Aluminum or Steel Front bumper
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mark8913, Jul 1, 2016.
  1. Jul 2, 2016 at 10:10 AM
    #61
    rutacoma
    rutacoma Well-Known Member
    OK
    2012 TX TRD DCSB
    everything stayed square, i tigged it instead of spool gun, and moved around a lot doin 4-5 inch welds at a time. then stitch welded the inside
    ChadsPride and steelhd[QUOTED] like this.
  2. Jul 2, 2016 at 10:33 AM
    #62
    Pigpen
    Dan
    Northwest Montana
    1. The stock bumper is aluminum. The bumper cover is plastic.
    2. These trucks do fine with weight. My truck weighs over 5,000 pounds as a daily driver and I usually average 18 mpgs for my daily driving. I also tow, haul, and wheel with it regularly.
    3. Tacoma lean is a body mount bushing issue, not a suspension issue. Put on a beefier suspension and it does not go away.
    4. The stock suspension is designed for the stock truck - if you make changes, you need to change the suspension accordingly.
    ChadsPride likes this.
  3. Jul 2, 2016 at 10:45 AM
    #63
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    Do you feel an increase in body roll when you have a passenger? Because a passenger is more weight at a much higher COG.
    Sliders aren't stiffening your frame on a perceivable level, either. Roll cages, engine cages, bed cages stiffen frames because they connect to both sides of the frame.
    ChadsPride and JimBeam like this.
  4. Jul 2, 2016 at 10:46 AM
    #64
    Shenanigans613
    Shenanigans613 Well-Known Member
    Justin
    Crestview FL
    2016 Silver TRD OFF ROAD MT
    Tint, Bed mat, door sill protectors, others pending.
    1. My stock bumper is plastic.
    2. These trucks do not do well with weight, or we would not have two sides to this debate. This issue would not come up if we were on a full size truck thread. we would all just run steal bumpers. The curb weight of a tacoma is between 4000-4500 lbs. Compared to an F-150 for example that has a curb weight from 4100-5200lbs. The tacoma is a fat pig for its size. (not that I don't love it)
    3. Fair enough, I will take your word for it. Though, I thought toyota would have had a little higher fit and finish then that. Seems like an easy fix, but I am not an engineer.
    3. I agree 100% with you.
  5. Jul 2, 2016 at 10:48 AM
    #65
    rutacoma
    OK
    2012 TX TRD DCSB
    i think on the number 1 he was talking about the aluminum crush bar behind the plastic
  6. Jul 2, 2016 at 11:14 AM
    #66
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Honestly I have no idea anymore. I've had the sliders on for long enough I've changed my habits. Since posting this I have driven somewhere and was feeling for body roll, and I only felt a tiny bit on a sharp right turn. Maybe it was all in my head, but I swear it made a slight difference! Oh well.
    My take on the OP.
    He spent a few days doing recon on TW. He found out that any thread comparing two things that are popular turns into a semi heated debate. He pulled the pin and ran! I don't think I've seen himpost since #1.
  7. Jul 2, 2016 at 11:32 AM
    #67
    Mxpatriot
    Do you think that could have anything to do with the majority of trucks on this forum having rock sliders?
    Talk to me about body roll when you ditch your sway bar.
