Alternator whine after timing belt replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by NWcamper, Dec 29, 2010.
  1. Dec 29, 2010 at 6:36 PM
    NWcamper
    NWcamper [OP] New Member
    Portland, OR
    '01 Tacoma 3.4L
    Dual Battery, Winch
    After having my timing belt replaced (as per 90k mile prescription) my factory alternator now whines like a little b**ch, mechanic says my dual battery setup is working it too hard. I had the extra battery w/ isolator and winch installed a few years ago and have never had a problem, but now that I dropped a bunch of cash to get my truck tuned up, it sounds messed up.
    Mechanic said the belt was loose before? Everything worked fine as it was...
    Anyway, any suggestions as to what my problem might be, or what I might do to fix it? Did this guy F something up?
    Anyone have a trusted mechanic for their toyota rig in Portland?
  2. Dec 29, 2010 at 6:40 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    i have semi the same problem. I had a badass mechanic do my timing belt, now sounds like my power steering whines, and it never did it before.
  3. Dec 29, 2010 at 7:52 PM
    tsab916
    tsab916 Well-Known Member
    Sacramento
    02 DC 4x4
    Belt might be too tight...putting alot of pressure on the alternator
  4. Dec 29, 2010 at 8:08 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Is it the original 90 amp alt? Or is it an high amp alt you added when you went to your dual bat setup?
    A squeak from power load (that's what I call the noise the alt makes when its working extra hard to catch up) is not a bearing noise. Besides, the system eventually does catch up and the "squeak" then goes away.
    You described the noise as a "whine", is it the bearing going bad? Big coincidence if it is. Is it a too tight belt putting pressure on the bearing? Easy enough to find out, loosen the belt a tad.
    Edit: I see it is the stock alt. I'd be quite surprised if the alt bearing was going bad with only 90K. Loosen the belt and see what happens.
  5. Dec 29, 2010 at 8:30 PM
    NWcamper
    Portland, OR
    '01 Tacoma 3.4L
    Dual Battery, Winch
    Thanks...over-tensioned belt seems like a good possibility, being the primary element changed between before and after, might as well give it a look...
