Aluminum “Sliders”
Discussion in 'Armor' started by parel, Jul 3, 2021.
  1. Oct 31, 2021 at 10:20 PM
    Glueman
    Glueman Yersinia pestis
    Utah
    The Plague....
    6 inch Douche Bag lift...what else do I need?
    Aluminum doesn't "slide" over rocks. It gouges and sticks. Steel is real......
  2. Nov 1, 2021 at 8:42 AM
    parel
    parel [OP] Well-Known Member
    Kin
    Calgary, AB
    (ex. 2014 Black Tacoma TRD)
    OEM FJ TRIBUTE EDITION (REPLICA)
    I got the Greenlane’s installed now. (AC no kick) Very light. However, I got mine in 0degree angle and with how smooth the top surface is my foot shoots off easily. I wish I had got 5-10* of angle on them and no top sheet. They look good but I think angled would have given it a better look and more clearance. Also without a top sheet my foot wouldn’t skeet off because I could press into the tube. Anyways I’ll probably keep them unless greenlane would make them customized.
    Marcgb91 likes this.
  3. Nov 1, 2021 at 8:52 AM
    Marcgb91
    Marcgb91 Well-Known Member
    Marc
    Comox, BC
    18' Tacoma OR
    Bumpers: -Kalil Fab prerunner -C4Fab RockRunner single tube - Inbound -CBI sliders Wrap: -Kpmf Gloss Opulent Indigo w/Avery satin silver Lights: Baja Designs - Squadron Sport Wide Cornering Foglights - S2 reverse kit - S8 30" amber combo Tires & Wheels: -Ffifteen52 Turbomac HD Classic 16x8 +0mm -Spidertrax 1.25" spacers -Falkentire Wildpeak AT3W LT315/75/16 Suspension: King shocks : Front 2.5 extended w/resi, Rear 2.5x12" shock w/external resi JD Fab: UCA double shear kit, Spindle gussets, LCA pivot kit, Nylon rack bushing, Billet heimed tie rods (stock width) -Dirt King UCA w/poly greasable bushings -Icon RXT leaf pack - option 3 -Archive Garage Shock relocation kit, U-Bolt flip kit & bump stop upgrade, Hammer Hangers RTT & Awning: Prinsu roof rack Overlandrec Upper Hutt & 23Zero Pellegrin 180°
    Thanks for the feedback! I guess you had them powdercoated w/o a texture to it?
    I've heard lots of people slapping on some skateboard grip tape on the main tubing or atleast by the kick out so their feet don't slide off as easy! Maybe a quick fix for you?
  4. Nov 1, 2021 at 9:55 AM
    OmahTako
    OmahTako Well-Known Member
    SoCal
    Tacoma-1ea. Tundra-1ea.
    So this theory applies to skid plates as well?
  5. Nov 1, 2021 at 1:55 PM
    Glueman
    Utah
    The Plague....
    Yes.
  6. Nov 1, 2021 at 2:35 PM
    parel
    Kin
    Calgary, AB
    I got them factory powder texture coated. With the addition of the top plate theres just nothing to bite your foot or toes into. They might get full grip tape to cover the entire top. Such a waste though...
    Marcgb91[QUOTED] likes this.
  7. Nov 1, 2021 at 3:06 PM
    ODSC1
    ODSC1 Well-Known Member
    London ON
    2017 DCSB Sport MT
    How would you get Greenlane to customize them? I'll be ordering a angled set when they have their Black Friday sale. I want them unpainted and without the step plates. I'll coat them with some type of bed liner.
  8. Nov 1, 2021 at 3:07 PM
    OmahTako
    SoCal
    Interesting. My aluminum skid plates work perfect. My sliders are steel and they’ve got gouges in them as well.
  9. Nov 1, 2021 at 4:00 PM
    Glueman
    Utah
    The Plague....
    Aluminum is much softer than steel. It will deform and gouge much easier and in affect create a higher friction coefficient. I'm sure your skids and sliders will work fine....and weigh much less.
    OmahTako[QUOTED] likes this.
