Am I good to go without a wheel alignment?
Discussion in 'Wheels & Tires' started by JimT805, May 14, 2018.
  1. May 14, 2018 at 4:02 PM
    JimT805
    JimT805 [OP] Dazed and Confused
    Jim
    Goleta, CA
    2014 Prerunner SR5 DCSB 2.7L
    Baja Alloy Wheels Toyo AT2 C-Load Avid Bumper Guard Oval Step Bar
    I had a wheel alignment a little over 2 years ago after putting on new tires. I have less then 20K on the new tires and I see no signs that my truck needs an alignment. Rides fine, doesn't pull or drift one-way or the other and tire wear is even.
    I am about to switch-out my steel wheels for OEM alloy wheels and add some C-load AT Tires. the new wheels are the exact same fitment as the stock steel wheels.
    I wanted to tryout America's Tire Shop that just opened in town but they do not perform wheel alignments.
  2. May 14, 2018 at 9:16 PM
    oscolivar1
    oscolivar1 Well-Known Member
    Oliver
    VA
    2017 Tacoma Limited
    Bilstein 8112/8100, JBA UCAs, Icon RXT leaf pack, work wheels 17x8.5;-10os, 285/75/17 cooper LTX AT3, Mobtown HC rear bumper and Sliders, SSO front bumper, BAMF greceased grill.
    What size tires are you getting?
    General rule is if you change out your tires you probably need one especially after 2 years. Your alignment numbers were use to your older setup.
    Firestone lifetime alignment! If you have big aggressive tires.
    roguegs likes this.
  3. May 14, 2018 at 9:29 PM
    JimT805
    Jim
    Goleta, CA
    Staying stock size: 245/75R16.
  4. May 14, 2018 at 9:31 PM
    Rob Daman
    Rob Daman The Taco Formerly Known as Hard Shell Taco
    Rob
    So Cal
    17 OR 6MT
    a lot
    I say no but keep an eye on wear.
  5. May 14, 2018 at 9:34 PM
    JimT805
    Jim
    Goleta, CA
    Changing out SR5 Steel Wheels 16" X 7" 30 mm offset with OEM Alloy Wheels 16" X 7" 30 mm offset. Replacing Michelin M/S2 with Discoverer AT/3 or Toyo ATll.
  6. May 14, 2018 at 9:37 PM
    oscolivar1
    Oliver
    VA
    2017 Tacoma Limited
    Really depends on how you drove the truck for the pass 20k miles in the 2 years you've driven it. If you done any type of offroad adventures IMO you should. Up to you though.
    Good luck.
  7. May 15, 2018 at 8:44 AM
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
    Glad to hear you have a new Discount Tire/America's Tire store that opened near you. At Discount Tire/America's Tire, we do what we do best, that is sell and service tires and wheels.
    The place where you had your alignment may just check it for you or watch for any abnormal wear.
    We appreciate your support.
