Always Pressurized Waterport
Discussion in 'Other Builds' started by 2ayne, Jan 30, 2020.
  1. Jan 30, 2020 at 3:10 PM
    2ayne
    2ayne [OP] Well-Known Member
    Zayne
    Ohio
    2017 Cement TRD Pro
    Something I built a while back that several people always ask about.
    I figured TW was the best place to do a write up so here it goes:
    I have a ARB Single Air Compressor mounted under the hood of my 2017 Tacoma.
    The ARB compressor is wired through a Switch-Pros SP-9100 to be used as it’s on/off switch.
    All ARB compressors to my knowledge come with a inline pressure switch mounted to the discharge of the compressor that shuts it off automatically when the pressure reaches approx. 100psi.
    When the pressure falls in the discharge line the compressor will turn back on until the pressure switch is made again. This pressure switch always needs installed in a Tee fitting before anything else in the compressor discharge line to insure no over-pressurization occurs and damages your compressor.
    YOUR FITTING CONFIGURATIONS WILL PROBABLY DIFFER BASED ON HOW AND WHERE YOUR AIR COMPRESSOR/WATERPORT IS INSTALLED! THIS IS MY WAY!
    PARTS:
    I used a Viair Pressure Regulator I had laying around but there are many more cheaper options available online for this and at most big box hardware stores.
    Below is a link to a cheaper option but is relatively the same regulator I used.
    I removed the waterport water nozzle holder they provide and drilled out the mounting screw holes on the bracket for the Viair Regulator and re-installed it with the provided rusty waterport screws for the nozzle/gun holder/holster?
    https://www.amazon.com/dp/B00IDCYKEY/ref=cm_sw_r_cp_api_i_wFWmEbE438M35
    -Thread Tape
    -1/4” Air Line (However long you need to get from your on board air compressor on your vehicle to your waterport)
    -(2) 90°, 1/4” MPT X 1/4” Tubing Compression Fittings (For Regulator)
    -(1) Straight 1/8” MPT X 1/4” Tubing Compression Fitting (For Waterport) Removed the shrader valve that comes in the waterport!
    -(1) 1/4” X 1/4” 90° Street Elbow (On Air Compressor. Yours may differ)
    -(1) 1/4” X 1/4” Tee (For Hose Chuck On Air Comp.)
    -(1) Straight 1/4” MPT X 1/4” Tubing Compression Fitting (For Air Compressor Side)
    -(1) 1/4” Ballvalve
    (On Air Compressor to valve off air to waterport if needed.)
    -(1) 1/4” Incline Check Valve
    (To Stop Water From Back Filling The Air Compressor) Similar to the one in this eBay link:
    https://www.ebay.com/ulk/itm/271855082480
    I set my regulator around 20psi. That seems to be the sweet spot with mine.
    Turn your air compressor power switch to “ON” and start spraying water. Your Air Compressor should now kick on and off as needed to keep your Waterport maintained at the desired pressure.
    Hope this helps!
    sachou, jonghwa79, e3po and 2 others like this.
  2. Jan 30, 2020 at 3:12 PM
    2ayne
    Zayne
    Ohio
    2017 Cement TRD Pro
    Feel free to let me know if I missed anything or if anyone has any questions or critiques.
  3. Jan 30, 2020 at 3:25 PM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Water for shower or small brush fires or ?
    Very cool - great idea as I have the ARB dual....and always looking for uses
    BTW where did you get the cap for your ARB QD?
  4. Jan 30, 2020 at 4:00 PM
    2ayne
    Zayne
    Ohio
    2017 Cement TRD Pro
    We use the Waterport in the truck for camp showers, cleaning dishes, spraying the dog off when he rolls in something and extinguishing camp fires mostly.
    It holds a little less than 4 gallons. They’re “okay” but not great. I’d like to carry a little more water and have a system with pressed in metal threads for hose connections and such rather than threaded plastic like the waterport has.
    I’m in the process of replacing it with a 12 gallon Front Runner Tank.
    https://thewaterport.com/build-a-tank/
    I purchased the dust cover from Expedition Essentials here:
    https://expeditionessentials.com/products/arb-coupler-dust-cover
    Pablo8[QUOTED] likes this.
  5. Jan 30, 2020 at 4:06 PM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Thanks and nice write up!
    2ayne[OP] likes this.
  6. Mar 11, 2021 at 9:43 AM
    e3po
    e3po Active Member
    2020 Tacoma TRD Off-Road
    Thanks for the write up! I see you’re using a hose and nozzle that isn’t original to the waterport. Would you mind listing where you purchased and parts? My nozzle is leaking and I’m looking to find superior parts instead of ordering from waterport. Thanks in advance!
  7. Mar 11, 2021 at 1:19 PM
    2ayne
    Zayne
    Ohio
    2017 Cement TRD Pro
    Plastair SpringHose PUW615B9-M-3OT-AMZ Light Polyurethane Lead Free Drinking Water Safe Marine/RV Recoil Hose, Blue Translucent, 3/8-Inch by 15-Foot https://www.amazon.com/dp/B0187602FG/ref=cm_sw_r_cp_api_glt_fabc_706DH05F7WKMAX2D4CGC
    Any garden hose or nozzle will work. This is the hose I used. The nozzle was just laying around my garage at the time and a lot better than the one they send.
    PNWWanderer and e3po[QUOTED] like this.
  8. Mar 14, 2021 at 7:09 PM
    e3po
    e3po Active Member