  10. Nov 1, 2021 at 8:46 PM
    angerbot
    angerbot Well-Known Member
    Definitely could do it in a pinch, wouldn’t want to make a habit of it though
  11. Nov 2, 2021 at 1:27 PM
    parel
    Kin
    Calgary, AB
    I would get the angled option on my straight sliders with no kick out. Probably 6* and no top plate. 12.5* might look good too. Just wish I could have seen them before installing.
    ODSC1[QUOTED] likes this.
  12. Sep 8, 2022 at 5:52 AM
    TS4x4
    TS4x4 Well-Known Member
    2018 TRD Offroad
    Hey OP, I'm looking into these and was wondering what your take is after having them for a bit? Also is the powder coat worth it? $150 seems steep for something that people are saying is slippery, so I'm wondering if I'm better off just going bare and then bedliner.
  13. Sep 8, 2022 at 6:21 AM
    su.b.rat
    su.b.rat broken truck
    i think the best alternative to these would be SDHQ chromemoly sliders... strong AF and 50lbs lighter than other steel options. i have them, total 100lbs with hardware. they're expensive though.
  14. Sep 8, 2022 at 9:56 AM
    Raijin822
    Raijin822 Well-Known Member
    Canada
    2021 TRD OR
    I went with steel sliders, glad I did too. Didn't see a big rock as I was cresting a hill, went over it and dropped full weight down on it. Steel sliders had a big dent in it but it saved my driver door and fender. Aluminum would have probably not survived it and possibly done more damage.
    Steel is easy to touch up as well, just buff out the scratches and loose paint with a steel wheel and then sprayed it with black paint.
    Imo steel for sliders and aluminum for bumpers are the way i'd go
    Junkhead and su.b.rat like this.
  15. Sep 10, 2022 at 7:29 PM
    #35
    guest_707
    guest_707 Well-Known Member
    Honestly, I was surprised that the Tacoma was about the same if not slightly lighter than some mid-size SUVs. The G. Cherokee can get up to 5k+ but I think that's the V8 versions. I guess an empty bed basically means no weight in the rear so less weight overall?
  16. Sep 26, 2022 at 6:58 PM
    #36
    trail_limo_project_
    trail_limo_project_ Active Member
    Ren
    Oahu, HI
    1999 Pre-Runner & 2018 TRD Off-Road DCLB
    @TS4x4 I've had mine for about a year now and opted for the factory powder coat option which looks great but yes, it can get slippery but it doesn't bother me enough to add grip tape to the top surface. I chose alum. sliders over steel for the weight savings & marginal protection.. not much rock crawling here in Hawaii for me to really be concerned.
    TS4x4 likes this.
  17. Sep 27, 2022 at 3:00 AM
    #37
    TS4x4
    2018 TRD Offroad
    Appreciate the feedback! Mine should arrive this week, I'm stoked. I live in the Northeast so my steel step bars didn't make it more than 3 years before disintegrating due to rust from road salt. I simply can't do steel up here.
  18. Sep 29, 2022 at 7:12 AM
    #38
    McGillz
    McGillz “It’s not accessorizing... It’s a BUILD!”
    New Jersey
    '19 TRD Sport Barcelona Red
    KMC Grenade wheels / BFG KO2 305/65/17 E rated, ECGS clamshell bushing, CMC, ARB Old Man Emu 2.5" lift- ARB 90000 OME Nitrocharger Sport Strut, ARB OME - 2886 Coil Springs (heavy), ARB OME Leaf Springs - EL111R (medium), SPC Specialty Products Upper Control Arms, Retrax One XR Tonneau Cover, Rhino Rack Vortex rails, Rago Fabrication Bed Stiffener, Tacomabeast- Spyder headlights /sequential LED DRL, Rigid driving/fog lightbar, RCI steel Skid Plate, Fab Fours Vengeance front bumper- High Pre Runner Guard, Fab Fours rear bumper, MillerCAT stainless Cat Shield, FEND-X wheel liners, Protec splash guards, Bushwhacker flares (Rhinoliner painted). For now…. Wife cut me off!!!
    Aluminum is light and soft but not the strongest. Steel with a good powdercoat is the way to go if you really want that type of protection. unfortunately salt kills everything and you'll have to pull them off and have them recoated every couple of years. That's the same for anything you put on your truck in states that use salt. NJ changed to a brine that doesn't seem to do as much damage. Time will tell.....
