Aluminum Plate Bumpers
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Yaozer, Aug 20, 2013.
  1. Aug 20, 2013 at 8:33 AM
    Yaozer
    Yaozer [OP] Well-Known Member
    North Jersey
    2011 Red DCSB TRD Sport
    Flowmaster exhaust, 3" Old Man Emu lift, Konig Countersteer Rims, and too much more.
    Anyone have any experience with these? Which vendors make them? Would I sacrifice a good amount of strength bc of the material?
    Just for reference, I have a 2011 double cab sport with old man emu 885 kit in the front with all pro standard leaves in the back.
    I am also wondering if anyone else out there runs a snow plow with a plate bumper and if there were any issues with the combo of (plow and plate bumper).
    On the other hand, would it be better to just upgrade to 886 bc of the weight on the front?
  2. Aug 20, 2013 at 11:47 AM
    HMA
    HMA Well-Known Member
    Hal
    Bainbridge, Ga
    '10 Taco Surveying Machine '22 Lunar Rock
    I have an Aluminess. I'm sure it's not as strong as the steel ones, but it's stronger than OEM and lighter than steel. I have stock suspension and was told that most steel ones were heavy enough to require heavier springs and or a re-alignment.
  3. Aug 20, 2013 at 1:24 PM
    Yaozer
    North Jersey
    Anyone run a snow plow with this bumper?
  4. Aug 20, 2013 at 1:25 PM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    Not a lot of Tacomas with plows around here....
  5. Aug 20, 2013 at 1:27 PM
    Benson X
    Benson X My build thread sucks...
    Ben
    Olympia, WA
    '11 MGM DC/LB
    If you don't draw blood, you're doing it wrong!
    ...also Tim (Elite) can make his bumpers out of AL.
  6. Aug 23, 2013 at 11:03 AM
    obscurotron
    obscurotron Well-Known Member
    N. Nevada
    '14 DCSB 4x4
    Too many to list, and I've probably forgotten a bunch.
    Resurrecting this for a moment...
    Anyone with an Aluminess front bumper and a winch -- seems the bumpers come with pre-drilled 1/2" holes, but my winch (M8000) uses 3/8" hardware. What did you other Aluminess owners use to sleeve from 1/2 down to 3/8?
