Am I good to go?
Discussion in 'Suspension' started by TacoMal, May 17, 2011.
  1. May 17, 2011 at 6:01 AM
    TacoMal
    TacoMal [OP] Well-Known Member
    California
    09 TRD Off Road Dbl cab
    Wet Okole's, Relentless Sliders, Plasti Dipped badges and wheels
    I think I'm about ready to install my lift and just want to make sure I have everything I need. I have the following:
    5100's front and rear
    Dakar leaf springs
    New bushings
    Extended U bolts
    Am I good to go? Is there anything else I MUST have before I get started?
    Thanks in advance for your help.
  2. May 17, 2011 at 6:25 AM
    brettb
    brettb Well-Known Member
    Brett
    Laramie, Wyoming
    '99 Tacoma
    Its a good thing you got extended U bolts. I got DAKAR leafs in the back too but I just used the same U bolts. Probably not the best choice but I re-threaded them so I think I will be okay. 5100's were a good choice too
  3. May 17, 2011 at 6:28 AM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Silverado Z71
    Readylift, Truxedo, Husky Liners, Carven
    Only thing I think you may need are extended brakelines. I'm not 100% sure but I think if you install the dakars you should also get the longer brake lines
  4. May 17, 2011 at 6:29 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    breaker bar, PB blaster and maybe even a torch or cut-off tool depending on where you live (sometimes those things get really rusted on there). A little patience and an extra set of hands doesn't hurt!
  5. May 17, 2011 at 6:33 AM
    MAXTacoma
    MAXTacoma Well-Known Member
    Lexus GS 350
    Have the Dakar leaf pack installed, no extended brake lines needed.
    I would suggest the drive shaft spacer. You might get some vibs if you dont. GL
  6. May 17, 2011 at 6:35 AM
    NC15TRD
    Nick
    PA
    16 Silverado Z71
    Thanks for straightening me out on that, again I wasnt sure though.
  7. May 17, 2011 at 6:49 AM
    MAXTacoma
    Lexus GS 350
    NP, some people go ahead and replace them and others dont. Its just a personal preference but ins't required.
  8. May 17, 2011 at 3:02 PM
    TacoMal
    California
    Thanks for the help everyone. I will definitely post pictures when I'm done!
