am I losing my mind??
Discussion in 'Technical Chat' started by NotSoFastEddie, Mar 23, 2020.
  1. Mar 23, 2020 at 6:02 AM
    NotSoFastEddie
    NotSoFastEddie [OP] Member
    Ed
    2014 charcoal grey Tacoma Prerunner
    2014 Access cab Prerunner SR5, with a 2.7 4-banger. She just turned over 100k miles, so I figured it was time to start doing my own maintenance. When I checked the owners manual, it said oil capacity with a new filter was 6.1 quarts. I poured in a 5 quart jug, let it run a minute, check the level and sure 'nuff, it was a quart low. Pour in another quart, clean myself up and let it sit overnight. Now the oil level on the dipstick shows way high!? What the heck? Do I drain off a quart and run it a while, or do I go with the book and just trust the 6 quart capacity? So far she's been flawless, so the last thing I want to do is risk screwing it up by overfilling it. Help?!
  2. Mar 23, 2020 at 6:14 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    The dip stick will have a high and low mark. Keep between the 2 levels. What is happening, is the oil is draining from the head (etc) and back into the pan. So your cold level will be higher than the hot level.
  3. Mar 23, 2020 at 6:20 AM
    Sep1911
    Sep1911 Well-Known Member
    2016 Taco
    Did you start the engine before checking in the morning?
    You're supposed to run the engine for a bit and have the engine at operating temp. The cold vs warm part doesn't make much of a difference but definitely run the engine first to let the oil flow through all the passages and let it sit while off for a minute before checking the oil.
  4. Mar 23, 2020 at 6:33 AM
    NotSoFastEddie
    Ed
    nope, I'm an old fart who was always told to check my oil when the engine's cold and all the oil has drained down into the pan. Looks like I've got to relearn a lot to deal with these new vehicles. Changed the plugs on it at the same time, and it threw me when I couldn't find a distributor, plug wires or any evidence of plugs. Had to You-Tube it to find them. Thanks for the help
    Larzzzz and Wyoming09 like this.
  5. Mar 27, 2020 at 4:46 AM
    NotSoFastEddie
    Ed
    that makes perfect sense, in a strange sort of way. Thanks!
  6. Mar 30, 2020 at 5:55 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Nothing wrong with that... We old farts can still still learn new tricks. We don't have a choice; having to work around these aches and pains that keep popping up seemingly out of nowhere. Lol
  7. Mar 30, 2020 at 7:57 AM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    U would have to fill more than a few quarts to matter
    no less U have to run hard / fast / under load for an ext3ended period o time to pressurize the sump
    all o which is totally unlikely
    few engine use ' splash ' lubrication whereby the crank+counterweights actually
    beat their way thru the sump oil
    essentially U have little to worry about
    even a quart low by design
    most engines allow that the amount o oil traversing thru the engine
    reconstitues with at least an equal volume in the sump
