Alternator help, hopefully…
Discussion in '2nd Gen. Tacomas (2005-2015)' started by donosparks234, Mar 21, 2024.
  1. Mar 21, 2024 at 11:57 PM
    donosparks234
    donosparks234 [OP] Member
    Murray, Ky
    2008 2.7 L manual Tacoma
    I hope the alternator is the problem and not something more sinister. When the battery light first came on the dash I got some supplies together and then noticed my dome light dimming and getting very bright. Then my radio would cut out. And cherry on top both my headlight bulbs and one parking light bulb blew. Both high and low beams. This is all within 6 hours
    At this point I went to AutoZone to get battery alternator and starting system checked. Of course battery light was off and they said my starting system was bad? I don’t know how it works fine.
    I know it was a fluke but at home with voltmeter with engine running it first read 15-17 volts jumping between those and then the battery light went out and then it read 14 volts like normal. Battery was normal voltage at rest.
    Decided to take alternator out and check continuity and resistance of diodes, slip rings, and b terminal. They seemed fine and checked brushes not really sure what bad brushes look like so I’ll put a picture below.
    The voltage regulator would jump between 0-3 ohms of resistance and then to 1000-1500 ohms. Not sure if that’s a fluke but I’m guessing voltage regulator is out (guessing my bulbs got a huge surge due to faulty regulator and blew) and as far as I know that part can’t be replaced and an all new or reman alternator is needed.
    Any agreement, disagreement, or suggestions are appreciated.
  2. Mar 22, 2024 at 1:27 AM
    TacoTuesday1
    SD CA
    1. Autozone no.
    2. in general when folks look at replacing alternator or regulator people generally prefer to replace the whole alternator
    3. there are tests that can be done on the alternator and battery
    4. why not replace it. It’s old and has miles.
    donosparks234[OP] likes this.
  3. Mar 22, 2024 at 2:35 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Any local rebuilders that are quality locally? I'd rather keep a quality one rebuilt by someone who knows what they are doing then some sketchy autozone alternator ''rebuilt'' by some 16 year old that replaced ONLY the bad part and tossed a coat of silver paint on it.
  4. Mar 22, 2024 at 8:23 AM
    donosparks234
    Murray, Ky
    not that I know of, there’s some little mom and pop auto shops around that might do it. BUT this is my daily and idk what the turnaround is on rebuilding, seems faster to buy all new.
  5. Mar 22, 2024 at 9:49 AM
    Revelations
    Revelations Well-Known Member
    2014 MGM DCSB
    I would just buy a denso alternator and replace it.
  6. Mar 22, 2024 at 10:00 AM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    The old joke about rebuilt starters and alternators is they get 500 from the boneyard, try them once. Half fail. The other half get painted and tagged as rebuilt.
    OP, buy a reman alternator from Toyota. They don't sell "new" alternators anymore (learned this last year). Do it right and you only do it once.
  7. Mar 22, 2024 at 10:01 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    The diode boards are the things to go, i looked into replacing myself but realistically a denso reman from napa was the better quicker option.
  8. Mar 22, 2024 at 10:18 AM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    I'll add my two cents to the party. I have a great local shop that rebuilds alternators and starters and is only about a mile from my house. Cost to rebuild was more than a Denso reman. Part of my goal was also to check with them how much bigger/more output I could get to compete with costs of aftermarket beefy alternators like Mechman/DC Power and that also wasn't worth doing. So yeah, follow what others have said and buy a Denso reman or Toyota OEM reman (likely the same thing) and just do the job once.
  9. Mar 22, 2024 at 11:17 AM
    TacoTuesday1
    SD CA
    Denso seems like the best bet.
    OP how many miles?
    anything else may not be as good and last. Sure Autozone has a warranty but how hard is the job and how many times do you want to swap it out. Seems like more of a last resort if that’s all that’s nearby broken down on a road trip. But that’s up to you. I know I’ve made the mistake of using a cheap shitty part for it to not work before. At least once.
  10. Mar 22, 2024 at 11:29 AM
    donosparks234
    Murray, Ky
    It’s sitting at 153,000
  11. Mar 22, 2024 at 8:14 PM
    ABA180
    East Bridgewater MA
    This is correct
    It's about a 2-3 hour job so think about how many times you want to mess with it too. My dad went the cheapo route long ago and it lasted a month, but at least it was a 10 minute job to R and R the bum one.