  8. Jul 2, 2016 at 11:34 AM
    #68
    Yamaha_TacoR1
    Yamaha_TacoR1 Very slow racer
    NJ/NY, USA
    2015 Black TRD Sport 4x4 Limo
    - 5100/885's, 5100/Icon 3leaf progressive AAL with overload left in, 1/4" Taco lean spacer - ARE Z Series camper shell with Yakima rack system - Tepui Ayer Rooftop Tent - Prinsu Design Cabrac with heavy duty anadized bars - WeatherTech window deflectors/floor liners/bug deflector - Ultragauge MX1.3 - PopnLock codable locking tailgate handle - TRD shift knob - 3M tint - Extang solid fold2.0 tonneu cover - OEM Tacoma muffler tip - OEM Tacoma side steps - OEM Tacoma bed mat - OEM Tacoma roof rack - OEM TRD PRO front grille in matte black - OEM TRD PRO headlights - Fastway FLASH "Solid-Tow" adjustable aluminum ball mount hitch - Reese dual hitch ball covers - Masterlock locking J pin - GoPro windshield mount - Door trim protectors - Side mirror 'fish eyes' - Thule T2 hitch mount 2 bike carrier - LEDs: Map/Dome, 3rd brake, license plate, parking lights, reverse CREE's - SEMA TRD PRO 17" black matte wheels - 265/70/17 BFG A/T KO2s - Black Widow 40" x 95" 3 piece powder-coated folding bed ramp - Mobtown Offroad ribbed tailgate reinforcement skin - GRIDiT center console organizer - Salex center console organizer - Marco Extreme Blast black premium train air horn - 'ImmrYo' Rearview mirror relocate bracket - Mattgecko's Sliding window security bar - Rigid tow rear hitch shackle - Plasti-dipped gunmetal emblems - Blacked out ACEkraut's front license plate relocate bracket - De-flapped (OEM mud flaps gone) - Uniden XL520 CB Radio - Shmellmopwho's CB antenna bed mount - 3ft Firestik II CB antenna - BirdDawg Industries Tech Deck Extreme version w/ 3 Ram 1" ball mounts - Ram Mounts: iPhone6/iPad Mini4 X Grips with 1" dual ball sockets - Garmin GLO portable GPS & GLONASS receiver - Depo LED tail lights with blacked-out inner housing - Various Velcro backed patches on the headliner - 3D-Cell LED Maglite mounted to the driver seat - 4XInnovation DOM weld on sliders with kickouts (welded at 20degree angle) - 4XInnovation Hi Lift bed mounting system - Hi Lift All cast 60" jack with optional handle holder - Lotus Development Hi Lift slider adapter - Relentless Fabrifacfions dual bed rail mounts with dual Quick Fists - Salex glovebox organizer system - YETI vintage bottle opener mounted to the bed - TRD Sport style aftermarket epoxy resin decals for WT front mats - Rigid Industries LED D2 spot lights (Midnight edition) - CBI spot light hood mounts - Air on Board "Zombie Lights" switch - Rebadged WeatherTech floor liners with custom TRD Sport emblems - GoPro Hero 3+ windshield mounted - Mattgecko's cool white LED bedlight kit v2 - 1.25" Spidertrax wheel spacers - Maxsa Escaper Buddy traction boards (mounted on top of Prinsu Cabrac) - 42" Plano Weatherproof gun case (mounted on top of Prinsu Cabrac) - 2gal Rotopax gasoline can, mounting plate, DLX pack mount (mounted on top of Prinsu Cabrac) - Bestek 150W power inverter DC 12V to 110 V - DBPower 600A car jump starter/booster - SOS Off-road Concepts Factory recovery replacement mount - ARB 30' Recovery strap - ARB EZDeflator - Smittybilt receiver hitch D ring with 3/3" shackle - Bosch Icon wiper blades - RCI IFS steel skid plate - Trasharoo trash bag - mounted on tailgate - Lamin X yellow fog lamp covers - Aftermarket illuminated air conditioning/heater/vent knobs - Toyota full frame replacement - Spring 2023 ================================ Future mods: - Rear diff breather relocate - Foglights anytime - Install external speaker for CB - Install mattgecko bedlight kit
    Damn this thread. Now I want aluminum bumper
    Harry, Maticuno and ChadsPride like this.
  9. Jul 2, 2016 at 11:48 AM
    #69
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    No thank you.
  10. Jul 2, 2016 at 12:00 PM
    #70
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Mustang?
    1/4" Aluminum plate bumper will eat sheet metal.
