Aluminum Radiator
Discussion in '1st Gen. Tacomas (1995-2004)' started by Denunz411, Jul 25, 2015.
  1. Jan 31, 2019 at 5:53 AM
    #121
    burntkat
    burntkat Well-Known Member
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Resurrecting this thread. I am having the same issue. I will need a radiator probably this year, and am having trouble finding one to fit a 97 3.4 5 speed.
  2. Jan 31, 2019 at 6:11 AM
    #122
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    Are you meaning you can't find an all aluminum one? If not RockAuto has plenty of plastic + aluminum varieties.
    https://tinyurl.com/yahaqzgx
  3. Jan 31, 2019 at 6:14 AM
    #123
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
  4. Jan 31, 2019 at 6:15 AM
    #124
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Yes. That's why I'm posting in the "aluminum radiator" thread.
    El Taco Diablo likes this.
  5. Jan 31, 2019 at 6:19 AM
    #125
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    I've had this exact experience with the radiator relocation in my V8-swapped S10.
  6. Jan 31, 2019 at 6:21 AM
    #126
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Good info here, which seems to answer my earlier question.
  7. Feb 4, 2019 at 4:24 PM
    #127
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Called them an hour ago. He said he had three on the shelf.
    Now he has two.
    255 shipped to me in Charleston, SC.
    Rldanie and 1997tacomav6 like this.
  8. Mar 4, 2019 at 12:37 PM
    #128
    ike.bentley
    ike.bentley Member
    Ike
    Virginia Beach
    '95 RusTacoma XtraCab 2.7L 4WD
    Billy 5100s, C'burg UCAs, OME Dakars, AllPro Bumper, Homefab Skids, Homefab Trac Bars, Safe-T Cap
    Following on the thread resurrection/hijack, has anyone replaced a taller radiator with a shorter one? I have a 4x4 5spd (meant for 20 3/4 height), but I'm eyeballin one on rockauto that's all aluminum for about $130. However this one is 18 5/8 height. Will this 2 1/8" difference make that much of a difference or am I just overthinking it?
    Arctic Taco likes this.
  9. Mar 4, 2019 at 12:54 PM
    #129
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Have you read through this thread? That question is answered several times, as well as the specific hose you will need to accomplish this.
  10. Nov 11, 2019 at 7:50 PM
    #130
    CHMM
    CHMM GTO
    Gabe
    Castle Rock, Colorado
    2001 TRD Xtra Cab 4x4 Supercharged
    5100s SPC UCAs Energy bushings #70 spring clutch mod Supercharged
    Hi,
    Re-resurrecting the thread has anyone found a plug and play radiator that is better than OEM. Running good with Supercharger? Looking for something without mods to fit right. 2001 3.4L v6 MT.
    cornbread_wy likes this.
  11. Nov 12, 2019 at 5:53 AM
    #131
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Honestly I am rather impressed with this one. I have been running it for about 8 months I think, and it is still fine. Even with my truck having been totaled in a front-end collision- no leaks. The radiator is probably going to wind up being a loss, though- it got bent in the collision. Even with that, no leaks. I am impressed.
  12. Nov 12, 2019 at 1:22 PM
    #132
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    Koyorad released one this year that is all aluminum and is hopefully better than the Champion ones that appear to be prone to leaking. It's technically for the 3rd Gen 4Runner, but will work with 01-04 MT Tacomas too.
    I purchased it and my friend installed it last month. Here is a link to the post I tossed into another thread about it:
    Champion Radiator Aluminum 3 core swap
    I can't say whether it will be more effective with a supercharged 5VZ, but it definitely keeps the 1KZ cooler than the stock rad did so I'd say its a safe assumption that it will.
    Arctic Taco and CHMM[QUOTED] like this.
  13. Nov 13, 2019 at 8:54 AM
    #133
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Can you get a pic of how far down the frame it comes? I'm going SAS so it can't go lower than the framerail.
  14. Nov 13, 2019 at 8:58 AM
    #134
    CHMM
    CHMM GTO
    Gabe
    I’ll check it out for sure.
  15. Nov 13, 2019 at 9:08 AM
    #135
    CHMM
    CHMM GTO
    Gabe
    So is there like a metric to look at to see if it potentially cools better than stock? Is it the size, the material it’s made of? Thanks
  16. Nov 13, 2019 at 11:55 AM
    #136
    RattleTractor
    Harry
    VT
    I will look for sure.
    The size matches that of the larger of the Tacoma radiators. Not sure if it sticks out lower or not offhand, but it isn't a special size either.
    My truck has an exhaust gas temp gauge that's mildly accurate. After installing the new radiator the gauge appeared to read 100-200 deg F cooler. Now it's sometimes even more, but that's because it's pretty much winter here at this point. The real test will come next summer.
    For 3RZ/5VZ motors, I guess using a scangauge or something for coolant temp is probably the move. Honestly I never cared when I had a 5VZ. Stock cooling setup worked just fine, even with an ARB/winch/lights impeding airflow somewhat.
    See size comment above. Since it matches stock, I think that the added cooling benefits come from the design- thicker core and how the coolant flows through it.
    It comes with steel mounts that match the style that the stock radiator uses. I'd assume that this is better than the Champion models, which bolt onto the truck directly, but I can't be certain. Only time will tell whether it's a much "cooler" radiator. Certainly looks cooler.
    CHMM[QUOTED] likes this.
  17. Nov 17, 2019 at 4:46 PM
    #137
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
  18. Feb 14, 2020 at 10:19 PM
    #138
    Arctic Taco
    Arctic Taco Firefly, Serenity Ed. -Arctic Taco, a slow build
    Denali Park, Alaska
    98 Tacoma Xtra Cab DLX, 85 Toyota LWB 4x4
    dents and missing bits, built in the Gravel garage, hillbilly trained mechanic…
    I found some bushings at Amazon: https://www.amazon.com/gp/product/B00OP3C614/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1
    Added some washers and M8-1.25 x 30mm bolts so maybe that will help it last longer.
    Talking with some techs at a radiator place, they thought the brackets might not be welded on in enough spot- just tacked and the thicker core can’t flex as much. So I figured I would try some bushings like the Hillmans above and start the search for something as a back up/ replacement maybe a Koyorad # http://battlebornoffroad.net/battle-born-offroad-specials/koyo-radiators/vh010665n/i-7532947.aspx
    Or this one:
    https://www.radiatorexpress.com/Product/radiator/toyota/2001/4runner/base/34l-v6/222485/1375163
    Still looking at this time- the Champion isn’t leaking yet but with a trip up the AlCan in a couple months....
  19. Feb 14, 2020 at 10:27 PM
    #139
    Arctic Taco
    Denali Park, Alaska
    I just installed these bushings and a steel washer, M8-1.25 x 30mm flanged bolts with the metal washer on the core support side. Still have over an 1” between the stock fan and the radiator. Going to keep looking for a replacement to keep as a back up. Who knows it may be one of the early unicorns with no drama, another AlCan trip will be a good test. I will attach some photos tomorrow when it is light enough to get pictures
  20. Feb 15, 2020 at 8:30 PM
    #140
    tony2018
    tony2018 Well-Known Member
    got pics?
