Always in "Sport" Mode...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 4Cylinders, Aug 12, 2024.
  1. Aug 12, 2024 at 5:39 PM
    4Cylinders
    4Cylinders [OP] Well-Known Member
    Anthony
    2023 Tacoma 2.7L 4x4 Auto
    This sounds right to me. S4 holds onto first gear longer than D in my truck. S4 also shifts into 4th sooner than D for me. S4 feels more natural to the truck whereas D feels "tuned" to my habits. I think you're right about this.
  2. Aug 12, 2024 at 5:46 PM
    Dbarffish
    Dbarffish Well-Known Member
    Doug
    Montana
    2024 dcsb TRDOR blue crush
    Stock
    To me it seems easier to use the accelerator pedal to encourage a shift up or down when in ECT. Like non learning ATs of old.
    gudujarlson and kahanabob like this.
  3. Aug 12, 2024 at 10:42 PM
    PTSDTherapy
    PTSDTherapy Well-Known Member
    22 SR5 DCSB
    2022 SR5 new in December of 22. 179483 miles. Been in s mode entirely since around 7k miles when I had it tuned. It’s not for temporary use.
    cropduster78 and Gen3TacomaOBX like this.
  4. Aug 13, 2024 at 5:48 AM
    4Cylinders
    Anthony
    Wow! That's a lot of S Mode driving. Thanks for chiming in. How do you use S Mode? In town driving or on the highway too? Also, what tune do you have?
  5. Aug 13, 2024 at 12:54 PM
    Topanga Taco
    Topanga Taco BUZZING NITRO
    Rick
    Topanga Strong Southern California
    2018 SR5 4x4 DCSB Harrop rear E-Locker
    The Magic of ALSD RCI-skid RAS-Sumos Bilstein 6112/5100
    :evil: Hometown ain’t lying, thee whole truth and nothing but!
  6. Aug 13, 2024 at 12:55 PM
    Topanga Taco
    Rick
  7. Aug 13, 2024 at 1:28 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I do not think that is true. The owners manual says s-mode is for engine braking. That also matches my intuition. You can certainly use it for other things.
  8. Aug 13, 2024 at 2:00 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    I agree, this is not true at all or there would be all sorts of warnings in the manual written by these mysterious "Toyota engineers".
    OP:Use auto-auto or fake-auto (S mode) and you and your gear box will be fine.
    4Cylinders[OP] likes this.
  9. Aug 13, 2024 at 2:11 PM
    gudujarlson
    Minnesota
    I will say that using s-mode constantly to hold the truck in a lower gear under normal driving conditions will cause increased gasoline usage, noise pollution, and wear on the engine. The same is true of leaving a manual in a gear higher gear than necessary. It’s not likely to grenade the engine though… unless taken to extreme excess.
    Internal combustion engines are generally most efficient at low rpm and high load.
    https://www.youtube.com/watch?v=iNspNdVkslA
  10. Aug 13, 2024 at 2:32 PM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    FWIW.. I spend the great majority of my time in Sport/Manual mode with my 2018 Tacoma SR 3.5L 4x4 automatic. I have 110,000 miles with approx ~18k of that towing and the truck still feels fresh/tight.
  11. Aug 13, 2024 at 2:35 PM
    Gen3TacomaOBX
    S
    You're averaging 90k miles a year?! impressed.
  12. Aug 13, 2024 at 2:45 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    The extra oil pressure from higher rpm, combined with the lesser load from the gearing that results in the higher rpm, should pretty much make any concerns about wear or longevity null and void.
  13. Aug 13, 2024 at 2:49 PM
    gudujarlson
    Minnesota
    Higher rpm results in higher piston speeds, bearing loads, heat, etc., but yes I agree it could be a wash if the rpm is not excessive
  14. Aug 13, 2024 at 2:59 PM
    bgavin
    bgavin Well-Known Member
    Orangevale, CA
    2023 Tacoma Access Cab, V6, 4WD, A/T, OTT Medium/Spicy
    CURT Mfg front receiver, anti-theft cages around cats
    I bought an automatic trans because I was forced to buy one.
    pdxTacoSR5 likes this.
  15. Aug 14, 2024 at 6:25 AM
    #35
    4Cylinders
    Anthony
    This is great information. Thanks for chiming in. How do you use S Mode? Just in town or on the highway too?
  16. Aug 14, 2024 at 6:31 AM
    #36
    4Cylinders
    Anthony
    What you're saying would be true if I was driving around at 40mph in 2nd gear constantly. However, I'm rarely spinning much higher than 2,000rpm in any gear around town which I assume would be better for the engine than lugging at 1,100rpm up a hill before the transmission decides to downshift. Engines hate being lugged so the extra momentum in the block can actually prevent wear and tear in the long run as long as the RPM isn't excessive like you said.
    My question was about whether or not the transmission is designed to be driven in this mode constantly. I think we can all agree that the engine is probably much better off with a reasonable amount of extra momentum to prevent lugging even if it marginally hurts MPG's.
  17. Aug 14, 2024 at 8:01 AM
    #37
    Gen3TacomaOBX
    S
    Highway also. I'm carrying an additional ~400 lbs in armor/cap/winch/tools and don't have a tune. Even with 4.88 gears I prefer to choose my own shifting (I'm 6 years in.. so I don't even have to think about it.)
  18. Aug 14, 2024 at 8:11 AM
    #38
    bgavin
    Orangevale, CA
    ECT mode on my stock 2023 shifts into 4th at 40 mph.
    As long as I stay below 40, I avoid that last up shift.
    This shift at 40 winds up a bit more than 1,2,3 do.
    It shifts into 4th around 2600 rpm on the analog factory tach, then drops to 2000 at 40 mph.
    In my head, this seems right, so the rpm is still in the bottom of the engine torque range after the shift into a higher gear.
    This would seem appropriate especially when towing.
  19. Aug 14, 2024 at 9:02 AM
    #39
    BTL Y-Wing
    BTL Y-Wing Well-Known Member
    2020 Army Green TRD Pro
    I basically run in S6 now by default. With a tune on the truck it is much nicer to drive in S6 then D (even more of a difference than stock tune), and you can command it to downshift to 5th or 6th when needed for merging onto highways or going up steeper slopes.
  20. Aug 14, 2024 at 9:39 AM
    #40
    Jerry311SD
    Jerry311SD Well-Known Member
    Jerry
    Ramona Ca SAN DIEGO
    2019 tacoma TRD Quicksand
    KDMaxx tune K&N drop in AFE catback Oil catch can Bill's 6112/5160 Dynomat whole inside of cab TRD skid plate
    I also live in a hilly area and to and from work Im always in S4 or S5. I dont use the 6th gear untill im on the freeway and its flat. The 6 speed auto trans in these trucks suck.