  11. Jul 2, 2016 at 12:13 PM
    #71
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Anderson, SC
    2015 DCSB 4x4 trd offroad
    Ome 887s, dakars, lr uca,sliders, konig countersteer,
    I just purchased aluminum bumper and a steel regular rear from sos concepts... I weighed my options (no pun intended) on steel vs aluminum.. a lot actually.. my reasons for aluminum were :
    1. Weight.. I have 885x and dakars and sliders already.. didn't want to change suspension again. I am a firefighter and usually have to respond quicker
    2. Doesn't rust.. my sliders I have to touch up a few times a year as is.. I didn't want to have to touch up my front bumper as much in fear of rusting if I couldn't get to it right away
    3. Air bags... as much as I don't want to have a wreck if I have one I want it to fold and keep the same shock absorbing characteristics to allow my air bags to deploy and save my life. I also would rather my bumper shear of than bend my frame.
    4. This is my daily driver like most mpg are important to me
    5. Protection... The off-road driving I do is not hardcore.. it's trail riding.. I wanted a little more protection up front and ability to winch if needed. Aluminum holds up well from what I have researched contact with animals...
    Now granted steel is stronger and has its benefits but my opinion and for my life style I choose aluminum .
    trlfrk, WormSquirts, rutacoma and 5 others like this.
  12. Jul 2, 2016 at 12:20 PM
    #72
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Well said!! The airbags deploy off of inertia, but having it crumple and absorb that energy is a big plus.
  13. Jul 2, 2016 at 12:45 PM
    #73
    Shenanigans613
    Justin
    Crestview FL
    But I thought the object of these bumpers was to try and inflict as much damage to the other participant in the accident as possible. :smash:
    medjah and ChadsPride like this.
  14. Jul 2, 2016 at 12:54 PM
    #74
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    That's going to be my goal with my steel one! I'm an advocate for both bumpers as they both have the their place. For me, I want inexpensive and super tough, because at this point I don't really are about the weight. At least not $400+ worth. My main factor is just the price point. If they were both equal, I'd go aluminum
  15. Jul 2, 2016 at 12:56 PM
    #75
    Shenanigans613
    Justin
    Crestview FL
    And with the steal bumper you and Jnelsen can go head to head on the trail to find out who does it harder! haha :burnrubber:
  16. Jul 2, 2016 at 12:57 PM
    #76
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Aha! Or play chicken and end up jacking up the line-x on it. That wasn't their brightest moment.
  17. Aug 24, 2016 at 9:41 PM
    #77
    Boomkanani
    Boomkanani Well-Known Member
    Goldsboro, NC
    2009 TRD OffRoad DCSB - 6 Speed
    Some stuffz
    I'm scared now....my 2 dogs weigh a combined 140 lbs. Acording to some of the comments in this thread, when my dogs are in the truck...I get about 2 mpg, my truck might tip over while turning, and I need to upgrade my suspension....
    JaxJim likes this.
  18. Aug 24, 2016 at 9:45 PM
    #78
    Boomkanani
    Goldsboro, NC
    Some stuffz
    God forbid I pack the truck with 4 adult friends...it might implode
    JaxJim likes this.
  19. Aug 24, 2016 at 9:56 PM
    #79
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Clearly you lack understanding of fulcrum points in suspension design. 140lbs suspended between the wheels is in no way remotely equal to 140lbs hanging off the nose of the truck. Unless you like riding on your bump stops you will need to upgrade your suspension.
    BenTheMan and EatSleepTacos like this.
  20. Aug 24, 2016 at 10:23 PM
    #80
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    I got an aluminum pelfreybilt front for the same reasons as @Jeffvt0508 . I have home built steel sliders and pelfreybilt steel HC rear, because those are the parts i usually hit on stuff.
    otherwise, having less weight on the front was a big plus. more clearance has come in very handy. doesn't rust. running a winch was a main reason. and way more protection over stock. fuel economy as my truck is my daily. crumples in an impact unlike steel. I'm not big into rock crawling, or purposely smashing my truck into stuff "just cuz", but going through a very steep cross ditch i did drag the front end pretty good and it did leave a couple light gouges, but nothing bent. just adds character. :notsure:
    If i were into rock crawling, or more hardcore trails, i would definitely get steel. but as it is my wife and i just love getting out into the more remote reaches... typical "overlanding" (did i use that right?) so aluminum was the right choice for us!
    econwatch likes this.
