Aluminum Camper Shell
Discussion in 'Tonneau Covers, Caps and Shells' started by Pjf1119, Nov 7, 2016.
  1. Jan 18, 2023 at 4:08 PM
    #261
    Kahpo
    Kahpo Well-Known Member
    Pacific Northwest
    96 extended cab 4x4 2021 TRD OR Access cab AG
    My plan A was a Tradesman but as they closed up shop I am now going with plan B which is a ARE DCU.
    Trying to decide if I want a 26-34 wedge with the ARE rack or a 29” ARE DCU Max with the thicker skin and Yakima tracks.
    I plan on mounting some brand of 270 Awning on the passenger side and a water shower on the other side of the rack.
    For those of you that have one do you like the ARE installed rack or would you have preferred something like Yakima tracks?
    If you have the wedge, would you do it again? Other than possibly less MPG loss and it looks cool is there any advantage of a wedge over a none wedge.
  2. Jan 18, 2023 at 4:36 PM
    #262
    Phessor
    Phessor Well-Known Member
    I cannot speak for a factory rack, as mine did not come with one. I installed some track on mine to allow custom tie down and rack needs.
    The wedge has worked out great for looks and having an angled surface for my solar panel.
    As far as mileage, it has never been a concern. Having a Prinsu roof rack I could have gone with a non wedge style and gained a little more headroom up front.
    I mounted an OVS Nomadic 270, but just for an added bit of security I am going to fabricate a front mount.
  3. Jan 21, 2023 at 5:00 PM
    #263
    Kahpo
    Pacific Northwest
    Thank you for the answer; your build and @bodean are the two I was looking at. Decided I am gong to order a paint matched 26" - 32" wedges with some extra plating for roof tracks on the back flat part of the wedge.
    Phessor[QUOTED] likes this.
  4. Jan 21, 2023 at 5:16 PM
    #264
    chrslefty
    chrslefty Well-Known Member
    chris
    Mesa az
    01 trd
    Stockish
    The factory rack is ok but I'd rather have had a more traditional type of rack. It's just a little more challenging to mount stuff too.
    The non wedge kinda acts like a sail especially if it's up high but the room is nice.
    Kahpo likes this.
  5. Feb 24, 2023 at 5:10 PM
    #265
    1madmnky
    1madmnky Well-Known Member
    Tony
    Kansas via Fullerton 714
    2010 Tacoma 4X4 DCLB
    Hella Supertones
    Just wanting to get a Decked and an awning.
  6. Feb 24, 2023 at 5:13 PM
    #266
    Papa Taco
    Papa Taco HARD CAAAAAAARRRRRRRL
    Jared
    Socal
    2011 Access Cab 4x4 6 Speed
    Follow the yellow brick road
    Siiick shell from a fellow Fullertonian
    1madmnky likes this.
  7. Feb 24, 2023 at 5:26 PM
    #267
    Papa Taco
    Jared
    Socal
    Here’s mine
    Ngneer, YotaBro, Canadian Joe and 3 others like this.
  8. Feb 24, 2023 at 9:58 PM
    #268
    Papa Taco
    Jared
    Socal
    I need to add lights. I love how your interior looks
  9. Feb 25, 2023 at 11:00 AM
    #269
    1madmnky
    Tony
    Hella Supertones
    Amazon, I don't have the link but it was "12v 120 LEDs Van Interior Lights..."
  10. Mar 11, 2023 at 1:49 PM
    #270
    mattehww
    mattehww Well-Known Member
    Minneapolis, MN
    2018 SR5 Access Cab 4x4
    Love this thread and really leaning towards a 23-29" DCU wedge at this point. I've got some questions for the folks that have a side tool box. Namely about how deep does it protrude into the bed, and are you still able to sleep two in the bed somewhat comfortably? Also are they generally welded/riveted in, or bolted and easily removable? I really want to have some extra storage that is easily reachable without having to get into any platform drawers, but could live without it if it means you can't really sleep 2 people in the back anymore..
    Ngneer likes this.
