alternator not charging
Discussion in '1st Gen. Tacomas (1995-2004)' started by Motobro440, Aug 17, 2021.
  1. Aug 19, 2021 at 12:49 PM
    Motobro440
    Motobro440 [OP] Active Member
    Frankie
    2000 single cab tacoma
    so when i turn my key on the battery bulb does not turn on why do i need to replace that and is it hard?
  2. Aug 19, 2021 at 3:08 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Did you check the rest of the wires and ground the yellow wire at the alternator and see if it turns on as I said in my previous post?
  3. Aug 19, 2021 at 3:36 PM
    Glamisman
    Glamisman Well-Known Member
    as stated by Dm93, if you unplug the connector at the alternator and ground the yellow wire the Battery light should come on. The regulator inside the alternator requires this circuit in order to function. Is it hard to take the dash/combination meter out to replace the bulb? That is difficult to answer as each persons ability and skill level/tool box is different.
