Alternator questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by IslandTacoma, Oct 23, 2017.
  1. Oct 23, 2017 at 6:59 PM
    IslandTacoma
    IslandTacoma [OP] Member
    2006 Tacoma 4x4
    My truck has died a few times lately, charging system's not working. If I put a battery with 13.6v in and fire it up it's at 12v at idle. I have no battery indicator on the dash, it doesn't flash for a second at startup, nothing. It will run for a while off of a charged battery but the ABS/brake light eventually comes on, then the check engine light for 0130, loses power, then the airbag light comes on right before it dies. I'm not sure if I've ever seen a batt light, but I see where it is, next to check eng.
    I pulled the alternator, 90a Bosch. Cleaned any corrosion/dirt, reassembled and reinstalled it, nothing. If I buy an alternator, I'm going to upgrade. I'm worried because of the no-dash-light thing. Did a previous owner just kill the dash led/wire, or is this the symptom of a bigger problem? Anybody have any ideas for something I overlooked? 120a fuse looks fine.
  2. Oct 23, 2017 at 7:03 PM
    4x4runner2002
    4x4runner2002 Well-Known Member
    Zach
    2002 4x4 limited
    suspension and armor
    Take the alt to get tested, most parts stores do it free.
    MuddyJackson and Sandman614 like this.
  3. Oct 23, 2017 at 7:03 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    I usually replace with an OE or equal.
  4. Oct 23, 2017 at 7:30 PM
    IslandTacoma
    2006 Tacoma 4x4
    Tried that when it was out,
    Parts store nor the wrecker had a bench test rig, but a Canadian tire about 45m away could have done it. I tried putting it back in, still no charge. Wrecker wants $175 for a used one, best price I could get on a new 130a was $265. The no-dash-light worries me though. If I plug in a new alt it's non-returnable, and the 130a is special order cash-up-front.
  5. Oct 23, 2017 at 7:33 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    In previous Toyota builds I’ve swapped my low output alternator with the highest OEM equivalent output alternator and it has been plug and play.
    In your case there is a 130amp OEM version you could upgrade to. Not certain the connectors are the same on a 2nd gen but it seems extremely likely. Almost a 50% boost in output without using expensive high output alternators.
  6. Oct 23, 2017 at 8:12 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Both (tow package 130 amp and non tow package 100 amp) 2nd Gen Alts have the same connectors.
    http://densoautoparts.com/find-my-part
  7. Oct 23, 2017 at 8:13 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Can you order from rockauto.com?
  8. Oct 23, 2017 at 8:22 PM
    IslandTacoma
    2006 Tacoma 4x4
    Thanks for the heads up, there's tons of good auto wrecker photos on eBay. The 130's are the same plug, I've been telling all the parts houses I have a tow package. I'm going to have to limp it around like this for a week, I can plug it in at work
    no credit card, and I'm in Canada. I can probably use someone's PayPal to buy something on eBay, there's lots of 130a-200a-240a ones on there.
    I'd like to diagnose the problem better, dash light (or lack of) worries me. Like maybe the alternator won't get an "activate" signal if the trucks not getting a "battery drain" light. Everything worked fine a week ago but I don't know if the dash light did or not.
    When everything's off (lights, ignition) and I hook up the battery there's a decent spark. I think there's a short somewhere, but it could be inside the alt? 120a alt fuse looks ok as does the 7.5a alt.s fuse.
  9. Oct 23, 2017 at 8:26 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Does that mean it's a hybrid, like those electric cars you see plugged in at fancy places lol. You said at idle the voltage is at 12v, what about at higher RPMs? Try starting it and then disconnect the battery while it's running, if it dies the Alt is definitely not working. There is a voltage sense wire that I've heard people talk about but I'm not sure that it applies to your issue because it's just measuring battery voltage.
  10. Oct 23, 2017 at 8:57 PM
    jdbunch1630
    jdbunch1630 Member
    Doug
    2006 Tacoma 4x4 V6
    Sometimes the battery lights just don't work, try to disconnect the battery with it running, if it dies you know the alternator is bad. I think your making a bigger deal out of the light not working.
