Alternator and fan belt slowly keep turning after the truck is off
Discussion in '1st Gen. Tacomas (1995-2004)' started by Travo50, Oct 15, 2021.
  1. Oct 16, 2021 at 12:09 PM
    wesb1023
    wesb1023 Well-Known Member
    Westley
    Eastern NC
    04 Double Cab
    Thats what it appears to be. Your truck is moving with it in gear. Totally normal for it to do that, without the parking brake set. If you had your parking brake pulled all the way, I’d check the rear brake shoes, and also adjust them up if they aren’t worn out. Rear shoes out of adjustment will also cause a long travel brake pedal application.
    Travo50[QUOTED][OP] likes this.
  2. Oct 16, 2021 at 12:18 PM
    SLAPS 65
    SLAPS 65 Dirty deeds, done dirt cheap..
    Leif
    Nor Cal east Bay Area Ca.
    2000 Tacoma 4wd ex cab 3.4 auto.. manual hub, J shift
    That must be the reason I’ve always been the heavy duty guy, never been much for electrical, lol!
    :anonymous:
    Bivouac[QUOTED] likes this.
  3. Oct 16, 2021 at 12:23 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    If all the pulleys are tight the only thing that will allow a belt to move would be the crankshaft.
  4. Oct 16, 2021 at 12:56 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    That's one of coolest things I've ever seen.....are you pranking us....
    I can hardy wait to see what all these genius come up with....
    Like Supreme Court setting a new president...
    Bivouac likes this.
  5. Oct 16, 2021 at 1:05 PM
    O'Silver_Taco
    MD
    Manual or Automatic ???
    Looks like its rolling back in gear......if its manual, your rear brake adjusters need to be checked...
    bet that blade is stuck on top star adjuster.....
