Alternator not charging battery (fixed)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Yota80482, Dec 17, 2023.
  1. Dec 22, 2023 at 5:26 PM
    glk21c
    glk21c Well-Known Member
    MD
    2007 Silver Tacoma TRD Sport 4x4
    Even if it had nothing to do with the problem you’re having I would redo those wires connections on the negative battery terminal, the one that goes to the firewall is not connected very well
    Yota80482[OP] and usmc2msu like this.
  2. Dec 23, 2023 at 4:48 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Where does the other end of that harness go? If it does corrode, as mentioned above, how are people going about the repair?
  3. Dec 23, 2023 at 6:29 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Chris(NJ)[QUOTED] and TnShooter like this.
  4. Dec 23, 2023 at 8:25 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Cut and splice.
    Way back years ago.
    Another member had this issue.
    Took him a while to find the problem.
    @Jimmyh might remember.
    Our good buddy Muddin' Fun was the first guy I know to fight the problem.
    Kind of miss the guy. He disappeared right about the time COVID hit. I hope he is out there doing OK.
    Him and JimmyH were the first guys that helped me learn to read wiring diagrams.
    Then I met Dm93 and it just took off from there.
    winkel, Too Stroked, SR-71A and 2 others like this.
  5. Dec 23, 2023 at 1:51 PM
    Yota80482
    Yota80482 [OP] Member
    Cory
    06 tacoma
    So I tested the plug that’s attached to the alternator and had 12v at the green wire and 0v at the white wire. So I checked the 7.5 fuses at the fuse box under the hood. Tested the fuse and found out that it was blown. Thanks guys for all of the quick reply’s to my issue.
    Jimmyh and TnShooter like this.
  6. Dec 23, 2023 at 4:29 PM
    TnShooter
    Deogee
    STOCK
    Awesome.
    That wasn’t too hard was it?
    Better than changing an alternator.
    Yota80482[QUOTED][OP] likes this.
  7. Dec 23, 2023 at 7:04 PM
    Yota80482
    Cory
    06 tacoma
    @TnShooter no sir it wasn’t bad at all. I was more so pleased with the quick replies from you all and everyone’s opinion definitely saved me some money.
    Dm93 and TnShooter like this.
  8. Dec 23, 2023 at 7:12 PM
    Waasheem
    Waasheem
    2007 xrunner
    Some might say, now you HAVE to figure out why that fuse popped. I tend to disagree. I’m not saying don’t do any testing at all. But you don’t need to spend hours testing and in the end still find no cause. To each their own.
    If it were mine, I might plug a tester I have in the fuse socket and check the amperage draw while turning things on and off, maybe if I’m feeling extra ambitious, put my load tester on the battery.
    https://www.amazon.com/gp/product/B001TCXOTW?ie=UTF8
  9. Dec 23, 2023 at 7:17 PM
    WOODY2
    WOODY2 Well-Known Member
    RAMONA,CA.
    APPEARS has defeated many owners, get a meter and test them is the only sure way to verify status. Glad to hear it's corrected.
  10. Dec 23, 2023 at 7:22 PM
    Yota80482
    Cory
    06 tacoma
    @Waasheem the fuse blew because I made a rookie mistake rushing to get the alternator on before it got dark so I could hunt the next day. My wrench hit a bolt while removing a the power wire!!!
    usmc2msu, winkel, Jimmyh and 2 others like this.
  11. Dec 24, 2023 at 11:46 AM
    WOODY2
    RAMONA,CA.
    As the saying goes Let he who has not sinned cast the first stone. BTDT Glad you're up and running.
    Jimmyh likes this.
  12. Jan 1, 2025 at 7:52 PM
    Ebackus1
    Ebackus1 New Member
    Eric
    2006 White Tacoma 4 Door TRD Sport
    Airbags K&N Air Filer Suspension & Lift Custom Paint USB Outlets
    Thanks for the information so far. I have a similar issue with light on with refurbished (Auto Store) alternator not charging. All fuses are testing good with meter and power to green wire when key on and white wire when off. The battery light was not on before replacing with refurbished alternator. I appreciate any advice that can be offered.
  13. Jan 1, 2025 at 8:09 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    We've all done it and that's why the fuse is there!
    Glad you got it figured out but I would give those negative cables some attention before they force you to.
