Am I crazy?
Discussion in 'Suspension' started by rmerchant3, Mar 24, 2010.
  1. Mar 24, 2010 at 6:13 AM
    rmerchant3
    rmerchant3 [OP] Insert nonsense here
    I notice a lot of people on here going for the 3 Inch lift are using a coil over setup from say toytec. Now I've installed lift kits on a jeep before and these coil over kits seem to be a joke. Your not actually lifting your truck, instead you are stiffening a spring which forces the truck to sit higher and have a stiffer/more bouncy ride. This seems so illogical. Isn't there a company out there that sells a REAL suspension lift/travel kit for our toyotas? The last one I put on a wrangler actually increased the suspension travel while lifting the truck. This is what you want. Not a cosmetic lift.
    Oh and the top plates...those are just a joke. That is essential a body lift. Someone please tell me there is a real kit out for our trucks.
  2. Mar 24, 2010 at 6:16 AM
    98tacoma27
    Ben
    Not Beech Creek
    You're comparing apples to oranges.
  3. Mar 24, 2010 at 6:19 AM
    Trigger
    Trigger Well-Known Member
    ^ yep
  4. Mar 24, 2010 at 7:06 AM
    rmerchant3
    No I'm not, I'm just trying to distinguish a true suspension lift between these coilover setups. So it would be safe to assume that 90% of the people that have a 3" lift have not improved anything but looks and maybe a different ride feel. They haven't gained any actual suspension travel for better articulation.
    Do the OME setups actually increase travel?
  5. Mar 24, 2010 at 7:08 AM
    nad
    nad mmmm tacos!
    Jordan
    Canada
    2014 Sierra All Terrain
    most people dont know what articulation is, they just want their truck to look 3 inch's higher, as for the ome im not sure about it myself
  6. Mar 24, 2010 at 7:31 AM
    98tacoma27
    Ben
    Not Beech Creek
    Comparing the lift of a solid axle to an independet suspesion is comparing apples to oranges, but I do see your point in increased travel. A long travel kit will give you increased travel.
  7. Mar 24, 2010 at 7:35 AM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    for extra travel either a long travel kit or extended travel CO's and UCA's are the way to go.
  8. Mar 24, 2010 at 8:51 AM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    word... long travel for the win...
  9. Mar 24, 2010 at 8:53 AM
    TexasIslandBoy
    TexasIslandBoy THE RED DRAGON!!
    Andrew
    South Texas. SPI
    07' trd offroad 4X4 (For Sale)
    pro comp 6inch lift 35'' tires moto 950's radfo coilovers magnaflow exhaust 5/16" front skidplate usa spec ipod interface tree pin strip mod dry drop in filter full size BFG KM2 spare
    yea the fox kit or icon
  10. Mar 24, 2010 at 8:55 AM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    oh, we're playing that game huh? :D
  11. Mar 24, 2010 at 9:08 AM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Yup...what he said...your components are every thing...like for example if you wanted increased travel in the rear you'd get Bilstein 5125's rather than 5100s
  12. Mar 24, 2010 at 9:09 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    trucks are typically designed for a different style of offroading. that's why most of the hardcore crawler guys are using jeeps or suzukis (short wheel base) they will increase their articulation via lifts and travel increases to gain more flex to crawl over obstacles. now yes, you can do that with a truck too, but there is a reason the large majority of guys you see doing baja and other desert races use trucks vs jeeps. the suspension is designed for different aplications. the coilover lifts guys put on hteir tacos ARE real lifts. coilovers are far from just asthetic. they are much tougher than stock and have greater heatdisipating capabilities. these systems are still great for slower crawling and such, but they are really designer for absorbsion vs travel that a jeep kit is designed for. there's a reason jeeps with increased suspension travel aren't winning baja. so yes, you are compairing apples to oranges...a similar comparison would be an older toyota with a solid axel...but you'd see in that case that the lift is exactly like a jeeps.
  13. Mar 24, 2010 at 9:10 AM
    ColtsTRD
    Scott
    AZ
    Right! IFS is shit for articulation unless you get extend shocks...long travel...or solid axle swap. :(
  14. Mar 24, 2010 at 9:10 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    YAY! I love this game!!!
    :p
  15. Mar 24, 2010 at 9:11 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    ^^^ I hate every one of you
  16. Mar 24, 2010 at 9:12 AM
    mjp2
    NJ
  17. Mar 24, 2010 at 9:14 AM
    98tacoma27
    Ben
    Not Beech Creek
    No reason to hate MJP2. It's purely a show truck. :p
  18. Mar 24, 2010 at 9:15 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    haha, ouch, you gonna take that?
  19. Mar 24, 2010 at 9:16 AM
    mjp2
    NJ
    Well, it does spend most of its time on a pedestal. More accurately, 4 pedestals supporting the frame. :p
  20. Mar 24, 2010 at 9:17 AM
    98tacoma27
    Ben
    Not Beech Creek
