Aluminum running boards hardware help?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 908tacoma, Jan 25, 2022.
  1. Jan 25, 2022 at 12:17 PM
    908tacoma
    908tacoma [OP] Well-Known Member
    New Jersey
    2018 MGM
    OME, SPC, TRD
    I am trying to install aluminum running boards but the hardware included (13mm bolts) don’t seem to want to go into the body? Is 13mm is used on the oval step bars ? I am using the right mounting holes but each bolt only wants to go halfway, if that? :mad::confused:
  2. Jan 25, 2022 at 12:22 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    I encountered the same problem. I cleaned out the hole and sprayed some wd-40. Make sure you have the correct thread and length.
    908tacoma[OP] likes this.
  3. Jan 25, 2022 at 12:29 PM
    908tacoma
    New Jersey
    2018 MGM
    OME, SPC, TRD
    What’s the correct thread and length? I’m hoping rust isnt an issue also.
  4. Jan 25, 2022 at 12:33 PM
    Tacomike18
    J
    I can check when I get home, I have a box of these bolts and nuts.
  5. Jan 25, 2022 at 2:56 PM
    908tacoma
    New Jersey
    2018 MGM
    OME, SPC, TRD
  6. Jan 26, 2022 at 12:15 PM
    Tacomike18
    J
    M8x1.25 is the thread size I believe
