Alternator upgrade or battery for winch?
Discussion in 'Recovery' started by WYO Taco 5, Aug 21, 2021.
  1. Aug 21, 2021 at 8:28 PM
    WYO Taco 5
    WYO Taco 5 [OP] New Member
    07 Tacoma Sport
    Adding the Warn semi hidden winch mount and the EVO VR 10 to my Tacoma soon. Anyone else with a similar setup recommend what kind of upgrades I would need as far as battery or alternator or both??
  2. Aug 22, 2021 at 7:15 AM
    willtill
    willtill Well-Known Member
    Maryland
    2018 Cement Off Road V6 Access cab
    I've added a Harbor Freight 12K Apex winch to my Tacoma. Still using the stock battery. As long as you leave the truck running while using the winch, you won't have an issue.
    Since you connect the winch directly to the battery, the winch will draw directly on the battery; not the alternator.
    When it is time to replace my battery, I'll upgrade to something more than the current 575 CCA's. For now, it's acceptable.
    WYO Taco 5[OP] likes this.
  3. Sep 6, 2021 at 9:03 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    As stated with the engine running as long as the charging system works like it should your fine.
    Then it is the charging system providing the output to the battery
    Even a dual battery set up with out doing the math will not last all that long with the engine not running or charging system not working.
    A high output alternator of course only works with the engine running .
