Always listen to TW members!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tundrataco, Apr 13, 2013.
  1. Apr 13, 2013 at 3:13 PM
    tundrataco
    tundrataco [OP] Well-Known Member
    eastern townships, quebec
    front bilsteins 2.5" lift, rear aal 2.5" lift, flowmaster 40 series muffler, kenwood headunit, ultraguage, allpro bolton sliders
    so, before i went and bought my new aftermarket headlights (blacked out inside) for my 07 taco, i came to you guys to see what you thought. and immediately someone said, no problem the headlights are as good as or better than oem as specified, but they suggested to silicone around the lenses before installation.
    i did not listen to this warning, i recieved the headlights, and installed them. fit and looked great!
    2 weeks later, i notice fog in one light, im like ahh crap... the next day, a pool of water in both headlights. had to remove both, not that hard. was able to take them inside, use a hair dryer on medium heat, that removed most of the moisture right away. then luckily i had my wood stove going, took out plugs in the headlights and sat them 4 feet from the stove, when i turned the lights upright, literally a pool of water came out. with closer inspection, noticed there were 2 spots on BOTH lights that had silicone but not close enough to seal the lens, there was a 1/8 gap the whole bottom length of each light.
    seller on ebay was very helpful and was willing to replace them free, but could not guarantee the next wouldnt be the same.
    so i put clear waterproof silicone all around the lights when they were dry, just like i should have in the first place, no headache....
    LISTEN TO THE TW MEMBERS!!! they know what theyre talking about!
    thanks guys!
  2. Apr 13, 2013 at 3:20 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    shouldn't use silicone to seal headlights
    silicone oil outgasses over time, and hazes things up
    after a few years
  3. Apr 13, 2013 at 3:21 PM
    ToyotaTacoma4Ever
    ToyotaTacoma4Ever Get Boosted
    Eric
    Alberta
    Supercharged Tacoma Sport
    Check Out The S/C Build
    You usually learn the lesson only once lol
  4. Apr 13, 2013 at 3:29 PM
    tundrataco
    see another lesson already lol! damnit.. well i guess ill spend another 100$ for new headlights in a couple years then...
  5. Apr 13, 2013 at 5:28 PM
    NorthWoods
    NorthWoods Well-Known Member
    Seacoast NH
    '15 TRD OR SW
    What would be better? Epoxy maybe?
  6. Apr 13, 2013 at 6:47 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Urethane sealant.
  7. Apr 14, 2013 at 7:19 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    no use headlight or glass-specific seals
  8. Apr 14, 2013 at 7:26 AM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    I need to do this to mine but I don't wana deal with it
  9. Apr 14, 2013 at 7:27 AM
    SoCalTacos
    SoCalTacos Turd runner
    socal
    2017 4Runner TRD Pro
    Led head/dtr lights.
    Bubble gum.
  10. Apr 14, 2013 at 7:30 AM
    BAMFTACO
    Juan
    Kings bruh
  11. Apr 14, 2013 at 12:09 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Using GE silicone II many times, I have NEVER had 1 leak and NEVER had 1 problem with offgassing.
    After using the silicone, u should leave all bulbs and drain tubes/caps off for a few hours (I always gave them 24hrs to offgas).....then install the harware.
    Times may vary....like I said, I waited 24hrs but that's because I wasn't in a hurrry and was more focused on curing and no hazing.
    GE silicone II is perfectly fine to use........ YMMV depending on how long u wait for it to cure.
    I've used it on retrofits, and even simple bhlms with halogen and/or HIDs
  12. Apr 14, 2013 at 12:18 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    I wish OP's statement was true of all TW members.
