Always on power outlet relay - *modified*
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by ramonortiz55, Dec 26, 2015.
  1. Dec 29, 2015 at 2:22 PM
    Benson X
    Benson X My build thread sucks...
    Ben
    Olympia, WA
    '11 MGM DC/LB
    If you don't draw blood, you're doing it wrong!
    I just shoved a piece a rubber wedge under the contact to make it a closed loop.
    Clean, simple, free.
    But, as we all know, some people would rather pay than do anything themselves. So GLWS! :thumbsup:
    Fastbilly5 likes this.
  2. Dec 29, 2015 at 2:24 PM
    ramonortiz55
    ramonortiz55 [OP] Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    True! That's why I posted this one for sale.
    I used to do the same thing. Shove a plastic wedge in there. A few aren't comfortable with it, but you and I know it works either way.
  3. Jan 4, 2016 at 8:07 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Whatever happened to mine Ramon?
  4. Jan 4, 2016 at 8:08 PM
    ramonortiz55
    Ramon
    Texas
    stock
    dealer had to order it:annoyed:
  5. Jan 4, 2016 at 8:09 PM
    ramonortiz55
    Ramon
    Texas
    stock
    ill go check on them tomorrow
  6. Jan 8, 2016 at 12:22 PM
    ramonortiz55
    Ramon
    Texas
    stock
    I have one for you.
    PM me your address brotha
  7. Jan 8, 2016 at 10:19 PM
    rhc0930
    rhc0930 Well-Known Member
    Houston
    14' TRD Sport 4x4
    3 Inch Lift 33 Inch Tires Subs Tint
    Where and when do you want to meet up. I'm free after the Texans game on Saturday.
  8. Jan 11, 2016 at 12:36 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Roman I know you just got married, and Congrats. Just got my relay today and I don't have one of these under the left hand part of the steering wheel. Any insight brother would be great
  9. Jan 11, 2016 at 12:40 PM
    rhc0930
    Houston
    14' TRD Sport 4x4
    ^^x2. I was actually going to ask the same thing.
  10. Jan 11, 2016 at 12:46 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Only fuses like that are under the hood of the truck. Sooooooooooooooooo confused right now
  11. Jan 11, 2016 at 1:07 PM
    ramonortiz55
    Ramon
    Texas
    stock
    The interior fuse panel below the steering wheel.
    You will have to remove the bottom panel below the steering wheel to expose the fuse panel.
    Once you get that fuse panel exposed, you might have to remove four bolts that hold that fuse panel in place. This will allow you to "SLIGHTLY" move it down to reach your hand BEHIND the fuse panel.
    On the back side of the fuse panel you will see three relays. The relay furthest to your left - furthest towards the driver's side door - is your relay for the power outlets.
    You can remove it and test by plugging something in the outlets and see if it starts to charge or not.
    If you have trouble removing the relay due to "large hands/fingers" you may use a small flathead screwdriver to pry it off.
    Make sure you have the negative side of the battery disconnected!
  12. Jan 11, 2016 at 1:07 PM
    ramonortiz55
    Ramon
    Texas
    stock
    I have been meaning to do a pictorial write up. .. the weather has not let me.
    Hayrider likes this.
  13. Jan 11, 2016 at 1:11 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Wow I thought this was a pop in pop out kind of thing. I have zero knowledge of taking panels or anything else apart. be a bit before I send my core to you brother. It's freezing here and this doesn't sound like a 5 to 10 minute job
  14. Jan 11, 2016 at 1:13 PM
    ramonortiz55
    Ramon
    Texas
    stock
    Take your time man.
    Ill try to get a pictorial write up as soon as i can
  15. Jan 11, 2016 at 1:16 PM
    #35
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Why would I be popping open the top of the relay Ramon? Is this already modded bro?
  16. Jan 11, 2016 at 1:25 PM
    #36
    ramonortiz55
    Ramon
    Texas
    stock
    sorry. that was misleading, let me rephrase that
  17. Jan 11, 2016 at 2:16 PM
    #37
    Buda Pest
    Buda Pest Well-Known Member
    With the contact being permanently closed, this doesn't drain th battery slowly over time? Sometimes, my truck would sit for a week or so.
  18. Jan 11, 2016 at 2:20 PM
    #38
    ramonortiz55
    Ramon
    Texas
    stock
    nope. if you dont have anything plugged in..
    even if you charge your phone on there overnight, it wouldnt kill your battery, been there done that lol
    a lot of older vehicles had always hot power outlets.. and they never had this problem :notsure:
    Unchained 5150 likes this.
  19. Jan 11, 2016 at 2:21 PM
    #39
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Supposed to be a little nicer Ramon. Stop slacking just because you got married and post the install instructions. Damn married people???
  20. Jan 11, 2016 at 2:22 PM
    #40
    ramonortiz55
    Ramon
    Texas
    stock
    shhh im a little busy :anonymous:
