Alternator is running, but system won't charge
Discussion in 'Toyota Trucks & SUVs' started by Isaiah, Feb 25, 2015.
  1. Feb 25, 2015 at 10:32 PM
    Isaiah
    Isaiah [OP] New Member
    San Diego
    1979 20r Pickup
    I have a 1979 20r that has been having electrical problems for awhile now. First I replaced my battery but my charge light stayed on. The light was still on. Then I got a new alternator and swapped it. Tests with a multimeter says its putting out 14+ volts. As soon as you load the system by turning on lights and the fan, voltage starts dropping and pretty soon its running off the battery.
    Any ideas?? I've read of a 5 or 6 plug alternator? There is a black wire running from the regulator to the alternator area but cannot find what its for, maybe a ground? Any suggestions would be very appreciated!
  2. Feb 25, 2015 at 11:00 PM
    BadBrains
    BadBrains Spreading the Aloha
    AL
    '07 Taco LT, '00 GS-R, '75 C10, '83 CJ-7, '19 T4R SR5
    King, TC +2"LT, 35's, Aluminum this and that.
    Not sure if it's your problem but double check your ground cable from battery to body.
    On my '83 it went up in smoke from corrosion(The cable, not the truck thankfully).
  3. Feb 28, 2015 at 7:53 AM
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    Attached is a general Toyota Charging System document that might be helpful for determining wiring connections. I would first clean the battery posts and terminal lugs and fully recharge the battery with an external charger. Then I would take the vehicle to an auto parts or battery store for a free battery and alternator test to determine if battery and alternator are healthy. They are both codependent on each other.
  4. Feb 28, 2015 at 7:59 AM
    n0rth
    n0rth Well-Known Member
    J.W.
    New Mexico
    2019 Tundra Platinum
    2009 Tacoma Access Cab SR5, 4wd, 2.7L URD S/C, 4:88's ARB lockers, 36x9.8r16 Radial TSL
    Check your regulator, I just went through this with my FJ-40.
  5. Feb 28, 2015 at 8:14 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Where?
  6. Feb 28, 2015 at 10:55 AM
    BadBrains
    AL
    If I still had an old pickup I'd probably convert to a GM one-wire alternator. LCE Bracket
    With that said, you'd probably get better help fixing your current setup over at the Marlin Crawler board.
  7. Mar 1, 2015 at 5:15 AM
    Shadetree
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    u
    Sorry, the 833 K .zip file exceeded the TW Forum's limitation. I should have checked the file size first. I have attached a diagram on one Tacoma engine that gives an example of how the charging system is connected.
  8. Mar 1, 2015 at 6:06 AM
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    Replaced a alternator and battery on a Geo Tracker last June.
    6 months later, the new-ish alternator would stop charging after 10 minutes of run time and the vehicle would run out the battery and sputter to a stop.
    It wouldn't start charging again until it cooled completely. We surmised the regulator failed.
    Napa lifetime warranty kicked in and replaced the Alt again.
    Do your usual standing voltage check,,then fire it up to see your charge volts,,and then let it idle for a bit. Accessories off at first,,then tested with them on. See what happens. It's a pretty easy and quick check to eliminate a possibility.
