Aluminum replacement for plastic rear coolant bypass joint
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jowett, Jan 5, 2021.
  1. Jan 12, 2024 at 12:15 AM
    #181
    danielgonzzz
    danielgonzzz Well-Known Member
    Daniel
    2019 Tacoma TRD Sport 4x4
    Stawk as FUCK!
  2. Jan 12, 2024 at 3:00 AM
    #182
    bishop5213
    bishop5213 Member
    2023 Tacoma TRD Off-Road DCSB 6MT
    Please add me to the list as well. Thanks!
  3. Jan 30, 2024 at 8:48 AM
    #183
    djchrisepa
    djchrisepa New Member
    2022 Tacoma 2WD TRD Off-Road
    2 (10” DD Audio Subs) (4) JBL Club Series Components (1) Kicker 600w mono (1) Kicker 720w 4 Ch.
    Following!! Please send me any info you need and I'll buy!
    02Duck likes this.
  4. Jan 31, 2024 at 3:10 PM
    #184
    rzbryant
    rzbryant New Member
    Put me down too 4804142536
  5. Feb 8, 2024 at 7:27 PM
    #185
    tacoma warrior
    tacoma warrior Well-Known Member
    2020 Tacoma SR5 silver
    Any update on this part?
  6. Feb 8, 2024 at 9:27 PM
    #186
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    It’s been 3 years since the first post in this thread. I’d say it’s as dead as a “will these tires rub” thread.
  7. Feb 8, 2024 at 10:08 PM
    #187
    JaxsonPotato
    JaxsonPotato Well-Known Member
    2023 TRD Off Road DCSB Lunar Rock
    This guy has people begging him to send them an aluminum coolant pipe for over 3 years and he just keeps teasing you. Greatest troll post of all time.
  8. Feb 9, 2024 at 6:06 AM
    #188
    dietcokefiend
    dietcokefiend Well-Known Member
    What shocks me here is that the aluminum one is a normally stocked part. Anyone here can go and buy it. It has the fitting going in the wrong direction, but this is pretty basic stuff for really any machine shop to look at and get a new fitting pressed or threaded in for the 90-degree outlet.
    TAC1 likes this.
  9. Feb 9, 2024 at 6:15 AM
    #189
    Topanga Taco
    Topanga Taco BUZZING NITRO
    Rick
    Topanga Strong Southern California
    2018 SR5 4x4 DCSB Harrop rear E-Locker
    The Magic of ALSD RCI-skid RAS-Sumos Bilstein 6112/5100
    If you can get Lexus to sell you this piece after you plea your case if you have this issue, a mill+custom jig to hold the piece if needed(aluminum or mag?)+TIG welder= modified to OEM specs.
    That would be good stuff…
  10. Feb 9, 2024 at 6:24 AM
    #190
    Sungod
    Sungod Well-Known Member
    St Augustine
    I haven't had any issue with my plastic pipe and really don't understand why someone would go out of their way to replace something that works.
    BillF1564 and Canadian Caber like this.
  11. Feb 9, 2024 at 6:35 AM
    #191
    Topanga Taco
    Rick
    Hear hear and definitely took warning from a member who mentioned that after time, the coolant becomes caustic. I recently switched it and although it still appeared pink and okay, the fresh coolant had an entirely different shade. From here on out, I’m heeding Toyota’s recommendation of every 5 years(I have to double check that, stoner can’t recall).
    Jerry311SD and Canadian Caber like this.
  12. Feb 9, 2024 at 4:35 PM
    #192
    JaxsonPotato
    Because like everything else in this forum, a handful of people had an issue and everyone freaks out and thinks every Tacoma will also have the issue.
  13. Feb 9, 2024 at 6:53 PM
    #193
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    You're on TW. If it ain't broke, fix it until it is!
    On the other hand, if you have a leak, it would be a bad feeling replacing it with the exact same plastic part knowing it'll probably leak again.
  14. Feb 9, 2024 at 7:13 PM
    #194
    rtzx9r
    Bueller
    2016 TRD Sport
    Some of us have…
    and yet I replaced mine with the same plastic part hoping I get another 90k out of it. Not dropping the tranny again because my bogus aluminum housing didn’t work how I planned after I cut it up.
    Same school of thought on the plastic vs metal oil filter housing.
    Barsoom and BillF1564 like this.
  15. May 10, 2024 at 10:33 PM
    #195
    GawainXR
    GawainXR Well-Known Member
    William
    2020 TRD Off-Road
    DashCam
    I think people want to buy one to keep on standby with the impression that their plastic one is going to inevitably fail, swapping it out when that occurs.
    ToyodaSun, Barsoom and stealthmode like this.
  16. May 11, 2024 at 3:47 AM
    #196
    TacoSupremo19
    TacoSupremo19 Well-Known Member
    NJ
    2019 Black Tacoma TRD SPort DCSB
    Brushed Copper Blaze 10 Rims | 265 70 17 Toyo Open Country A/T III tires | Bilstein 5100 w/ Eibach Coils 2.5" lift | Blackhawk UCAs | ICON Rear 3 AAL |TRD Skid Plate | TRD CAI | OEM Rear Bed Lighting | OEM rear Tailgate lock | RC Bed Molle Racks | Custom Blacked out OEM LED Headlights | MESO V4 Mirror Turnsignals | MESO Interior trim blackout | TG DMM dash mount | TRD Shift Knob | OEM SR5 interior door handles | Upgraded Stereo including Alpine 700W Amp Alpine Type R Components & Hertz speakers 12" Sub | Custom Clazzio Seat covers | Mobtown Sliders | Front Camera
    Just to be clear, coolant becomes acidic, the opposite of caustic, over time. One of those bulb testers can quickly tell you the Ph level of your coolant. Not sure this is causing the issues with the pipe as the pink stuff lasts 100k and most people that have had this problem are under 100k. THe mystery of the cracked coolant manifold rages on....
    Ngneer likes this.
  17. May 11, 2024 at 9:54 AM
    #197
    GawainXR
    William
    2020 TRD Off-Road
    DashCam
    Would this apply in the case where someone reported this issue with a 22?
  18. May 11, 2024 at 10:00 AM
    #198
    TacoSupremo19
    NJ
    Not sure what you're asking. I would think this would fall under warranty if that's what you mean.
  19. May 11, 2024 at 10:13 AM
    #199
    GawainXR
    William
    2020 TRD Off-Road
    DashCam
    What I meant is age of the fluid is less likely to be a significant factor if the person with the 22 had the exact same failure.
  20. May 11, 2024 at 11:28 AM
    #200
    TacoSupremo19
    NJ
    Correct. That's why I said what you responded to initially. I don't think the fluid is a factor at all since people that have this problem are way under 100K. Not everyone has the problem either. I don't have it on my 2019. I'm almost at 80K. So this would more point to a manufacturer defect, assembly error, or mechanical stress, (like possibly wheeling too hard). Someone will figure it out eventually. Really kinda shocked that there isn't an aluminum alternative yet that can be bolted right on.
    Kodiak420 and Canadian Caber like this.
