Alternator/Starter/Ground cable upgrades - Help scope out job
Discussion in '2nd Gen. Tacomas (2005-2015)' started by qnyla, Mar 22, 2014.
  1. Mar 22, 2014 at 11:33 AM
    qnyla
    qnyla [OP] Well-Known Member
    NM
    2006 & 2016 DCSB TRD Off Road 6-Speed
    I am getting ready to put a new Diehard Platinum Group 31M battery in my truck. Since the terminal locations will be a bit different, and the stock cables are very short, I want to upgrade my battery to alternator, starter and ground cables.
    I do not want to take it all apart before I actually order the cables and have them in hand, but I do want to sort out where all the connections are and how to get to them.
    The wiring is hidden in loom and insulators, so it is a bit hard to tell what is what. Please help me scope out the cables and ID them. If I have these ID'd wrong set me straight.
    Some photos taken while sticking the phone where the sun don't shine. :D
  2. Mar 22, 2014 at 2:17 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    I installed a G31 commercial battery with top threaded studs in my tacoma without lengthening the battery cables - only the 6ga power wire to the fuse block and the body ground cable needed to be longer, so I built new ones. If you want more info, I'll dig it up. If you're set on redoing all the cables, then I'm not much help. The hold-down can be easily modified with cheap oem parts to fit a G31 too.
    Go to a commercial truck shop in your area and get a price on a G31 "dual purpose" battery before you buy that Diehard, you'll be glad you did.
  3. Mar 22, 2014 at 2:25 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  4. Mar 22, 2014 at 2:31 PM
    transplant
    transplant resident know-nothing
    theo
    Crestline, Ca
    89 sr5, 99 OR, 11sport, 14 offroad
    honestly id just get 10-12ft of cable, and cut as i went, replacing the cable and tying it in as i went.
    isnt the chassis ground to the motor a cable weave going from the firewall to the aft-most part of the engine just above where the bell housing mounts? i wouldnt think that was necessary to upgrade or replace.
  5. Mar 22, 2014 at 4:22 PM
    qnyla
    NM
    landphil, I would appreciate any info or shots you have of the body ground and fuse block cable changes. If you have a shot of the G31 setup that would be cool too. My starter cable seems tight even with a G27F battery.
  6. Mar 22, 2014 at 4:24 PM
    qnyla
    NM
    Yes, I've done that before, but buying some pre-made marine-grade cables is pretty cheap and easy.
    I don't think so, not on a 2nd gen.
  7. Mar 22, 2014 at 6:21 PM
    landphil
    BC, Canada
    Tundra 5.7 mod