    Good luck
  11. Oct 23, 2017 at 9:01 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    In america land of throw away parts sure, but he's in the desolate frozen north.
  12. Oct 23, 2017 at 9:14 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Do not do this, unless you want to get new electronic components. This is one of the worst advice I've seen on this forum.
    OP, if there is an electric shop near you, they should be able to rebuild your alt. They will bench test your alt first to confirm what is broken, if anything, then fix it and provide a warranty. Maybe only 90 days or so, but I've had good results from these perishing breed of mechanics.
  13. Oct 23, 2017 at 9:16 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    So what your saying is I need to go get new electronic components because I swapped dead batteries with a buddy whose alternator went out?
    @BamaToy1997 care to weigh in?
  14. Oct 23, 2017 at 9:21 PM
    Chuy
    Lakeside, CA
    Silver Taco
    Nay, I'm saying don't disconnect the battery cables while the car is running.
    Scorpion Regent likes this.
  15. Oct 23, 2017 at 9:21 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Which is exactly what we did to put my charged battery in his truck and his dead battery in mine to charge.
  16. Oct 23, 2017 at 9:38 PM
    Chuy
    Lakeside, CA
    Silver Taco
  17. Oct 23, 2017 at 9:42 PM
    Pigpen
    Dan
    Northwest Montana
    MuddyJackson likes this.
  18. Oct 23, 2017 at 10:26 PM
    IslandTacoma
    2006 Tacoma 4x4
    Thanks for the diagram Sandman!
    The truck dies if I do the old classic disconnect-the-battery test, good advice or not. Dies right away.not even going to click those links Chuy posted.
    Somebody pulled me a free GM alt from a 90s truck with similar mounts/pulley, I don't know if it's a cs144 like the ones they're selling for a Tacoma conversion or not, but I'm hoping I can scab it together enough to see if an alt fixes the problem anyway. Worth a shot.
    https://www.tacomaworld.com/threads/high-output-alternators-for-1st-gen.499065/
    There was one thread on here that said our oem alts put out 20ish amps at idle and the GM one does ~100 idle amps. Plus they're cheap and plentiful, and our alternators are down low where they get wet. I'll get a free one to troubleshoot with tomorrow so I'll see what I can figure out about wiring.
  19. Oct 30, 2017 at 10:58 AM
    BamaToy1997
    Bill
    Navarre, FL
    It is not always 100%, but it CAN be very dangerous to disconnect the battery with the engine running. The battery acts like a voltage stabilizer. When the battery is disconnected the alternator and vehicle electronics "think" that the battery is heavily discharged, or dead. This results in a much higher output from the alternator. In many, many cases it has resulted in a much higher voltage than is safe for the sensitive electronics of today's modern vehicles. Now it won't do it every time, but you do run a high risk of destroying an ECU, Radio, BCM, or other expensive electronic component by disconnecting the battery with the engine running.
  20. Oct 30, 2017 at 1:54 PM
    IslandTacoma
    2006 Tacoma 4x4
    Well, glad I know not to do that again, and now why - thanks.
    I was driving around for days off battery power, it would run at well under 12v, I was worried about frying something then. Drove around with a spare battery in the back, had to swap them a few times.
    The chev cs144 I got was the wrong mounts, I would've had to change belts for it or the 12/6 mount, so I jut bought a Toyota 130a denso alt. Everything works great, 14.4v, re&re took an hour tops and I'm slow. I was super worried that the alt might not be bad, there was 12v to 2 of the 3 small alt harness wires and 10.5v to the other. New alt fixed everything, even the nonexistent battery light on the dash. It flashes up proper for a second on startup like it should. I think it's very strange that instead of the battery light coming on when the alr died, it just stopped working. Oh well, I got a better alternator out of the deal that can keep up with the lights and stereo- mine had 90a Bosch.
    Pigpen likes this.
