Alternator question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kcw5184, Jun 17, 2022.
  1. Jun 17, 2022 at 5:00 PM
    kcw5184
    kcw5184 [OP] YumaYota
    West Coast of Arizona
    2011 Tacoma DCSB V6 AT 4WD
    2011 V6 4WD with original 130 amp Alternator
    210000 miles
    Looks like thin dark black "grease" coming out of front cover on alternator. Also seems to be on inside of pulley and between pulley and front cover. Charges at 13.4v. Any ideas as to what this is?
  2. Jun 17, 2022 at 5:06 PM
    Bishop84
    Bishop84 Well-Known Member
    Oil leak either current or previously repaired.
    Typically on that side it's either the oil filter draining on to it, or more likely your oil pressure switch is leaking.
    Kolter45 and Dm93 like this.
  3. Jun 17, 2022 at 5:06 PM
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    Sure it isn’t oil from someplace else?
    wilcam47 and Dm93 like this.
  4. Jun 17, 2022 at 5:13 PM
    kcw5184
    Thanks for the replies. I keep the engine bay very clean however I have degreased that specific area again and will watch it. Its just weird. Seriously looks like a heavy oil or thin grease coming out of the front cover vents on the alternator. I may have a timing chain cover leak also but I thought read where those usually appear on the passenger side of the engine.
  5. Jun 17, 2022 at 5:39 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    When you say “front cover” do you mean the front of the alternator.
    As on the grease is behind the pulley and on the front of the alternator?
    Or are you saying the oil/grease is between (behind) the alternator and front timing cover?
  6. Jun 17, 2022 at 5:52 PM
    kcw5184
    Behind the pulley and on front of alternator
  7. Jun 17, 2022 at 6:07 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Are you sure it's not something else leaking oil that the belt is picking up and leaving behind on the alternator pulley?
    TnShooter likes this.
  8. Jun 17, 2022 at 6:21 PM
    Waasheem
    Waasheem
    2007 xrunner
    Are you the original owner? Do you use the quickie oil change places? Guessing someone didn’t know the trick to stick a container or hose on the oil filter thing. If it’s a tiny amount I wouldn’t worry. If it flinging a mess all over, a can of brake cleaner should do the trick.
  9. Jun 17, 2022 at 6:57 PM
    kcw5184
    No residue on any other pulley. I am the original owner and do all my own maintenance and I’m pretty meticulous about a clean engine and engine bay. Brake cleaner is a heavily used staple in my garage! I did use brake cleaner to remove it and cleaned/degreased the timing chain cover. Also put UV dye in the crankcase so hopefully I’ll be able to rule a timing chain cover leak in or out. All the thoughts and suggestions are much appreciated
  10. Jun 17, 2022 at 7:07 PM
    Kolter45
    Kolter45 Well-Known Member
    Denver, CO
    2013 TRD Sport, 2015 Inferno 4Runner
    Toytec Boss Leer/Rhino Rack TRD Wheels/Falkens
    Welcome OP. Have any photos that might help
  11. Jun 17, 2022 at 7:36 PM
    kcw5184
    I realize that pics will help immensely. Forgot to take them before I cleaned everything. I will drive it tomorrow then get a few and post. Thanks
