Aluminum Oil Filter Swap
Discussion in '3rd Gen. Tacomas (2016-2023)' started by gcmesa, Apr 2, 2018.
  1. Apr 2, 2018 at 10:45 PM
    gcmesa
    gcmesa [OP] New Member
    2017 Double Cab V6
    Hey guys,
    New to Tacoma World and wanted to share a video I made on switching to the aluminum oil filter canister.
    https://www.youtube.com/watch?v=Kx3BuNuDTdg&t=1s
    I don't get to check the tacoma fourms daily but give it a watch and leave some feedback on what you think or how I can make better videos.
    This is my 5th Toyota truck, 3rd Tacoma, and I've always done mods over the years so I hope this will help anyone looking to do the swap. I've also surfed TW for previous posts on the swap and they were super helpful.
    Later. -Greg
  2. Apr 2, 2018 at 11:15 PM
    SeeWhatHadHappenedWas...
    SeeWhatHadHappenedWas... Well-Known Member
    Jeremiah
    Oregon
    2017 OR DCSB MT Quicksand
    Very cool, it was one of the first mods I did. I had a lot of looking around to make sure I did it right. Nice to have it in one spot for other people.
  3. Apr 3, 2018 at 3:16 AM
    kbp810
    kbp810 Well-Known Member
    Au Gres, MI
    2016 Tacoma TRD OR
    As long as you have a skid plate protecting it, I would go ahead and install the fumoto. Find a short length of tube that will fit it as well... then get ready to enjoy quick and mess free oil changes in The future. I don’t have one on my taco yet, but ran them on my jeep in the past where the skid plate made for a annoyingly messy oil change otherwise; planning to do the same in the taco with my next change.
  4. Apr 3, 2018 at 7:35 PM
    gcmesa
    2017 Double Cab V6
    I think I paid around $8 for the Mobil 1 filter at Walmart.
    nightcrawler[QUOTED] likes this.
  5. Apr 4, 2018 at 12:07 AM
    Drunken Chewbacca
    Drunken Chewbacca Well-Known Member
    Josh
    3rd Gen Taco
    Not enough to list
    What's the point in changing from plastic to aluminum? Real question, not trying to be a smartass..
    niko5055 likes this.
  6. Apr 4, 2018 at 12:41 AM
    gcmesa
    2017 Double Cab V6
    Hey Josh,
    When saw this mod it was a no brainer for me because I live in a dry climate. Rubber and plastic parts get dry and brittle faster in the desert. Oil filter canisters are also removed and reinstalled more than any other maintenance part so they see slow but gradual wear from the filter removal tool. The way I see it, it's an upgrade that will probably prevent future frustration for less than $30.
    I hope this helps.
  7. Apr 4, 2018 at 1:37 AM
    e6400ultra
    e6400ultra Well-Known Member
    NorCal
    2017 SR AC 4x4 MT 2.7L
    Acts as a heat-sink for a little extra heat dissipation? :notsure:
    The extra ruggedness is nice.
    nightcrawler likes this.
  8. Apr 4, 2018 at 12:15 PM
    Drunken Chewbacca
    Josh
    3rd Gen Taco
    Not enough to list
    Doubt it dissipates any heat. Also ruggedness? From your oil filter wrench? Anyways, I can see it lasting longer vs the plastic, however I bet the plastic one will last the life of the vehicle. You're not suppose to gorilla wrench it, snug and a quarter turn will do it..
    shakerhood likes this.
  9. Apr 4, 2018 at 12:23 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Exactly, if memory serves me that canister is only 18 Ft Lbs.
  10. Apr 4, 2018 at 12:32 PM
    SargeBSA
    SargeBSA With self-discipline most anything is possible.
    Cascade Mountains
    2021 SR5 Tundra 4x4
    TRD Offroad Wheels 265/75 18 General Grabber ATX's,
    Makes me so happy to have a regular oil filter on my 4cyl.
    Drunken Chewbacca likes this.
  11. Apr 4, 2018 at 1:11 PM
    Xena1
    Xena1 Well-Known Member
    Ron
    2017 Tacoma Access Cab
    Agree, that's why I bought the Baxter Performance spin on filter adapter. Aluminum or plastic, one still has the PITA cartridge filter.
  12. Apr 4, 2018 at 1:42 PM
    e6400ultra
    NorCal
    Of course it dissipates more heat, it's aluminum. Plastic is an insulator. ...Regardless how you plan to use it, aluminum is more rugged than plastic. I have seen plastic parts spontaneously crack without being misused. :duel:
    The aluminum oil filter housing is a no-brainer.
  13. May 10, 2018 at 6:57 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    I’m posting up my experience after buying the exact Aluminum filter off eBay, yes it was the right one and gaskets were all installed correctly.
    Here’s two things I found. The aluminum housing threaded all the way then completely stopped, metal to metal but it was tight. The other thing is it slightly leaked. I drove around for about 10 miles, pulled back in the garage, crawled under and noticed it was slightly leaking.
    So, I took it off and put the original plastic one back on. Really wanted this to work and was about $20, not much, but now it’s just a piece of aluminum in the parts bin.
  14. May 10, 2018 at 7:41 PM
    Grossomotto
    2017 4WDV6LB6MT
    The fitment was fine, it went on just like the plastic. But, after a test drive it was definitely leaking, not a lot, it was slightly which I’m not cool with.
    Leave your skid plate off and after you install it check it out to see if you have any leaks and use a flashlight.
  15. May 10, 2018 at 8:44 PM
    Garrett75x
    Garrett75x Well-Known Member
    Torrance
    2017 TRDOR 4x4 JBL P&T
    Pro Grille, Shmellfab rock sliders, Carhartt seat covers
    :eek:
