Aluminum iPhone mount for off-road & daily use
Discussion in 'Group Buys' started by MobArmor, Sep 10, 2014.
Thread Status:
Not open for further replies.
  1. Sep 10, 2014 at 4:41 PM
    MobArmor
    MobArmor [OP] Well-Known Member
    Joel
    San Luis Obispo
    2012 sport LT
    full Dirt Designs long travel. Big tires small shocks lots of fun
    Hello all!
    Joel here from Mob Armor, we are opening a group buy to the good people of TW.
    We have the blessing of TCBob and with enough traction Mob Armor will gain vendor status on here which would be an awesome step for my little company. Check out mobarmor.com for more info.
    The group buy will run from 9/10/14 - 9/28/14
    GROUP BUY CLOSED
    -The Mob Mount is a U.S.A. made aluminum phone mount:oldglory: I designed the mount because I was sick of losing my phone all over the cab of my Tacoma when I was off road.
    -It works by a slide clamping phones with or without a case securely into its aluminum arms and then attaching by magnet to a steel disc on your dash. The steel mounting disc uses a high bond non permanent 3M VHB to attach to any flat surface. This stuff is the same adhesive GoPro uses for their sticky mounts, its very, very strong and doesn't leave a trace if you want to remove it later. The Mount has a tilt and swivel housing that is easy to use and can orient the phone to many viewing angles for you or your passengers to use with no set screws. The Mount will allow full access to all data jacks, buttons, speakers, and is very easy to use. Your phone can be installed in seconds and removed even faster for daily driver use.
    -It can easily be pulled off the mounting disc to take a call (NOT WHILE DRIVING ON PUBLIC ROADS:rolleyes:), change GPS directions, etc. When you are done, just aim and stick it back to the steel mount disc.
    -The Mob mount will work for iPhone 3G - 5S with just about every case on the market that is popular. Lifeproof, Otterbox, soft cases, bumper cases, plastic shell cases etc. It has worked for Samsung S3 and S4 and will work for many smart phones similar size to the iPhone 5.
    -It WILL work for the new iPhone 6 but with no case. We are in production of a larger mount that will work for Samsung S5, Note 3, HTC M8, iPhone 6 with any case, iPhone 6 Plus, and many other larger phablet type phones.
    The mounts include
    (1) Mob Mount in Red, Blue or Black.
    (1) Instruction kit
    (2) Steel Mount Disc
    We also sell them for Mountain bikes, road bikes, street bikes, dirt bikes, anything with a 1.5" or less tube.
    These mounts have been desiged and tested using my Tacoma, many of you may have seen it. These things are very strong when mounted.. Desert tested, Dune tested, they do not fall off your dash. :thumbsup:
    Biscuits likes this.
  2. Sep 10, 2014 at 4:45 PM
    Aw9d
    Aw9d That one guy
    If anyone was wondering about what phones work with it I found this on their site.
    Phone Fit-guide
    Phones and Cases compatible with Mob Mount
    iPhone 3G & 3Gs with bumper cases, soft cases, OtterBox Defender.
    iPhone 4 & 4S with bumper cases, soft cases, OtterBox Defender & Commuter, LifeProof.
    iPhone 5, 5C, & 5S with bumper cases, soft cases, OtterBox Defender & Commuter, LifeProof.
    Phones that are compatible Mob Mount without case.
    Samsung S3*, S4*
    LG G2 *
    LG Nexus 5*
    HTC One M7 *
    HTC One X *
    (*) Use of a case may render your device non-compatible.
    New Large Mount Coming Soon. Supports these devices:
    Samsung Note 2 and 3
    Sony Xperia
    Samsung S5 Active
    S5
    I'm hoping the large cases support Note 2/3/4 sized phones.
  3. Sep 10, 2014 at 4:47 PM
    MobArmor
    Joel
    San Luis Obispo
    2012 sport LT
    Awesome post! Thank you for grabbing that from out site. It will help people for sure.
    The large Mob Mount will definitely work for Note 2-4 and was solidworks tested to make sure we allow the biggest of cases (Otterbox) for the note 3.
  4. Sep 10, 2014 at 4:56 PM
    tcBob
    tcBob Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
    Nexus 4?
  5. Sep 10, 2014 at 5:00 PM
    Aw9d
    Aw9d That one guy
    Can't wait for the large mount to come out!
