Always Warm air from vents-even at "cold" setting
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TACSO 1114, Mar 24, 2015.
  1. Mar 24, 2015 at 7:14 PM
    TACSO 1114
    TACSO 1114 [OP] New Member
    San Francisco
    Tacoma 2015 Off Road
    When the engine is at normal operating temperature the air that blows from the cab vents is always slightly warm even if Temperature dial is set to coldest setting. Even if it is cool outside and the Temperature dial is set to the coldest postion (but AC not on) the blower air is noticibly warm. Is this normal for the 2015 Tacomas. Anyone else experience the same thing?
  2. Mar 24, 2015 at 7:27 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    That's about right. I think the engine has a 195 degree thermostat that will keep it blowing warm. I don't know if it's possible or advised where you live to change out to a 160 degree thermostat but where I live, I like it just the way it is.
  3. Mar 24, 2015 at 7:38 PM
    tacoma4
    tacoma4 Well-Known Member
    Maybe the blend door isn't moving completely or it's leaking air past? I wouldn't say mine is warm at all when in the cold position with ac off.
  4. Mar 24, 2015 at 7:39 PM
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    On my 2009 Tacoma the heat isn't turned off completely until the dial is down in the air conditioning part of the range.
  5. Mar 25, 2015 at 11:11 AM
    TACSO 1114
    San Francisco
    Thanks to all above for their imput. I think I will bring it up with the dealer when it goes in for its 10K check.
    Also - my understanding is that unlike previous era Tacomas there is no longer a user operated flow control valve that controls hot coolent flow through the heater core based on the temp dial position. In current models the heater core is always getting full flow and that cab temp is only controlled by an air mixing system. Is this correct?
