Always in "Sport" Mode...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 4Cylinders, Aug 12, 2024.
  1. Aug 12, 2024 at 2:28 PM
    4Cylinders
    4Cylinders [OP] Well-Known Member
    Anthony
    2023 Tacoma 2.7L 4x4 Auto
    2023 2.7L 4x4 Auto
    I'm currently at 6,500 miles on my new truck and I do mostly city driving under 45mph. The truck likes to slide into 5th gear and it's killing me. I live in a hilly area and 3rd and 4th are where I need to be.
    I find myself using S4 and S3 very often as a gear limiter to prevent the up-shifting. I know I can get a tune to help with the shifting but S4 and S3 solve my problems perfectly.
    My question is whether or not it's okay to constantly use these modes and almost never use "D". I want to keep this truck forever and put a ton of miles on it. I don't want to find myself with a toast transmission at 100k because of this...
    Is there anything I should be concerned about here?
    Thanks in advance.
  2. Aug 12, 2024 at 2:37 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Transmission will be 100% fine doing what you’re doing. Actually, it will be better off doing that than constantly shifting on its own back and forth.
    Vmax540, that180guy, G2.M6 and 4 others like this.
  3. Aug 12, 2024 at 3:19 PM
    Clearwater Bill
    Billy
    Largo Florida
    The engine may be a bit happier too, as you're less likely to cause a lugging situation.
    Vmax540, G2.M6, Chew and 1 other person like this.
  4. Aug 12, 2024 at 3:28 PM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    I would recommend against using all the time .toyota engineers designed this for a temporary use .. towing …hills …and such .over time it will learn your driving habit .
  5. Aug 12, 2024 at 3:35 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Although I see nothing wrong with using s-mode that way, I can offer you an alternative. If you want your automatic transmission to downshift, push the skinny pedal hard or blip it (hard on then mostly back where you started). The sudden throttle input will cause the transmission to downshift as faster or faster than I can with my manual transmission.
    You bought an automatic transmission so it could shift for you. Let it do that for you.
    Topanga Taco likes this.
  6. Aug 12, 2024 at 3:38 PM
    4Cylinders
    Anthony
    I have noticed this, actually. It's useful when I forget to use S4 or S3...but using those modes eliminates my need to do that and driving the truck is much easier that way.
  7. Aug 12, 2024 at 3:40 PM
    4Cylinders
    Anthony
    I've heard that the truck will learn my habits but, after 6,500 miles, it hasn't really adjusted much. I drove about the first 5,500 miles in "D" exclusively hoping that it would learn but it still grabs 5th gear at the worst times.
    Can you tell me where it says it's only intended for temporary use? I checked through the manual and online and I couldn't find much on this subject. Thank you.
  8. Aug 12, 2024 at 3:41 PM
    4Cylinders
    Anthony
    This is definitely true. The 2.7L definitely lugs when in 5th under 45mph in hilly areas. I imagine that could cause problems in the long run.
  9. Aug 12, 2024 at 3:44 PM
    waffleiron
    waffleiron Well-Known Member
    Washington
    No they didn't and no it doesn't. The trucks control parameters are setup to provide the most fuel efficient drives while usin the D.
  10. Aug 12, 2024 at 3:44 PM
    BLtheP
    Plano, TX
    Seriously, there are no concerns. The idea that it is only for temporary use is unfounded. They wouldn’t give the option to you if they wanted you to limit your use of it. Otherwise there would at least be a large disclaimer somewhere.
    Personally, I don’t like the just push the pedal harder option either. Modern automatics are programmed super lethargic much of the time and it is exhausting feeling like you have to floor it constantly to get it to downshift an adequate number of gears. Easier to just slap it over and limit it to the desired gear. But, all of that is probably why I don’t buy autos anyways so maybe my input isn’t helpful.
  11. Aug 12, 2024 at 3:45 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Have you tried leaving it in “D” with the ECT button on?
    kahanabob likes this.
  12. Aug 12, 2024 at 3:46 PM
    BLtheP
    Plano, TX
    They don’t learn much. The loaner I borrowed at low mileage didn’t drive any differently from the day I picked it up to the day I turned it in with 2k more miles, and I drove it much differently than how the stock programming wanted it to drive.
    And the idea that it’s only for temporary use definitely isn’t true at all.
  13. Aug 12, 2024 at 3:47 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Pretty sure all it does is limit the highest gear the transmission will use, everything else remains the same. There’s no risk or harm in being in S4 all the time.
    4Cylinders[OP] and Chew like this.
  14. Aug 12, 2024 at 4:41 PM
    bgavin
    bgavin Well-Known Member
    Orangevale, CA
    2023 Tacoma Access Cab, V6, 4WD, A/T, OTT Medium/Spicy
    CURT Mfg front receiver, anti-theft cages around cats
    I drive my stock 2023 in ECT mode all the time.
    I'm fed up with the chronic hunting it does in non-ECT mode.
    Most of my town driving is 50 mph or less.
    ECT shifts into 4th gear right at 40 mph with my driving habits.
    This keeps it in 1,2 or 3 for most of the time, with less shifting.
  15. Aug 12, 2024 at 4:52 PM
    pdxTacoSR5
    pdxTacoSR5 Well-Known Member
    PDX area
    2018 Tacoma SR5, V6 Auto, Access Cab, 4x4, Silver Sky Metallic
    i believe i read this on this forum years ago, so 50/50 chance it is true.
    the driving behavior that is learned is only learned in "D". no learning goes on when using "S" mode.
    I use "S" mode like you since i live in hilly area. We both really want an MT. "S" mode is a very poor man's MT but better than "D".
  16. Aug 12, 2024 at 5:32 PM
    4Cylinders
    Anthony
    This was my initial thought as well. If it's there and I'm only supposed to use it for small amounts of time, I think they would have made that more obvious somehow.
    All of my other cars are MT so I agree with you on that. I really do like the auto in my truck despite this 5th gear issue though.
    BLtheP[QUOTED] likes this.
  17. Aug 12, 2024 at 5:34 PM
    4Cylinders
    Anthony
    Yes, I have used the ECT button mostly when merging on the highway or in other "maximum acceleration" situations. I find that it holds onto gears a bit too long for my liking during normal driving even with very little pedal input. I only use the ECT button for short periods of time when I need to accelerate quickly and I need everything from the engine. Then I turn it off.
    Topanga Taco and TA2016[QUOTED] like this.
  18. Aug 12, 2024 at 5:36 PM
    4Cylinders
    Anthony
    This is what I originally thought too. I use it as a limiter and the truck seems happy. But I wasn't sure if it could cause long term issues.
  19. Aug 12, 2024 at 5:37 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    Same here, i have the mod "ECT on at start up"
    vprgts likes this.
  20. Aug 12, 2024 at 5:38 PM
    4Cylinders
    Anthony
    This is interesting. Thanks for your input. I've tried normal driving in ECT mode but it holds onto gears (especially 1 and 2) for too long even with very light throttle input. I like how it shifts through the higher gears though. I end up just using the ECT button when I need to accelerate as quickly as possible. Then I turn it off.
