Aluminum Falcon's Bird Trd rebuild
Discussion in '2nd Gen. Builds (2005-2015)' started by Btnewman, Aug 10, 2011.
  1. Jun 7, 2013 at 8:26 PM
    #161
    Btnewman
    Btnewman [OP] Benjamin Newman
    Benjamin
    Grand Junction co
    Uh. It's beat to he//. But it's only 1 owner.
    Custom body work/damage ARB rear locker Bumpers Shocks Other parts Tires and Rims Air tank fully plumbed into truck "Golf ball mod"
    Holy geez! Maybe look at some load bearing shocks like some air shocks or ori's or sumpin!
  2. Jun 7, 2013 at 8:28 PM
    #162
    BradyT88
    BradyT88 Well-Known Member
    Load bearing shocks huh? Never heard of them. Maybe some long travel airbags. Haha
  3. Jun 7, 2013 at 8:29 PM
    #163
    Btnewman
    Benjamin
    Grand Junction co
    Look at fox air shocks.
  4. Jun 7, 2013 at 8:29 PM
    #164
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    LS Swap 500 hp......
    I was thinking maybe some ori's wouldnt be a half bad idea
  5. Jun 7, 2013 at 8:31 PM
    #165
    Btnewman
    Benjamin
    Grand Junction co
    And I think the springs are eibachs, they are the toytec 5100 setups. And this weekend they are getting dropped a notch
  6. Jun 7, 2013 at 8:50 PM
    #166
    Btnewman
    Benjamin
    Grand Junction co
    In the long term I want to run a set spring such as a coil over, along side with an adjustable shock like an air shock. Just to be able to adjust ride height for either street, desert, or rock crawling
  7. Jun 9, 2013 at 10:42 AM
    #167
    Btnewman
    Benjamin
    Grand Junction co
  8. Jun 9, 2013 at 11:46 AM
    #168
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    Lol. ....
    I guess I shouldnt laugh I may need rear air bags for the time being until I hash out whats going to happen with my truck
  9. Jun 9, 2013 at 11:51 AM
    #169
    BradyT88
  10. Jun 9, 2013 at 11:57 AM
    #170
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Call me an idiot...but I'm a bit confused why you need air bags in the front. Purely for height adjustment? I would think you should have the correct spring and shock to hold the weight f the truck
    I have always been told you don't want to run air bags on an off road truck, the harsh suspension movement and constant flex and compression can damage them
  11. Jun 9, 2013 at 12:00 PM
    #171
    BradyT88
    Depending on how much adjustment you have, you could give yourself more ground clearance for rock crawling and then lower it down for better center of gravity while playing in the whoops, all without affecting your suspension ride very much, if at all.
    Yeah, the airbags might wear out after a while. Just depends on how often you abuse them and how tough they are as to how long they may last.
  12. Jun 9, 2013 at 12:02 PM
    #172
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    Im going to sit down with a fab shop tomorrow put the truck on a lift and we are going to come up with a game plan
  13. Jun 9, 2013 at 12:03 PM
    #173
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    Ill have it set up to take them out fairly quickly, didnt you see how fast I had leafs swapped
  14. Jun 9, 2013 at 3:48 PM
    #174
    Milota95
    Milota95 Mall Crawling Specialist
    Qrampage
    B.F.E
    97 SX Single Cab V6 ~ 95.5 SX Single Cab 4c ~ 81 Pickup
    Driven Safely
    what is the thing sticking up on the back? id it to hold a go pro?
  15. Jun 9, 2013 at 6:33 PM
    #175
    BradyT88
    Yep!:cool:
  16. Jun 9, 2013 at 9:53 PM
    #176
    Btnewman
    Benjamin
    Grand Junction co
    I have wondered about doing an airbag with a shackle kind if like the teraflex revolver shackle but without the the ability rotate. Just the pivot that would allow the bag to droop with the suspension but when at normal ride height it would be in contact and giving added springiness. You would just have to have limit straps on the airbag part to avoid over extending the bags.
  17. Jun 9, 2013 at 10:01 PM
    #177
    Btnewman
    Benjamin
    Grand Junction co
    I would like to run the bags in combo with a "normal" suspension setup just to allow the ability to adjust height on the fly. In the long run I want to be running an lt center diff front end with a watts link/canti in the rear. But where most of my time is spent on highway I want to be able to keep my truck at a neutral height for streetability and less stress on my cvs and universals. But as soon as I hit the trail head I can enter crawl mode and lift it on the fly. And as far as offroadability of air bags, I guess I will just have to put some to the test...
  18. Jun 9, 2013 at 10:11 PM
    #178
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    yea see that makes perfect sense. as long as the truck is strapped or limited to the bag's max droop (for the rear) i think it would be fine. but it's the go fast shit that would tear them up. but like you said...time to test eh?
  19. Jun 9, 2013 at 10:28 PM
    #179
    Btnewman
    Benjamin
    Grand Junction co
    Now I just need an invenstor. ...
  20. Jun 9, 2013 at 11:02 PM
    #180
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Ben, based in your needs, you are a perfect candidate for ORI's. I wouldn't mess with bags at all. Just do the ORI's and never look back.