  6. Sep 10, 2014 at 5:03 PM
    MobArmor
    Joel
    San Luis Obispo
    2012 sport LT
    Nexus 4 will work and should work with a slim case. Otterbox case on nexus 4 is too large. It would work in the Mob Mount large that is coming soon.
    @TCbob,
    I have a pictures of the iPad mount in my tacoma to PM you, I will get that to you tonight.
  7. Sep 10, 2014 at 9:10 PM
    lawless
    lawless the rent is too damn high
    Lawson
    San Jose, CA
    2012 dcsb mgm sc
    sub'd to lurk and ponder...
  8. Sep 11, 2014 at 2:54 AM
    Darryle
    Darryle It is just a truck
    Darryle
    Weatherford, Texas
    I am in if you can confirm the HTC One with Otterbox, I can get you exact dimensions with calipers if need be.
    Edit:
    Width 3.040"
    Height 5.740"
    Thickness .700"
    1. Darryle : Black Version
  9. Sep 11, 2014 at 4:16 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
  10. Sep 11, 2014 at 4:41 AM
    Jpike
    Jpike Active Member
    Nh
    2014 trd off road
    I'd like a black mount pls!
  11. Sep 11, 2014 at 12:25 PM
    MobArmor
    Joel
    San Luis Obispo
    2012 sport LT
    So stoked you busted out the caliper to check, not many of our customers have given us that kind of dimensions of their phone.
    The max range of the mount we have to offer for this group buy is about 5.44" in length, unfortunately! I designed the mount around my iPhone 5S in the Lifeproof case which measure to about 5.4" (138mm)
    We will likely run this same exact group buy with the larger mount when it is out of production in late September/Early October.
  12. Sep 11, 2014 at 12:29 PM
    MobArmor
    Joel
    San Luis Obispo
    2012 sport LT
    Also, This is often over looked.
    These mounts are incredibly useful when working on your truck, working in the shop, driving a tractor, cooking,... on and on.
    The magnet on the bottom of the mount is a 15lb pull so it is quite strong considering the whole weight of the mount with the phone installed is far less than a 1/2 lb.
    I use mine when I am running my buddies CNC plasma table to keep my phone up off the shop tables. I also use it frequently when I am working on my truck, its legit to have TW on my phone and get the info I need hands free when I am wrenching under my truck.
    These are not just for off-road use, I use mine every day for commuting, running errands and much more.
  13. Sep 11, 2014 at 12:58 PM
    Roguestatus1688
    Roguestatus1688 Well-Known Member
    Bay Area
    2000 4Runner
    I will for sure be interested in the mount for the iphone 6 as I will be snagging that up
  14. Sep 11, 2014 at 2:06 PM
    MobArmor
    Joel
    San Luis Obispo
    2012 sport LT
    Are going to grab iPhone 6 or the 6 plus?
    The 6 plus is massive. lol
  15. Sep 11, 2014 at 2:13 PM
    samiam
    samiam Always here, never there
    Sam
    Stinky Vegas
    2008 TRD OR DCSB 4.0 6MT 1E7 Alu Cab
    Workin' on Workin' on it
    I`ll be watching for the Galaxy S5 mount. I don`t like the Ram X-Grip that I use now.
  16. Sep 11, 2014 at 2:23 PM
    Darryle
    Darryle
    Weatherford, Texas
    Disappointed, but will be waiting on the next GB
  17. Sep 11, 2014 at 2:27 PM
    MobArmor
    Joel
    San Luis Obispo
    2012 sport LT
    Awesome, I will definitely keep all the Samsung guys updated.
    Ram mounts are...:rolleyes: I'll keep my thoughts to myself.
    We manufacture our mounts in San Luis Obispo, USA. The quality is much much greater than many other Chinese mounts that are shipped over here and sold for pennies on the dollar.
    Edit.
    Ram literally makes a mount for everything, we can't beat them at that we are a pretty small time operation.
  18. Sep 11, 2014 at 2:28 PM
    Aw9d
    Aw9d That one guy
    I like my Ram Mount because someone doesn't on here doesn't make a mount for larger sized phones ;)
  19. Sep 11, 2014 at 2:28 PM
    MobArmor
    Joel
    San Luis Obispo
    2012 sport LT
    Sorry to disappoint! We have had a huge demand for the larger mount and are literally pushing production as fast as possible.
  20. Sep 11, 2014 at 2:29 PM
    MobArmor
    Joel
    San Luis Obispo
    2012 sport LT
    coming soon ;)
Thread Status:
