$25 Aluminum KC Cyclone Pods, Complete Bolt On for both V1 and V2 Lights
Discussion in 'Buy / Sell / Trade - Other' started by Grossomotto, Jun 16, 2021.
  1. Jun 16, 2021 at 7:51 PM
    Grossomotto
    Grossomotto [OP] Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Note, these work with both version V1 and V2 Cyclone lights.
    I've made these Aluminum pods that hold a KC Cyclone light, they bolt on to anything. They're complete with hardware and middle plastic plug. Etch primered and painted satin black that feels and looks just like powdercoat.
    You'll need the Cyclone light and two 3/8" holes that are 3/4" apart center to center for the supplied middle bolt/nut and wires.
    They come in four versions:
    0 degrees flat, mount to any 90 degree surface, they face straight out.
    22.5 degrees, the same angle as the cab so you can mount to a bed rack and they point straight out.
    30 degree for more angle down
    45 degree for the most angle used on a Victory front plate of a roof rack or a bed rack with up to 45 angle.
    $25 each and $10 flat rate shipping any amount you buy. Depending on stock, they can take about five days to make (primer/paint takes 3 full days). PM me for payment, thanks.
    Also, they work with the new Cyclone V2 light (V1 and V2 are the exact same dimensions)
    EnBoo, MY50cal, NoOne and 3 others like this.
  2. Jun 16, 2021 at 11:35 PM
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    Followed your other thread. I’ll be needing some soon so following here too
    Grossomotto[OP] likes this.
  3. Jun 17, 2021 at 5:44 PM
    ktmrdr
    ktmrdr Well-Known Member
    What a great idea. These will be popular.
  4. Jun 18, 2021 at 7:29 AM
    Phoosa
    Phoosa I never saw nothing.
    Truck
    07taco likes this.
  5. Jun 19, 2021 at 7:44 AM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Did you mean 1/4" here? 3/4" seems rather large.
  6. Jun 19, 2021 at 8:15 AM
    Grossomotto
    2017 4WDV6LB6MT
    Actually, both holes should be 3/8" and then 3/4" apart center to center. I'll have to clear that up in the first post.
    Bertw192[QUOTED] likes this.
  7. Jun 19, 2021 at 1:07 PM
    Grossomotto
    2017 4WDV6LB6MT
    So anyone ordering these for Cyclones keep in mind the frontside is 2.5" wide and the backside opens up like an oval when it's cut. Something to keep in mind when mounting these, especially to the side of a roof rack.
    Up to 30 degree to 3" wide
    45 degrees 3.5" wide
  8. Jun 22, 2021 at 10:20 AM
    Grossomotto
    2017 4WDV6LB6MT
    I'm also considering making aluminum pods for VLED puddle lights that will be attached to a plate, 2, 3 and 4 pod versions. Flat, 15, 30 or 45 degrees. The pic shows 15 degree angles. I'll get more pics with the actual VLEDs in them.
    malburg114 likes this.
  9. Jul 18, 2021 at 7:06 PM
    Grossomotto
    2017 4WDV6LB6MT
    Here's an owner who put my aluminum pods/kc cylones on his roof rack. 3000+ lumens
    DarkMark340 and Bertw192 like this.
  10. Jul 19, 2021 at 11:13 PM
    Grossomotto
    2017 4WDV6LB6MT
    Replied to @OrangeCrash, thx for the order, much appreciated.
  11. Jul 27, 2021 at 9:36 PM
    Grossomotto
    2017 4WDV6LB6MT
    This is the back of an owners roof rack with chase lights facing out
  12. Aug 6, 2021 at 1:22 PM
    Grossomotto
    2017 4WDV6LB6MT
    An owner put a few 45° pods on a Jeep roof rack, turned out awesome
    Tucson4runner and malburg114 like this.
  13. Sep 2, 2021 at 6:02 PM
    Grossomotto
    2017 4WDV6LB6MT
    I'm updating my pods with the new KC Cyclone V2 light and will have pics up soon. They're the same size, just want to confirm fitment.
    If anyone has the V1 lights I can always make the pods for those, as well.
    vorkuta775 and malburg114 like this.
  14. Sep 2, 2021 at 6:41 PM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
  15. Sep 2, 2021 at 6:53 PM
    Grossomotto
    2017 4WDV6LB6MT
    Something like the 30° pods would work under the hood if you want the light to point straight down on the engine with the hood open. I'll measure the angle tomorrow and check clearance.
    Unless you mean mounted to ditch light brackets coming out the front of the hood?
    AllTacosFloat[QUOTED] likes this.
  16. Sep 3, 2021 at 2:49 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Hmmmmmmmmmmmmmmmmmmm
  17. Sep 3, 2021 at 2:53 AM
    AllTacosFloat
    Boston ish
    Think I might try a pair of the 30°. Low profile and bolts to existing holes. Win win
  18. Sep 3, 2021 at 9:22 AM
    AllTacosFloat
    Boston ish
    Thanks, yes, I'm looking to light the engine bay. Just need to make sure I have clearance.
  19. Sep 3, 2021 at 9:36 AM
    Grossomotto
    2017 4WDV6LB6MT
    Cool, I just looked and you'll need 3" clearance, it just matters where you put it, so you'll have clearance. Also, you probably just need 1 light pod, but you can buy as many as you like, thx :)
  20. Sep 3, 2021 at 9:43 AM
    AllTacosFloat
    Boston ish
    Let me go mess around and see what I got. No matter what I'd do the pair. Also looking to see if I can dim them to not blind myself
