Alternator hum
Discussion in '1st Gen. Tacomas (1995-2004)' started by dmk679, Jan 11, 2024.
  1. Jan 11, 2024 at 12:45 PM
    dmk679
    dmk679 [OP] Well-Known Member
    Orlando, Florida
    My relatively new alternator (from PO; appears to be a cheap one) is making a very slight humming noise when it is under load. I can hear it with my drivers window down. The belt is new and the tension is appropriate. Checked the battery voltage and it is spot on.
    Is this normal or should I be concerned the alternator will give out?
  2. Jan 11, 2024 at 2:07 PM
    taco03Trd
    taco03Trd 03 rig trd v6
    Carlos
    Riverside ca
    03 DC prerunner trd v6 2wd
    Ome 881 5100's jba's looking for more
    Sounds like the bearing is no good .
  3. Jan 11, 2024 at 3:03 PM
    dmk679
    Orlando, Florida
    Would the bearing noise come and go based on the load?
    Can I change out the bearing myself or do I need to get another alternator?
  4. Jan 11, 2024 at 3:26 PM
    taco03Trd
    Carlos
    Riverside ca
    Bearing sound should be on always if it bad . Did you do a sound test on the alternator with a long screwdriver? You should be able to listen to a grinding noise .
  5. Jan 11, 2024 at 3:28 PM
    dmk679
    Orlando, Florida
    The noise only happens when it is under load and will go away immediately when I turn my lights off.
  6. Jan 12, 2024 at 12:57 PM
    taco03Trd
    Carlos
    Riverside ca
  7. Jan 12, 2024 at 1:36 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    funny, yesterday i took my bad alternator to Oriellys along with my original receipt from 2012
    got new one bc of warranty
  8. Jan 12, 2024 at 1:57 PM
    dmk679
    Orlando, Florida
    Was your alternator making a noise?
  9. Jan 13, 2024 at 10:02 AM
    ControlCar
    Steven
    Sugar Land TX
    No
    But instrument cluster started to flash (Subaru) diff temp/brake/battery all at same…..intermittently
    When these light were on, volt meter gauge would drop
