Aluminum skid plate build
Discussion in '1st Gen. Tacomas (1995-2004)' started by mrfish27, Mar 15, 2016.
  1. Mar 15, 2016 at 7:53 PM
    mrfish27
    mrfish27 [OP] MrFish27
    Sonoma County, CA
    Horatio: 99 Tacoma
    Air lockers, RTT, aluminum armor, lithium 2nd battery
    I purchased a RAT Products 1/8" steel skid plate from this site, and it works well. Last fall I hit a rock on the trail and put a good dent in the cold rolled steel with no damage to my rig.
    Issues with the RAT skid: it's heavy and hard to get on and off; it doesn't mate easily and elegantly to my Relentless aluminum plate front bumper; the side panels make it difficult to clean, installed, at the car wash. So I decided to build an aluminum version.
    Design parameters:
    Shape similar to RAT skid
    Keyhole under engine mounts
    1/4" aluminum to reduce weight
    Fitted to my aftermarket bumper
    No side panels to allow easier cleaning at the car wash
    No oil drain opening (nice in theory but messy in practice)
    RAT skid on the bench, design in progress:
    Wat3rdog and Minny Taco like this.
  2. Mar 15, 2016 at 7:56 PM
    mrfish27
    Sonoma County, CA
    Horatio: 99 Tacoma
    My approach is to build an MDF version, get the tweaks worked out, then start cutting metal.
  3. Mar 15, 2016 at 7:57 PM
    mrfish27
    Sonoma County, CA
    Horatio: 99 Tacoma
  4. Mar 15, 2016 at 8:02 PM
    mrfish27
    Sonoma County, CA
    Horatio: 99 Tacoma
    Layout is always fun.
  5. Mar 15, 2016 at 8:05 PM
    mrfish27
    Sonoma County, CA
    Horatio: 99 Tacoma
    Where do I get my curves from? Whatever is handy.
  6. Mar 15, 2016 at 8:08 PM
    mrfish27
    Sonoma County, CA
    Horatio: 99 Tacoma
    After cutting and shaping the MDF, I taped the fours panels together and installed the floppy unit on the rig.
  7. Mar 15, 2016 at 8:17 PM
    mrfish27
    Sonoma County, CA
    Horatio: 99 Tacoma
    Now I have all the angles of the new skid. I just have to save them on the template. Hot glue and scraps did the trick.
    Wild Crow likes this.
  8. Mar 15, 2016 at 8:20 PM
    mrfish27
    Sonoma County, CA
    Horatio: 99 Tacoma
    The MDF version completed.
  9. Mar 15, 2016 at 8:26 PM
    mrfish27
    Sonoma County, CA
    Horatio: 99 Tacoma
    One of the things I like about aluminum is that you can cut it with woodworking equipment, which I have. I use beeswax for lubrication.
  10. Mar 15, 2016 at 8:30 PM
    mrfish27
    Sonoma County, CA
    Horatio: 99 Tacoma
    Aluminum pieces after shaping. Some cleaning and they are ready to tack together.
  11. Mar 15, 2016 at 8:35 PM
    mrfish27
    Sonoma County, CA
    Horatio: 99 Tacoma
    I used a bevel gauge and tacked carefully to make sure I preserved the shape of the MDF unit.
  12. Mar 15, 2016 at 8:38 PM
    mrfish27
    Sonoma County, CA
    Horatio: 99 Tacoma
    After a few beads I could test the fit.
    RelentlessFab likes this.
  13. Mar 15, 2016 at 8:41 PM
    mrfish27
    Sonoma County, CA
    Horatio: 99 Tacoma
    Then back to the welding table for lotsa beads. A final fit before paint.
    Wild Crow and AR15xAR10 like this.
  14. Mar 15, 2016 at 8:44 PM
    Tdkrum5
    Tdkrum5 New TRD OR P
    Ted
    Oly, Wa/Sun City West AZ.
    2024 TRD OR P
    New ride 2024 TRD OR. Old ride 2014 Icon Stage 5, 265/75/16 BFG AT KO2, Fuel wheels, KMFB sliders,BAMF trilogy skids, Baja Design Squadron Sport WC
    You are quite the craftsman I can see. Nice tools. How much do you think you will save in weight? Will this provide you the protection as the steel one did during your last hit?
  15. Mar 15, 2016 at 8:49 PM
    mrfish27
    Sonoma County, CA
    Horatio: 99 Tacoma
    Thank you.
    RAT unit is 39 lbs; my version is 26 lbs.
    I hope so.
    AR15xAR10 likes this.
  16. Mar 15, 2016 at 8:55 PM
    Tdkrum5
    Ted
    2024 TRD OR P
    Sweet, it does look very nice. Like to see pictures when bolted in place.
  17. Mar 15, 2016 at 8:57 PM
    mrfish27
    Sonoma County, CA
    Horatio: 99 Tacoma
    Paint in progress. Should get a final installed picture up in a few days.
  18. Mar 15, 2016 at 9:10 PM
    Looiz
    Looiz Well-Known Member
    Los Angeles
    95.5 RegCab
    ...blank canvas...
    Very Cool. Is that an extra set you cut out? Can I have it? :drool:
  19. Mar 19, 2016 at 6:11 PM
    mrfish27
    Sonoma County, CA
    Horatio: 99 Tacoma
  20. Mar 19, 2016 at 8:35 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    looks good, dont you love how much noise it makes cutting alu on a table saw? also nice table saw setup.
    on my last one i did that needed a bend, to cut down on welding, i did a releafe cut on the backside which allowed me to bend by hand(ish) then weld up that seam.
