Aluminum replacement for plastic rear coolant bypass joint
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jowett, Jan 5, 2021.
  1. May 11, 2025 at 10:06 PM
    #241
    Kidneypunch
    Kidneypunch Active Member
    Ethan
    2021 TRD Sport
    @Jowett I am very much wanting to get an aluminum version of this. The parts seem to be back ordered at many Lexus parts suppliers. Staying tuned…
    Barsoom and BillyE like this.
  2. Jun 5, 2025 at 9:21 AM
    #242
    Kidneypunch
    Ethan
    2021 TRD Sport
    What would the torque spec for this be? Same as with the rubber gaskets?
  3. Jul 4, 2025 at 4:56 PM
    #243
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Did you try making it in metal yet? Check out PolyCast printer filament- it’s designed to burn out without any ash residues for casting the same way you do with wax. You’d be able to cast the part with Aluminum this way! I’m going to try it also, thanks for your STL files!
    JmsWms likes this.
  4. Jul 4, 2025 at 5:30 PM
    #244
    Kidneypunch
    Ethan
    2021 TRD Sport
    I just used the metal one from Jowett’s post. The shop was able to install it. We put a silicone hose elbow and capped off the smaller port. It works fine. No leaks.
    Phlogiston, JmsWms and Barsoom like this.
  5. Jul 4, 2025 at 6:54 PM
    #245
    OnHartung'sRoad
    Looking at his photo- there are 5 ports on the aluminum one(not counting the three at the bottom) and two on top are stuck together. Does the Tacoma plastic one have only 2 on top (not counting the three on the bottom)? If so, what 3 ports did you seal, or am I missing some?
  6. Jul 4, 2025 at 9:24 PM
    #246
    Kidneypunch
    Ethan
    2021 TRD Sport
    On the aluminum one…There are the three on the engine side, one that comes out opposite toward the firewall (5/8) and a small one (5/16) that comes upward out of the top.
    The original part has the three engine side ports and the one (5/8) that comes up to the heater hose. I plugged the smaller port (5/16)
  7. Jul 5, 2025 at 9:19 AM
    #247
    OnHartung'sRoad
    Thanks for the details, appreciate it!
  8. Jul 5, 2025 at 10:30 AM
    #248
    Kidneypunch
    Ethan
    2021 TRD Sport
    On the aluminum it looks like there are two small ports side by side but those are mounting points for something else. They are threaded holes. The last hole you see that are in the same spot on both parts is the installation point for the coolant temp sensor. I recommend changing that if you’re gonna do this job. It’s like a $20 part.
  9. Jul 5, 2025 at 11:45 AM
    #249
    GaMGMTaco
    GaMGMTaco Well-Known Member
    Billy
    NE Georgia
    23’ MGM TRD OR DCSB 4x4
    can you give the part# you used? I can’t find it. Maybe I’m blind.
  10. Jul 5, 2025 at 12:28 PM
    #250
    Kidneypunch
    Ethan
    2021 TRD Sport
    If you go in from the top you’ll need the set of three DI seals per injector and the upper and lower intake manifold gaskets.
    I used a cap from the auto parts store to cap off the smaller port and a “LS Swap” silicone elbow cut to shape with an aluminum union to make it all fit.
    The torque spec is 13lbs for the joint.
    GaMGMTaco and JmsWms like this.
  11. Jul 5, 2025 at 7:59 PM
    #251
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    @Kidneypunch any pics of the parts used to modify the joint?
    And good looking out about the injector seals. I'm planning to pick up the lexus crossover pipe and seals, and install them when I pull the intake to install a manifold spacer. Figure make it all one job, might do my plugs at the same time.
  12. Jul 6, 2025 at 1:07 AM
    #252
    Kidneypunch
    Ethan
    2021 TRD Sport
    I should tell you this is not a part that is easily installed as a “might as well while I’m in there”.
    I believe the manifold spacer is installed on top of the lower manifold. To access this part the lower manifold and lower fuel rails and many other little support brackets need to come off. Plus you may need to remove the passenger side down pipes to reach the bolts on the bottom because that outlet sits right above the lower bolt to install the bypass joint.
    Also get the MLS gaskets
    JmsWms and Toy_Runner[QUOTED] like this.
  13. Jul 17, 2025 at 8:03 AM
    #253
    shadesbro
    shadesbro Well-Known Member
    noted for future need
