Aluminum Third Brake Light, KC Cyclones, Bolt On, No Drill
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Grossomotto, May 8, 2021.
  1. May 11, 2021 at 6:52 PM
    #41
    Shaggy1215
    Shaggy1215 Well-Known Member
    2021 mean green taco
    Dude they are looking badass
    Grossomotto[OP] likes this.
  2. May 11, 2021 at 7:32 PM
    #42
    Grossomotto
    Grossomotto [OP] Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Thank you sir, they're coming out exactly as I expected. It may not look like it, but there's 26 pieces to these that have to fit perfect. Hope to have this completed, painted, wired and on the truck Wed or Thurs.
    Aqualoon and jcmotr like this.
  3. May 12, 2021 at 5:05 AM
    #43
    rjmart34
    rjmart34 Member
    2015 Tacoma 4x4 Limited
    Stock
    Looking forward to placing my order!
  4. May 12, 2021 at 4:53 PM
    #44
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    Need a 3rd gen DC one :thumbsup: Either pre wired with lights, or buy my own lights/wire myself. Doesnt matter to me
  5. May 12, 2021 at 5:29 PM
    #45
    awynne56
    awynne56 Well-Known Member
    Andy
    2019 Taco trd sport
    front grill pro
    Hey all not to hijack but I can seem to get a clear answer if I have the meso 3rd brake light and cyclones I just cut the Oem wiring and splice this in right? Ps great job glad someone is adding to the options of third brake lights
  6. May 12, 2021 at 5:38 PM
    #46
    Shaggy1215
    Thats my understanding
  7. May 12, 2021 at 5:42 PM
    #47
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    There is no better option at this point in time. Color-wise on the DC, white/black is ground, green should be cargo lamp and purple brake but probe to confirm.
    Skydvrr likes this.
  8. May 12, 2021 at 5:50 PM
    #48
    awynne56
    Andy
    2019 Taco trd sport
    front grill pro
    That’s what I thought. . Didn’t know if there somebody made a plug and play setup yet. Thanks for all the quick responses
  9. May 12, 2021 at 5:59 PM
    #49
    daveeasa
    David
    PNW
    Lots and lots of chatter and evaluation. The hangup is that TE who makes the female connector only makes a wire-to-board male, not a wire-to-wire male. So for plug and play we either need to build a board to use their connector, have a mating connector made, or inject the terminals directly with heat shrink to avoid them touching each other and somehow wrap with tape or goop to secure the whole thing which would no longer really be plug and play, it'd be connect once and pray.
    Given the headache and costs (dumb wire-to-board with 4 screw terminals is $9 for a run of 100) it would appear that the best option is to cut the connector. For those truly interested you could use a 3 pin JST male and female as quick disconnect, but doubling up on the cyclone (they are 18 gauge?) is hard with JST pins. Probably better to go 090II connectors (same as the head unit uses) or a different TE 3 pin, there might even be one which uses the same terminals so you could de-pin and re-pin but since the whole idea is you do this once and you're done, quick disconnect seems like a total waste of time, just butt connector or solder and heat shrink it and forget about it.
    Skydvrr and Grossomotto[OP] like this.
  10. May 12, 2021 at 6:39 PM
    #50
    Grossomotto
    2017 4WDV6LB6MT
    Yes, you can use the cyclone wiring and the oem plug to wire these up, it's pretty easy. That'll be what I'll have to start, a bare assembly and you put in your cyclones, wires. Aceess Cab (3 light openings) will be first (next week) and Double Cab (4 light openings) will be a couple weeks, there's a bit more involved with DC.
    Dave @daveeasa, @kmorgan3, @Puppypunter and @caribe makaira are working on a complete harness and I'll wire these with Cyclones and it'll be plug and play. Priced accordingly since lights are $30 each. That'll be a few weeks and you can order it complete with lights ready to go. A huge thank you to these four guys for all of their genius.
    Tonight I just finished the plates, which I had to mill down, the band saw nor plasma cutter was forming that well. The mill worked great, I primered tonight and will put this on the truck for pics tomorrow.
  11. May 12, 2021 at 6:55 PM
    #51
    HelloFelix
    HelloFelix Well-Known Member
    Felix
    Las Vegas
    2017 MGM 4x4 OR Tacoma
    How and where can I place a preorder?
  12. May 12, 2021 at 7:28 PM
    #52
    Grossomotto
    2017 4WDV6LB6MT
    Let me get everyone that showed interest and committed in this thread and I'll put everything in the first post tomorrow, along with you.
    Really want to get this on my truck tomorrow with pics so everyone can see exactly what it looks like. It's a nice functional aluminum assembly with the kc cyclones.
    Malvolio, rmreid20, su.b.rat and 4 others like this.
  13. May 13, 2021 at 10:29 AM
    #53
    Grossomotto
    2017 4WDV6LB6MT
    Got it painted at least one coat (no clear coat), wired and installed. Everything looks great and works just as I expected.
    Here's pics, I'll have to get some at night and still wiring the cargo light to the overhead switch. The paint is not perfect since I rushed it this morning to get it up. The two screws holding it to the cab will be black 1/4" hex with rubber washers, you'll use an open wrench on the side, I quickly painted a couple black that I had on hand.
    These are difficult to wire initially, so I have to figure out a couple things with wiring them up if I'm selling these bare assembly at first.
    This sits about 1/2" under the roof line and is about 1.8" out from the back of the cab.
    jcmotr, HelloFelix and tonered like this.
  14. May 13, 2021 at 10:30 AM
    #54
    Grossomotto
    2017 4WDV6LB6MT
    Brakes on
    Brakes off
  15. May 13, 2021 at 10:32 AM
    #55
    Grossomotto
    2017 4WDV6LB6MT
  16. May 13, 2021 at 11:06 AM
    #56
    Grossomotto
    2017 4WDV6LB6MT
    I've figured it out, the three holes out the back for wiring have to be bigger and right under the top of the gasket. It'll be easy to wire and all bullets connectors will be able to be pulled out so you can change out a Cyclone light if needed without taking off the assembly. This is important since it's a double sided adhesive gasket like the oem and if the assembly comes off you need to a new gasket which I'm trying to avoid.
    rmreid20, HelloFelix and daveeasa like this.
  17. May 13, 2021 at 11:43 AM
    #57
    caribe makaira
    Caribbean, Puerto Rico
    Night pic later?:popcorn:
  18. May 13, 2021 at 12:24 PM
    #58
    Grossomotto
    2017 4WDV6LB6MT
    Yeah, I'll at least have it for the brake lights. I'm trying to get to the cargo wired today, I know it's 500 lumens, so it'll be a lot of much needed light for the bed.
  19. May 13, 2021 at 6:58 PM
    #59
    Grossomotto
    2017 4WDV6LB6MT
    Got the cargo light installed, works perfect, this is before dark.
    This is the bed with 800 lumens of 2 VLED puddle lights
    This is the bed with 500 lumens of 1 KC Cyclone
    jcmotr and daveeasa like this.
  20. May 13, 2021 at 8:14 PM
    #60
    Grossomotto
    2017 4WDV6LB6MT
    Updated the first post
