Am I about to be screwed?
Discussion in 'Suspension' started by Armyballer, Apr 2, 2009.
  1. Apr 2, 2009 at 11:07 PM
    Armyballer
    Armyballer [OP] Well-Known Member
    Alabama
    05 4x4TRD
    As I said before, I have a cracked right front CV boot on my 05 Taco. Today I stopped by a "Big 10 tires" to get a price quote on replacing the CV Boot alone (Which I have priced on the internet for $25-$35). The clown behind the counter tells me "Oh you don't hear about doing that much anymore, usually you just replace the entire Axel which will run you about $250.00 in parts alone". I just said ok and left. Was he trying to hook me up and make a quick $400 (after labor) or is he correct? BTW, I've already had my mod guy look at it, he says the axel is fine and not much grease was lost, he sees no addational damage and thinks all I need is the CV boot replaced.
  2. Apr 3, 2009 at 3:22 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
  3. Apr 5, 2009 at 8:01 AM
    Muy Grande
    Muy Grande Well-Known Member
    Dallas, TX; RGV, TX
    06 DC TRD
    Suspension: DHoes up front, Dakar and OME out back. Audio: Alpine w205 w/ pair of Alpine Amps, Image Dynamic 6.5 Component Speakers up front and Image Dynamic Subs in the Back. Armor: ARB Bull Bar, Rocktek rear bumper and custom rock sliders. Other: Rigid Industries LED Light Bar, Platinum DieHard Battery, BlueSea Fuse Block, rear lights, bed lights, leds inside.
    You can buy a "Speedy Boot" repair kit from Autozone/O'reilys/PepBoys. This is only if you are replacing the boot itself.....I have used them on my older Toyota and it worked fine. You don't have to take the whole CV out to do this job and it can be done in 30 mins. It will get a little messy and you need to have a little bit of room. Of course the best option is to just fix the boot. The "Speedy Boot" is a temporary fix, I wouldn't suggest wheeling if you go this route. Good luck.
  4. Apr 5, 2009 at 8:47 AM
    Toph
    Toph Addicted to V8s
    Dirty South
    90 Mustang Notch, 06 CTS-V
    A lot of people don't catch broken CV boots until they've lost most of the grease and are messed up and are making noise. Since he didn't look at it I'm guessing he was just airing on the side of caution.
    The shop I used to work at had a machine that could stretch a new boot on...but you're still looking at labor to take it off put the boot on and put it on again.
