Alternator Whine
Discussion in 'Audio & Video' started by Dave P, Jun 27, 2017.
  1. Jun 27, 2017 at 4:14 PM
    Dave P
    Dave P [OP] Well-Known Member
    Dave
    Edmonton, Alberta
    2012 Trail Teams Pro TRD
    TRD Cat Back Exhaust TRD Shift Knob Side Step Bars Soft Tonneau Cover Pioneer AVIC 6000NEX Head Unit Focal PS 165 F 6.5" Speakers Color Matched Grill Retrofit Headlights by Ambiguous LED Fog Lights
    Hello all, sorry for the long winded post but this issue is driving me crazy.
    About a week ago I was driving down the highway and my amp driving my front speakers suddenly powered down and would not power back on despite having power running to the amp.
    I took it into a local car audio store and they could not figure out why it happened or what was wrong with the amp so they installed a new focal amp. As soon as they installed the new amp there was alternator whine coming from the front speakers. The car audio place ran a new power cable and installed a new ground (into chassis of truck). They ran their power cable through the same route as I had my previous one (drivers side kicker panel along floor to amp under driver seat).
    The took a look at my wiring job I had previously done on my head unit and cleaned it up a bit but could not find the source of the alternator whine.
    I double checked their ground and tried it in other locations and the sound persisted. When I unplug the RCAs from the amp the whine stops. When I plug them into the amp and disconnect them from the head unit the noise stops. The car audio place also replaced the RCAs once (I think they thought that was problem) but it didn't solve anything. RCAs are running through the middle console which is where I had them previously running with no issues.
    This would lead me to think that the issue is at the head unit (pioneer avic 6000NEX), but there were no issues before the new amp was installed so I'm not sure why there would be issues now.
    The car audio place told me that there was a fair amount of corrosion on my battery and that I should replace the battery and get someone to check out my power cables to make sure they aren't corroded.
    Has anyone had similar issues. Would it make sense for me to replace the battery etc if the whine stops when I unplug the RCAs from the amp? obviously I do not want to buy a new battery if it is not what is causing the issue.
    Thanks for the help!
  2. Jun 27, 2017 at 4:16 PM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    It isn't your battery...look elsewhere...sounds like the head unit or amp suffered some type of damage...
    For your battery corrosion, clean the corrosion, apply battery gel anti corrosion stuff and reassemble. I use the stuff religiously, it keeps corrosion away for sure....
  3. Jun 27, 2017 at 4:18 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Is your RCA ran right next to your power cable? That can cause whine.
  4. Jun 27, 2017 at 4:22 PM
    Rob Daman
    Rob Daman The Taco Formerly Known as Hard Shell Taco
    Rob
    So Cal
    17 OR 6MT
    a lot
    run it from another source like your phone using an adapter and see if the whine is there. that will either eliminate or confirm the HU is the issue.
  5. Jun 27, 2017 at 4:25 PM
    Dave P
    Dave
    Edmonton, Alberta
    the amp is brand new so it shouldn't be damaged, The RCA is running down the middle console and the power is at the drivers side door so they are not close. I will try running from my iPod and see what happens.
  6. Jun 27, 2017 at 4:39 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Check the alt output if one diode is bad it will still charge not full output but it will induce noise on the DC wiring.
  7. Jun 27, 2017 at 4:41 PM
    06RedComa
    06RedComa Well-Known Member
    06 4x4 DC Sport
    Kings, Camburg 1.25" UCAs, Dakar leafs, TRD exhaust, Grillcraft grille, All-Pro APEX Bumper, Kenwood DNX6960, Avid Sliders, SnugTop Rebel, 285/75/16 Hankook Dynapro atm
    Interested to find out what the cause is. I noticed a whine the other day after my battery died but went away after my battery got some power back in. Went to test the battery the next day and battery tested good but alternator came back as a fail. The guy that tested it said the 120+ temps were not helping either. Sorry to go off topic but maybe it's something in my audio system as well. Best of luck with the issue
  8. Jun 27, 2017 at 8:55 PM
    Dave P
    Dave
    Edmonton, Alberta
    Thanks for all the replies. After checking the ground at the head unit I decided to try running a second set of RCA cables from the deck over top of the centre console to the amp which solved the problem. When I took a look at where the car audio place had run the RCAs they installed it turns out they were being directly underneath and parallel to the power to the amp underneath the carpet under the seat. I relocated the RCAs away from the power and everything is all good now!
    timmaayyy likes this.
