Am I being ripped off for wheel bearing replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by silvertaco.69, Dec 18, 2019.
  1. Dec 19, 2019 at 6:09 AM
    WSW3
    WSW3 @willwitecki
    Will
    Connecticut
    '08 Tacoma DCSB TRD Sport
    Scratches, dents, and a lot of miles
    Honestly I replace mine with the TRQ assembled bearings and they've been fine. I ordered 2 last time so I can have a spare around but they were 180 for the pair. The one I replaced has been on for 25k, and was replacing the OEM assembly with a replacement bearing I did about 40k before that.
    Wheel bearings shouldn't take you more than 15 minutes per side, so I would start there. If problems persist I'd come back here and post again. With the difference in price between DIY and having a shop do it, you can buy a whole lot of tools.
  2. Dec 19, 2019 at 6:35 AM
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    Had the RF go out on the '05 @ 90K miles......
    Had the NAPA shop change it....used Toyota OEM bearing......
    IIRC was $300ish
    OP....shop around !
  3. Dec 20, 2019 at 5:45 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Unless you have major rust to deal with, do it yourself. Quite easy to do if you buy the pre-assembled WB. I swap both of mine out in about 3 hrs. Just need a 3 ton floor jack, 200 ft/lb torque wrench, BFH and basic hand tools but a big plus if you have an impact. You can invest in the tools and still be cheaper than paying for a shop. Lastly, Don't go cheap with WBs which is likely with some shops. I bought mine from an ex-TW member a few yrs ago until his customer service went down the toilet later down the road but very high quality stuff. Current TW member
    @05Taco4x4 is worth checking out his products.
    TheDevilYouLove likes this.
  4. Dec 20, 2019 at 6:02 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    I think 15 minutes a side is a bit underestimating the time required. @Wattapunk seems more spot on.
    koditten and goforbroke123 like this.
  5. Dec 20, 2019 at 6:09 AM
    Wattapunk
    Uncle K
    TX
    2005 DCLB 4WD
    Lol, 30mins per side and squeezing in a beer is what it took me to just remove those rear bolts and hammering with the bfg to get the old ones off.
    Forgot to mention that you can rent the axle nut socket from autozone.
    PzTank[QUOTED] likes this.
  6. Dec 20, 2019 at 6:10 AM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    Just ordered a set from the Taco man. Quick communications. I'll report back on shipping time and quality.
  7. Dec 20, 2019 at 6:24 AM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    I did mine, it was easy. I got the hub assembly with Koyo bearing from the member here. A slide hammer helped to get the old hub assembly off. Would have been a 20 minute job per side but I forgot to put on the dust shield for the brakes, then I put it on backwards so the caliper wouldn’t go back on, lol. The second side went super fast having already made all the possible mistakes doing the first side.
    Total cost for both sides with quality Japanese bearings was $320
    TacoBreaker and PzTank like this.
  8. Dec 20, 2019 at 6:53 AM
    PzTank
    Above the Notches
    Or ask your TWSS for one! Worked for me last year!!
  9. Dec 20, 2019 at 7:00 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    I paid 90 for the bearing and a shop pressed it and installed it for 140
  10. Dec 28, 2019 at 2:28 PM
    Fullboogie
    Dave
    Houston
    Ordered just before Christmas and they showed up 4 days later! They were packed extremely well. Much appreciated!
    Muddinfun and whatstcp like this.
  11. Dec 29, 2019 at 1:05 AM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap
    This was one of the first things I did to my truck by myself I saved a ton of money by not having somebody else do it and I learned a ton. My only regret is not buying oem quality parts oh well
  12. Dec 29, 2019 at 4:36 AM
    airrage
    airrage Well-Known Member
    Myrtle Beach, SC
    2006 Tacoma Prerunner SR5 DCSB
    17X9 Gear Alloy Rims, BFG KO2's , Android Radio, 32" LED Light Bar in Bumper, LED Bed Lights,
    i bought mine on Ebay Detroit axel about $89 each preassembled. Easy to install!
    koditten likes this.
  13. Feb 23, 2020 at 1:27 AM
    FixItPhillip
    FixItPhillip Member
    Heres a video i made of replacing the wheel bearing as a whole hub assembly on a 2wd. It comes assembled ready to go with the hub, bearing, seals, and mounting bolts.
    Same process also applies for 4x4 tacomas, only difference is you have to remove the axle nut in the center. Hope this helps. FixItPhillip
    https://youtu.be/BCP3wxUs-Vs
    DRAWN and EdgemanVA like this.
  14. Feb 27, 2020 at 8:35 AM
    greyzland
    greyzland Member
    Joe
    California
    2011 PreRunner
    Running Board Roof Rack Bed Extender
    Thank you very much FixitPhillip... you really made it look easy with a very nice instructional video... the most I did in my 2011 Tacoma with 80K mileage was Oil/Oil filter change and lately changing both headlight assemblies.... your style is exactly my hometown mechanic's style, direct to the point, some may comment about that mechanical dust blowing and no safety glasses but that's how I grew up in our hometown..the important thing is it got the job done.... and at 3:00 sounds like a hatch roundhead and a pure roundhead crowing in the background...that was nice accompanying music while working.....
  15. Feb 27, 2020 at 12:09 PM
    #35
    XSplicer62
    XSplicer62 Well-Known Member
    Jefferson State
    2005 Tacoma DC TRD OffRoad
    Ten weeks later and no update from the OP??
    Had my LF wheel bearing replaced by a local shop last month. I was not in a position to do it myself. Bearing (NAPA) was $168 and 3.1 hours labor @ $90/hr.
  16. Feb 27, 2020 at 12:43 PM
    #36
    dk_crew
    dk_crew Well-Known Member
    Dave
    Austin, TX
    2005 Tacoma 4x4
  17. Feb 27, 2020 at 2:36 PM
    #37
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    This ^ is the very best route,and its easy.
