Aluminum replacement for plastic rear coolant bypass joint
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jowett, Jan 5, 2021.
  1. Aug 24, 2021 at 8:27 PM
    #41
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    Well, at least you could then do the timing cover at the same time.
    Grossomotto likes this.
  2. Aug 25, 2021 at 5:26 AM
    #42
    NC_Pinz
    NC_Pinz Well-Known Member
    North Carolina
    2018 Cavalry Blue TRD Pro
  3. Aug 25, 2021 at 6:06 AM
    #43
    Summitroad
    Summitroad Well-Known Member
    Northen CA
    TRD OR 4X4
    That is correct, I just got mine done, the intake manifold was removed to get acces. The replacement still is plastic.
    The Lexus uses an aluminium one.
    IMHO, This is one of the many things that Mike Sweers have done to this trucks, decreasing their QDR.
    02Duck likes this.
  4. Aug 25, 2021 at 6:48 AM
    #44
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    @Jowett did you get this installed? Would be interested in any feedback. I may actually get this for the inevitable down the road when my clutch, timing cover goes and do everything at once, may even put on solid motor mounts.
    su.b.rat and shotgunbilly420 like this.
  5. Aug 25, 2021 at 7:55 AM
    #45
    Jowett
    Jowett [OP] Well-Known Member
    Brian
    North Adams, MA
    It's bolted up and has a 90 elbow inserted. I'm trying to locate the same elbow in Stainless.... I have not yet run it, but can't see any issues. I'm also looking at having a new piece cast with the port in the proper place.
  6. Aug 25, 2021 at 8:06 AM
    #46
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    If you get a part made, I'm in.
    rannon, su.b.rat, Grossomotto and 2 others like this.
  7. Aug 25, 2021 at 8:10 AM
    #47
    BDSKJChris
    BDSKJChris Well-Known Member
    Albany, NY
    2019 Quicksand TRD OR DCSB
    You may not want to use a stainless elbow and Stainless and Aluminum together can easily cause galvanic corrosion, unless the stainless were passivated.
  8. Aug 25, 2021 at 8:12 AM
    #48
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Good catch.
    shotgunbilly420 likes this.
  9. Aug 25, 2021 at 8:44 AM
    #49
    Caligula
    Los Angeles, CA
    Pics of the install?
    I don't need it immediately, but I would buy one regardless if this was available.
  10. Aug 25, 2021 at 10:12 AM
    #50
    Jowett
    Brian
    North Adams, MA
    Good to point out! I am already thinking a nice hard anodized coating for the bypass joint will do the trick. That will produce a true lifetime part.
    I'll grab pics asap.
  11. Aug 25, 2021 at 10:45 AM
    #51
    BDSKJChris
    Albany, NY
    I still have a heater core from a jeep liberty BNIB, so suffice to say, if you bring a solid replacement part to market I will buy it.
    Ngneer likes this.
  12. Aug 25, 2021 at 10:48 AM
    #52
    Grossomotto
    2017 4WDV6LB6MT
    This will push my growing mod queue out to 2024
    Junkhead, su.b.rat and Skydvrr like this.
  13. Aug 25, 2021 at 7:45 PM
    #53
    MegaHurts777
    MegaHurts777 Well-Known Member
    Jacob
    ID
    2019 Tacoma TRD Off-Road (MT)
    Is it just me, or does it appear that you have to un-do the lines going to the direct injectors (if you go the 'taking the intake apart' method)?
    I think I heard, but would have to confirm, that if you undo that line you're supposed to just replace the whole thing.
    Hopefully Toyota updated the part as I haven't heard of much issues with 2018 and up, and I have a 2019 :fingerscrossed:.
    Ngneer likes this.
  14. Aug 25, 2021 at 7:52 PM
    #54
    Caligula
    Los Angeles, CA
    Jesus, I hope youre mistaken. Sounds like another extraneous part on a truck that I should have not gotten involved with.
    Ngneer likes this.
  15. Aug 29, 2021 at 10:19 PM
    #55
    MegaHurts777
    Jacob
    ID
    For what it's worth, I just noticed that my wifes car (which hopefully will be replaced at some point soon) has a plastic T-Stat housing.
    https://www.rockauto.com/en/moreinfo.php?pk=1057952&cc=1441219&pt=10337&jsn=496
    It's a 2008 with about 120k on it.
    Sadly the T-Stat isn't doing so hot (failed open) and it's also time to replace allllll the coolant hoses as they are 13 years old.
    Coming full circle, if Toyota hopefully updated that part on the back of the engine...it might last a decent amount of time. :fingerscrossed:
    Same goes for a few other plastic coolant parts.
    Nice thing is, with the Tacoma if there's a serious issue there's usually a solution either from Toyota or after market.
  16. Oct 15, 2021 at 7:27 AM
    #56
    su.b.rat
    su.b.rat broken truck
    so how's it going with this? have you progressed?
    Junkhead and Skydvrr like this.
  17. Oct 15, 2021 at 7:48 AM
    #57
    Jowett
    Brian
    North Adams, MA
    Unfortunately, nothing further.
  18. Oct 15, 2021 at 3:33 PM
    #58
    su.b.rat
    oh well, I'll just chill out and hope nothing bad happens. like with everything else. have a weekend! :rasta:
  19. Nov 18, 2021 at 6:00 PM
    #59
    slapntz
    slapntz Well-Known Member
    Any chance of this progressing? Would love to do this when I install my maggy
  20. Jan 22, 2022 at 2:47 PM
    #60
    111R
    111R Well-Known Member
    Any word on if the 2022 model year coolant pipes are improved over previous years? My Tacoma is on order, so I was just curious.
