alternator wonder
Discussion in '2nd Gen. Tacomas (2005-2015)' started by snowgod06, Oct 16, 2009.
  1. Oct 16, 2009 at 5:15 PM
    snowgod06
    snowgod06 [OP] UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    so i have out my stereo setup into my taco from my other rig. Since i drive my truck more. Question is whats the output/load rating on our alternators.
    im asking because ive fried 3 alternators in my other rig due to power drain and having my alternator running at 2/3 constant load(im assuming).
    So wondering if my total power from my stereo is 2200w, how much does that make the alternator work? And wondering if i need to perhaps either build one to handle the power load, or do you think i should be ok.
    thanks
  2. Oct 16, 2009 at 5:25 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Im thinking your maxing out the alt. The out put of the alternator is about 112 amps. or 1344 watts.
  3. Oct 16, 2009 at 5:31 PM
    snowgod06
    Rob
    06 Access Cab
    what would you recommend, building a tougher alt, or perhaps buying an aftermarket that could handle the power load. Not to mention my soon to be HID kit, rear lights, and box lights to add to the mix
  4. Oct 16, 2009 at 5:36 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    no i would get a capacitor and add it to your system
  5. Oct 16, 2009 at 5:38 PM
    snowgod06
    Rob
    06 Access Cab
    have had one since day one. Im running a 4 farad, but that still doesnt really affect anything, the alternator still has to work to keep the battery and the cap charged.
  6. Oct 16, 2009 at 5:41 PM
    DanGer
    ah well then i am out of advice
  7. Oct 16, 2009 at 6:34 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Yes, I would look to upgrade.
