Bolt-On rock sliders, TRD bedside decals, ImMrYo Mirror Bracket, Relocated rear diff breather, 2019 Steering wheel, color matched door handles
    This is what you need:
    https://www.ebay.com/itm/293572598315
    I had to replace this seal when I bought a used axle from LKQ, and that was the only aftermarket version I could find, and that I could get quickly.
