Alternatives to stock cats?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Timbo66, Aug 15, 2024.
  1. Aug 15, 2024 at 8:20 AM
    Timbo66
    Timbo66 [OP] Well-Known Member
    My cats are bad, throws a P420 code. Last year I added O2 sensor spacers to avoid the problem and get past an emissions test (It was a temporary fix, don't troll me). Now it's time to actually replace them.
    Local shop quoted me $3400 to replace them with OEM cats, I need something cheaper, preferably high-flow.
    Also.... do I need to replace the secondary cats too, or just the primaries?
  2. Aug 15, 2024 at 8:29 AM
    snook 32
    snook 32 Well-Known Member
    Herb
    Davie Florida
    08 pre runner
    take a look at flow master universal cats
  3. Aug 15, 2024 at 11:00 AM
    Timbo66
    Hoping for a bolt-in replacement. Those need to be welded. In CO only OEM cats are allowed. I don't mind using non-OEM even though they're not allowed, but I don't know that I can find someone willing to weld them in.
  4. Aug 15, 2024 at 11:04 AM
    TacoTuesday1
    SD CA
    Bolt some cats on it. That work.
    interesting I didn’t know that about CO. I thought CA was the only one that was strict. For example CA requires CARB approved cats that cost significantly more than non CARB cats.
  5. Aug 15, 2024 at 11:05 AM
    spicy_fish_taco
    spicy_fish_taco Well-Known Member
    '18 2.7L Taco 4x4 Access Cab
    magnaflow makes oem quality cats
  6. Aug 15, 2024 at 11:31 AM
    TacoRob08
    TacoRob08 Well-Known Member
    Rob
    Fredericton, NB, Canada
    17 Sport DCLB
    gibson exhaust, OVTuned base 91, AFE intake
    Was just about to say the same thing
  7. Aug 15, 2024 at 11:42 AM
    GearHead899
    GearHead899 Well-Known Member
    Justin
    Ocean View, NJ
    11' Black X-Runner, 06' RR X-Runner
    If you dont use a OEM cat, theirs a good chance it could throw a p0420 code again. A lot of newer vehicles are very sensitive to the cats. Iv installed a number of non oem cats on customers cars at their request and most of them still throw a random p0420 code now and then. If you go the aftermarket route, you may still need to run a o2 spacer
    Dm93 likes this.
