alternator belt spec
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ltk, Oct 11, 2015.
  1. Oct 11, 2015 at 11:09 AM
    Ltk
    Ltk [OP] Well-Known Member
    ive tried searching on here as well as google.
    about a month ago i replaced my alternator and ever since it has squealed pretty loud on initial startup for a second.
    i cannot find the spec for how much movement the belt should have up and down.
    anyone have an idea? im sure its not tight enough
  2. Oct 11, 2015 at 11:40 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    Quick test:
    Start the truck, put on the lights, switch to high beam and rev it up to 4,000 for a second. Chances are if the belt is too loose it will squeal.
  3. Oct 11, 2015 at 12:24 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    The dealers have an SST for measuring proper tension/deflection. What I do when a belt squeals, is to tighten the belt a little more and see if the squeal is gone. If not, tighten it up a bit more. You don't want it too tight, or it could shorten the life of the belt and/or bearings.
  4. Oct 11, 2015 at 5:14 PM
    Ltk
    it squeals when revved up after startup. seems to me like its too loose. i will tighten tomorrow and try again.
    i was thinking maybe there was a measurement, but ill just tighten little by little until it stops
  5. Oct 11, 2015 at 5:29 PM
    arifleman
    arifleman Well-Known Member
    Pacific NW
    2002 TRD 3.4L Ext Cab
    You want roughly 1/4" deflection at mid-belt when it is tightened. That's what I use and recall reading at some point. Works for me.
  6. Oct 11, 2015 at 11:49 PM
    Ltk
    thanks! will try to figure a way to roughly measure it
  7. Oct 12, 2015 at 12:58 AM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    I thought it was 1/4" too!!
    But yeah just keep going till she stops that terrible noise, but if you go till the belt is so tight it has no deflection youve got something going on...
  8. Oct 12, 2015 at 9:06 AM
    skeezix
    Colorado
    1998 Limited
    The eraser on a new pencil (remember those? wooden things that people used to write with) is 1/4 inch long.
