Alu cab 3rd brake light issues.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Malibu**Ken69420, Dec 10, 2024.
  1. Dec 10, 2024 at 11:47 AM
    Malibu**Ken69420
    Malibu**Ken69420 [OP] New Member
    Hello,
    I have an alucab contour canopy. I have wired in my interior canopy lights and they operate normally. However, my 3rd brake light is on until I push on my brake pedal. The 3rd brake light on the canopy goes out when the brake is pushed.
    I tapped into the blue wire and the green wire on my passenger side. (Tapped into the middle light bulb as it is the brake light portion.
    Has anyone experienced this before?
    Should I have tapped the blue wire and the black and white wire?
    I looked at the aftermarket harnesses and they show the blue wire and black and white wire being used.
    If anyone has any advice, I would greatly appreciate it. I will be attempting to connect it to the black and white wire after work to see if that fixes it. Just thought I would ask. Maybe I am way of base.
    Thanks.
  2. Dec 10, 2024 at 12:21 PM
    eurowner
    eurowner Duke Sky
    Scoty
  3. Dec 10, 2024 at 1:00 PM
    Malibu**Ken69420
    I have had it for about 4 months.
    I did the install.
    I had a brake light bulb burn out and replaced it. I thought that may correct the new issue of brake light not working when foot is on the brake pedal. But it didn't work.
    My oem tacoma brake lights work fine, and all other functions work fine. It is just the 3rd brake light that is illuminated when brake is not being used. Then when pressed it goes out.
    Not sure if the answer is in the link you shared. It's 68 pages long.
    Edit: found it. Thanks!
    Thanks
  4. Dec 10, 2024 at 1:18 PM
    MR E30
    MR E30 Well-Known Member
    Michael
    Wherever it's parked
    2021 Silver TRD OR DCLB w/ AluCab and All the Mods
    Yes, you need to tap into the blue and black and white wire, shown not-connected-yet, in the photo below. This is drivers side, and I have the aftermarket harness, but you get the idea.
    [​IMG]More Install by Michael Rickerd, on Flickr
    The Alu-Cab 3rd brake light only illuminates when the pedal is pressed, when installed correctly. It is never on otherwise.
  5. Dec 10, 2024 at 3:49 PM
    Malibu**Ken69420
    Thank you! I just ran out and got it set to the black and white. Everything is running great!
    eurowner and MR E30 like this.
  6. Dec 10, 2024 at 5:59 PM
    Malibu**Ken69420
    ^This harness looks really nice. Is this purchasable still online? (No worries if you don't know.)
    Thanks.
    MR E30[QUOTED] likes this.
  7. Dec 12, 2024 at 11:42 AM
    jonvan
    jonvan Well-Known Member
    Jon
    Bath, PA
    21' DCSB, Past- 10' ACLB, 03' RCSB