  11. Mar 11, 2023 at 2:19 PM
    #271
    Ayoung208
    Ayoung208 Member
    Andrew
    2010 Tacoma TRD Sport DCLB
    I purchased a Swisscaps aluminum shell used. I assume they are very similar construction to the ARE’s but they very well may differ. The tool box was riveted into the roof and then screwed down the sides with sheet metal screws. It was easy to remove the screws and it was easy to drill out the rivits along the top but here’s the kicker.. the bottom panel of the box was riveted to the frame and was sandwiched between the frame and the base panel (the sheet of aluminum that contacts the bed rails). I couldn’t remove these rivits without the whole shell coming apart basically. I solved this problem by cutting the bottom panel flush against the frame using an angle grinder. Turned out great but you have to be careful with the angle grinder since it cuts through aluminum like butter and could easily bite into the frame. I was happy to have it gone since the tool box blocks off access to rest of the bed from that side. I don’t sleep in the bed and I like to access the bed from both side panels. I still have the box laying around and could give you the depth another time soon.
    Also it may have been a good idea to cut the box out with just a hacksaw to avoid potential damage.
    Ngneer and mattehww[QUOTED] like this.
  12. Mar 11, 2023 at 2:39 PM
    #272
    Ayoung208
    Ayoung208 Member
    Andrew
    Box depth on my Swisscaps is 10” from the inside of the frame.
    And just to add my 2 cents on the box: it’s nice storage. I liked it but the fact that it blocked access to the rest of the bed made it a deal breaker for me. I can’t reach all the way across the bed from one side.
    Also I think the 23-29” Wedge is a winner for sure. My shell is 23” flat roof and it is just too short to sit up in on a bed frame set at the height of the wheel wells.
    mattehww likes this.
  13. Apr 5, 2023 at 9:26 AM
    #273
    chrslefty
    chris
    Mesa az
    01 trd
    Stockish
    Has anyone seen or found a way to change out the folding T-handle for the side doors ? I'd like to have a locking mechanism that I can open from the inside,and have a lift handel similar to a car door on the outside. I think super pacific campers have that type of handel. It would be nice to close up the camper and not be locked inside.
    T-handel.
    Super pacific handel
    Ngneer, Road Bull, 1madmnky and 2 others like this.
  14. Apr 5, 2023 at 10:21 AM
    #274
    Phessor
    What he said
    Ngneer likes this.
  15. Apr 5, 2023 at 12:05 PM
    #275
    1madmnky
    Tony
    Hella Supertones
    Yup
    Ngneer likes this.
  16. Apr 5, 2023 at 12:47 PM
    #276
    chrslefty
    chris
    Mesa az
    01 trd
    Stockish
    Well this is what I've found so far.
    It's called a rotary paddle handle.
    I've seen some slam shut ones but I think the lock/mechanism is orientated wrong.
    I found this one but couldn't find any more info.
  17. Apr 5, 2023 at 12:54 PM
    #277
    chrslefty
    chris
    Mesa az
    01 trd
    Stockish
  18. Apr 6, 2023 at 6:38 AM
    #278
    EricGinTX
    EricGinTX Member
    Houston, TX
    That latch from McMaster would be cool if you can get it to work. I'll be building a DCU also, so I'm interested in how this works out.
    As far as the regular T handle latches they come with... I saw somewhere a guy cut the T down so it could still be rotated without hitting the cup and stopping the unlock rotation. I guess he just pushed the locking bars from the inside to unlock it.
    chrslefty[QUOTED] likes this.
  19. Apr 26, 2023 at 10:10 PM
    #279
    jet123
    jet123 Well-Known Member
    Ft Collins
    2013 DCLB
    Work in progress...
    Ngneer, Canadian Joe, Kahpo and 2 others like this.
  20. May 13, 2023 at 10:00 AM
    #280
    Kahpo
    Pacific Northwest
    Got mine at last only had to wait 3 Months for it. IMG_1943.jpg IMG_1947.jpg IMG_1946.jpg
    Ngneer, djm68, Naveronski and 8 others like this.
