Alternator Belt Squeal on Engine Start-Up
Discussion in '1st Gen. Tacomas (1995-2004)' started by JoePoulson, Jan 21, 2012.
  1. Jan 21, 2012 at 6:39 PM
    JoePoulson
    JoePoulson [OP] Loves Tacos
    Joe
    Lake Mary, FL
    Black 2012 TRD Sport DCLB 4x4
    De-mud flapped, tinted, de-badged, WeatherTech FloorLinered, 400W anytimed, Salex Organized
    I had all of my belts replaced the first week of December, 2011. They were squealing like crazy, and were beyond ready for replacement. The new belts have been great ever since, but lately, my alternator belt is squealing when I start my cold engine. It's only for a second, unless my A/C is on, then it's for 2-3 seconds.
    I assume that belt needs to be tightened, but I have no clue how to do it. I've searched high and low for specific instructions on how to do this on my Taco (2004 PreRunner, 3.6L V6), but have come up empty. Lots and lots of belt threads here and elsewhere, but none give how-to's for my Taco. I can't even find anything in my service manual.
    If anyone can point me in the right direction for this, I would appreciate it. I've learned so much about my truck since I bought it last November (I replaced my brakes, all fluids, new stereo, etc.), but I'm still very green when it comes to vehicles. I had a local mechanic replace my belts because it would have taken me a week.
    Thanks!
  2. Jan 21, 2012 at 6:47 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    The service manual tells you how to remove it so it's the opposite of this link. Obviously all you need to do is tighten the adjustment bolt. Google how to tell if the belt is tight, I normally just tighten mine till they don't give hardly at all when pushed in the center. But this is completely inaccurate.
  3. Jan 22, 2012 at 6:56 AM
    JoePoulson
    Joe
    Lake Mary, FL
    That's perfect! I saw bits and pieces around the web, but not such a simple explanation. It sounds silly, I know, but the last thing I wanted to do was to mess anything up. Also, with the adjusting lock bolt and adjusting bolt being underneath my alternator, I just wasn't seeing them.
    I tightened the belt a bit this morning, and no squeal! I will continue to test and monitor, but I believe I am all set.
    Thank you!
  4. Jan 22, 2012 at 3:36 PM
    misterdmac
    misterdmac Well-Known Member
    Doostin
    In or around the truck
    '97 2.7L DLX
    Sometimes if tightening doesn't get all the noise out, rubbing some chalk on the inner belt face can help. Has worked for me on a couple of old cars and both my Toyotas. But you should have about 1/4 inches play either direction in the belts, no more than 1/2 inch.
  5. Jan 22, 2012 at 3:39 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    I've used ivory soap before...works great until it washes off if it rains.
  6. Feb 7, 2017 at 11:03 AM
    leprechaun
    leprechaun Active Member
    Evan
    2004 Tacoma SR5 TRD
    The link is dead on this, anyone have an updated one to a similar source?
  7. Feb 7, 2017 at 11:46 AM
    TooMuchToDo
    TooMuchToDo Well-Known Member
    2002 Gold Tacoma XtraCab with 192k
    ...we'll get there.
    you want to loosen up the pivot bolt (on top of the alternator),
    then loosen up the slide (the bolt under the alternator that runs the same direction as the truck (pointing towards the camera in the picture), then turn the adjuster (going sideways in the picture).
    tighten everything up when you're done
    riddmkidd and Thuguon2.7 like this.
  8. Feb 7, 2017 at 3:36 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    I just did all my belts (incl timing belt) several weeks ago. When I installed the accessory belts, I basically just eyeballed them, but didn't make them "too tight" (whatever that means, lol). Then, after a day or two the alt belt started squeaking on start up. So went back in and tightened it.
    There, now it's tight enough.
