alternator fail??
Discussion in 'Technical Chat' started by rawdog, Nov 22, 2009.
  1. Nov 22, 2009 at 8:39 PM
    rawdog
    rawdog [OP] Well-Known Member
    Kelowna B.C.
    2016 TRD Sport Upgrade PKG DCSB
    Hey guys
    my new alternator just went.. fortunately its covered under warranty, but the problem is it went on sat morning. mech aint open until monday, iwork until 3.. question is.
    how long do you think my battery will last
    i tested it and its at 11.75 volts..
    waht is the smallest voltage my truck will take until it starts to die.
    i have an optima red top.
    btw im only assuming its my alt..
    bat light on as well as brake light.
    and with the voltage on the terminals so low with truck running..
  2. Nov 22, 2009 at 8:57 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    couple of miles maybe with all accessories shut off.
  3. Nov 22, 2009 at 9:01 PM
    ak47
    ak47 v.hey its my Avatar avatar.v
    Anthony
    Washington
    stock 2nd owner
    it depends how far do you need to drive? i wouldnt risk more then 10 miles without one of those power pak things. lol. no one wants to be stranded! ;)
    unplug the negative terminal if the truck dies think alternator.
  4. Nov 22, 2009 at 9:09 PM
    sachou
    sachou Well-Known Member
    Sam
    Richland, Washington
    2006 TRD Sport Acc Cab 4x4 V6 6spd
    Sounds like your battery is already slightly drained...shouldn't they be at around 12.6 volts?
    This guy: http://www.instructables.com/id/SDG93IZFT7PLXT3/ actually disconnected his alternator completely to reduce the parasitic drag to increase mileage.
    So it seems doable.
    I'd definitely charge the battery overnight if you had a charger.
    Remember, it has to be a gel-cell charger, because they're lame and have to charge slower.
