Aluminum camper shells
Discussion in 'Tonneau Covers, Caps and Shells' started by petyanca, Apr 12, 2011.
  1. Apr 12, 2011 at 8:41 PM
    petyanca
    petyanca [OP] Well-Known Member
    bay area
    09 AC 4cyl 4x4 5spd
    I went to check out some aluminum camper shells the other day, and found them to be very light - may be about 40 lbs. Has anybody had an aluminum camper shell and what are the impressions ? Appreciate any input.
  2. Apr 12, 2011 at 8:56 PM
    TimRD OffRoad
    TimRD OffRoad Well-Known Member
    Tim
    NC
    05 DC Off Road 4x4
    King Coil Overs, Add-A-Leaf, Custom tube rear bumper
    sounds interesting. how much an aluminum shell run?
  3. Apr 12, 2011 at 9:00 PM
    petyanca
    bay area
    09 AC 4cyl 4x4 5spd
    1K OTD installed with some options like sliding side windows and carpeted headliner.
  4. Apr 12, 2011 at 9:00 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    First hand, they fly off real well once the connections fatigue.I seen 2 fly off , one from the truck and another on someone elses truck going down the freeway. I'm glad no one was behind us. That was a different truck, but still.
    I dont dislike them, but they just dont look good on modern trucks imo.Along with leases and plastic insert bedliners , aluminum canopies are another thing i'll never do again.
  5. Apr 12, 2011 at 9:11 PM
    petyanca
    bay area
    09 AC 4cyl 4x4 5spd
    I guess its a consequence of their light weight so aerodynamically they pull up onto the connection points a bit harder than pretty hefty fiberglass ones. I think it can be worked out.
  6. Apr 12, 2011 at 9:19 PM
    Tacoyota
    08 4wd
    The commercial aluminum ones are good, I just never seen one with windows.
    The budget ones I suspect you are refering to, those ones scare me. For a better idea what it did, it lasted 4-5 years, never offroaded,no rack, but saw gravel roads on a 1/2 ton truck.One day coming back from deer hunting, going 45mph on a paved road, it decided to seperate and flew off , skidded and went in the ditch.
  7. Apr 12, 2011 at 9:23 PM
    petyanca
    bay area
    09 AC 4cyl 4x4 5spd
  8. Apr 12, 2011 at 9:29 PM
    Tacoyota
    08 4wd
    i'm not familiar with them,but they ought to do fine, but i'm basing that on being commercial. Ask them about putting ,say, 4 ladders on a rack on it. If it holds 150lb or so,and they warantee it , it should be ok.
