Aluminum Oil Filter Housing: 15620-31060
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Metonymy, May 16, 2017.
  1. May 16, 2017 at 8:44 PM
    #41
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    125k platinum. lucky sob....
  2. May 16, 2017 at 8:45 PM
    #42
    GPsevinSixx
    GPsevinSixx Well-Known Member
    Ros Angerus
    2015twoAX2.4techPAWS
    6112/5160AALfnCNTSTRyokG015
    Damn.....that turd's a keeper till then!
  3. May 16, 2017 at 9:00 PM
    #43
    LJGIbbs
    LJGIbbs Well-Known Member
    Independence Missouri
    2017 TRD PRO Cement 6MT
    none yet/none planned! It's perfect!
    I trust my life to a plastic gun so I am good with a plastic oil filter housing!
    kybluejeep, Hiluxski, Hoff and 2 others like this.
  4. May 16, 2017 at 9:02 PM
    #44
    Z50king
    Eric
    Southern California
    Stock and loving it
    I'm good with the price at 16 bucks, all in
    Metonymy[OP] and LJGIbbs[QUOTED] like this.
  5. May 17, 2017 at 2:25 AM
    #45
    tibadoe
    tibadoe Well-Known Member
    Joe
    Gladys, VA
    17 Tacoma SR 4X4
    Good price. Think I paid about $20 for these months ago. I replaced the plastic housing on the wife's RAV4 and my previous Tundra with the Aluminum one at the first oil change. :thumbsup:
    Metonymy[OP] likes this.
  6. May 17, 2017 at 2:54 AM
    #46
    momoe65
    momoe65 Well-Known Member
    2017 Super white TRD OffRoad
    Full LED upgrade toytec lift SCS wheels w/ cooper STMaXX clazzio seat covers
    ordered...good looking out
  7. May 17, 2017 at 3:18 AM
    #47
    TONYCANNOLI
    TONYCANNOLI Well-Known Member
    ‘15 DCSB 4x4 Sport / ‘14 SR5 Premium 4Runner
    I had to buy one of these for my Tundra. I admit that I ruined the plastic one due to my fluted wrench being a Walmart cheapo. The filter I got came with a special tool which helps on both the metal and plastic. In the end, I feel it comes down to preference...to each his own.
  8. May 17, 2017 at 6:33 AM
    #48
    Hagendazsss
    Hagendazsss Well-Known Member
    San Diego, CA
    2017 3.5 4x4 sr dcsb
    16 bucks. Why not
  9. May 17, 2017 at 6:42 AM
    #49
    gorram
    gorram Well-Known Member
    2016 Limited
    That's what I was thinking, the plastic housing is pretty beefy it seems like it could outlast every moving part on the vehicle.
    Hiluxski and Hoff like this.
  10. Jul 12, 2017 at 6:26 PM
    #50
    Z50king
    Eric
    Southern California
    Stock and loving it
    I had the service center install the oil filter housing during the oil change today. They wrote in my service paper work that the metal filter does not have the locking tabs like the plastic does. So they pushed the lock up against it but it's not locked. They said it won't rotate so it should be fine.
    Any info? I didn't look at it before they installed it
  11. Jul 12, 2017 at 6:37 PM
    #51
    GPsevinSixx
    Ros Angerus
    https://forum.ih8mud.com/threads/aluminum-oil-filter-cap-durability.411523/
    Check this out. The tabs are just for retention, but it's not on there tight like it's screwed on. It floats on the tab and uses the spring pressure to keep it from flopping around before installation. If it doesn't rotate, it should be fine. So yours came with the longer tube like the one displayed in this thread?
  12. Jul 13, 2017 at 4:48 AM
    #52
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Which brand of wrench for these caps is decent (ie won't break the second time I use it)?
  13. Jul 13, 2017 at 4:54 AM
    #53
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Motivx.
    I also like their oil filter drain hose.
    MOC221_[QUOTED] likes this.
  14. Jul 13, 2017 at 7:55 AM
    #54
    Z50king
    Eric
    Southern California
    Stock and loving it
    I don't know. The service people did it. There is a tube in the plastic unit, so I'm not sure if they switched it out.
  15. Jul 13, 2017 at 8:28 AM
    #55
    MOC221_
    Frank
    Yeah the Motivx MX 2320 (640mm) looks like it would take some abuse. Thanks Splitbolt,
    Frank
  16. Jul 13, 2017 at 12:52 PM
    #56
    Hiluxski
    Hiluxski Well-Known Member
    Ventura California
    2022 Lime green TRD Pro
    You're looking for trouble, you didn't look at this part and you gave it to the oil change people to swap out ? do you think they took the time to measure that tube and make sure everything was identical. This thread gave all the info you why would you not check it yourself. That seems like a big gamble and now the locking tabs don't lineup that doesn't seem right to me. these type of mods are for the do it yourself or at home guy who is into it.
    shakerhood likes this.
  17. Jul 13, 2017 at 12:53 PM
    #57
    Z50king
    Eric
    Southern California
    Stock and loving it
    I'll check if the part was removed from the unit when I get home. There are no locking tabs on the metal unit
  18. Jul 13, 2017 at 12:55 PM
    #58
    Hiluxski
    Ventura California
    The housing is supposed to be identical with the exception of it being aluminum the locking tabs should be there. I've not heard of anybody else not having locking tabs.
  19. Jul 13, 2017 at 12:55 PM
    #59
    GPsevinSixx
    Ros Angerus
    so much agree..... I would have used the resources here since it was listed in one of my posts, but if the service dept agreed to put it in, then they can be liable for any issues with it if their tech did not install it properly. It doesn't take a rocket scientist to figure it out, but some of those techs do amaze me!
    They likely wouldn't have installed it if it was deemed unsafe or it didn't fit right.
    lbrewer likes this.
  20. Jul 13, 2017 at 12:56 PM
    #60
    Hiluxski
    Ventura California
    You're locking tabs lined up and worked correctly didn't they? , interesting you bring up liability as the tech noted oil filter housing swap , noted that it did not fit correctly and that he thinks it should be OK. Customer supplied parts noted on the work order I think they covered their liability
